Old 06-17-2015, 03:56 AM   #57
ajc209
Drives: GT86 Cosworth
Safe to say we are eagerly awaiting some more information!
ajc209 is offline   Reply With Quote
Old 06-17-2015, 10:00 AM   #58
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
In for details.
-Mike Paisan
Maintaining, Modifying and Educating TriState Enthusiasts since 2001.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 06-19-2015, 08:02 PM   #59
FRSKEV
Drives: FRS
My guess is $6k-$8k and up from there. Not sure about the entry level ones
2013 Scion FR-S
Autox - Track
Paint Protection Film Pro
FRSKEV is offline   Reply With Quote
Old 06-20-2015, 08:52 AM   #60
RBbugBITme
Drives: S60R/Corvette
Good guess for single adjust with upper mounts. That's the cost of total domination.
Revalves are $75 per corner and $40 in oil if you need it. Complete rebuilds with new seals, oil, etc. are $150 per corner.
Springs are your choice or we can guide you. Raceseng will have some recommendations after we finish on-track testing.
Any other technical questions just fire away.
Ryan M.
Strange Engineering
Director of Suspension Development
RBbugBITme is offline   Reply With Quote
Old 06-20-2015, 10:43 AM   #61
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Are these custom for the 86 or off of the universal tubes you guys have?
Old 06-20-2015, 10:46 AM   #62
RBbugBITme
Some custom parts some parts that fit other applications.
Ryan M.
Strange Engineering
Old 06-23-2015, 02:46 PM   #63
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Ouch. While the S2000 doesn't use more expensive camber plates, this is what a Penske 9300 dual adjustable with remove reservoirs costs:
http://performanceshock.com/index.ph...oducts_id=1220
$4280
Old 06-23-2015, 03:04 PM   #64
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
can you confirm if you plan on providing SCCA Street-Class compliant units?
or is this all going to be a coilover type setup to be used with helical springs of whatever stiffeness the client wants?
Old 06-23-2015, 03:04 PM   #65
RBbugBITme
The camber plates are minimal. All of the cost difference between our Corvette/Miata/Supra/Honda/Etc. applications and the BRZ/Mustang/Camaro are the way we design struts. Its superior in every way to a big 22mm shaft design but there are more parts, more critical surfaces, more material, etc. If it was cheap and easy, more Asian mfgs. would be doing it.
Ryan M.
Strange Engineering
Old 06-23-2015, 03:12 PM   #66
RBbugBITme
Which rules are you concerned about?
Ryan M.
Strange Engineering
Old 06-23-2015, 03:17 PM   #67
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
$4280
No Springs either. So Then add ~$300-$400+ for springs.
Old 06-23-2015, 03:17 PM   #68
King Tut
NASA SpecE30 Racer
King Tut's Avatar
The reuse of the OEM springs, spring perches, and top hats.
Old 06-23-2015, 03:18 PM   #69
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Yeah. You will find most shock packages don't come with springs. I prefer Hyperco for $55 a pop.
Old 06-23-2015, 03:22 PM   #70
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
in stock class you are allowed to upgrade your dampers, so long as
-they are used with oem springs
-spring perch is at oem height
-mounting holes don't allow for camber adjustment beyond oem levels
-and I believe the oem tophat must be used, or if aftermarket I think it can't alter the vehicle height or offer alignment changes.
Ultimate Racing Turbo Kit sweetfrs Forced Induction 34 12-17-2015 11:25 AM
More info on Penske shocks ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 156 04-28-2015 10:22 AM
Ultimate Racing Turbo Kit ganz954 Forced Induction 19 11-13-2014 10:34 PM
Ultimate Racing Exhaust help psyclone07 Engine, Exhaust, Transmission 0 07-06-2014 11:05 PM
Ultimate Racing, quality? rhythmM Engine, Exhaust, Transmission 5 11-30-2013 05:46 PM
