Old 06-19-2015, 11:23 AM   #1
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Caster off, is this causing the problem?
After swapping onto summer tires after the winter was over, i noticed that whenever i enter a corner turning right, the whole front end of the car skips to the right, as if there if the sidewall is flexing. Right when the car skips to the right, traction is immediately lost, traction control light starts blinking. I can't drive spirited into any corner, let alone even take the car to auto x and track day. After the corner is finished and i turn the wheel straight, the car still wants to pull to the right as if its turning, the steering wheel has to be cocked to the left in order for the car to trek straight, then the car pushes it self back to straight, allowing the steering wheel to back into center position to go straight.
I started guessing it was the tires, so i adjusted tire pressure, that didn't work. I bought a whole new set of tires, Bridgestone RE71R and the problem is still there, i'm losing traction into corners going 20mph, where i could previously go at close to 35.
I had an alignment done before the issue started, after the issue began i had the alignment checked again from a better shop, the alignment was fine, except my caster on the left was 4.6, where the range is 5.2-6.7. The right side is 5.9 - in the range. The car was in an accident close to three years ago, the left side had a damaged wheel, but an alignment showed it trek straight. I don't have specs, so who knows if the caster was off the whole time?
Is the caster causing my problem? I know by elimination it seems to be that it would, but every time i talk to my tech friends, they disagree that this would be the issue, since to them caster that small doesn't matter in the real world. I can't seem to think what else it could be, maybe the steering rack?
Edit: I also started a similar topic a while back, this was before i changed the tires. http://www.ft86club.com/forums/showthread.php?t=88412
Old 06-19-2015, 12:22 PM   #2
wparsons
wparsons's Avatar
Is there anything loose in the front end? It sounds like worn/damaged bushings/tierod/balljoint. Anytime you find the wheel doesn't center properly intermittently that should be the first things checked.
flickr
Old 06-19-2015, 02:34 PM   #3
dem00n
dem00n's Avatar
Drives: Scion FRS
I just jacked up the front and checked both sides. It seems the balljoint on the drivers side is lose, there is a lot of play on the whole suspesnion. Could a bad balljoint cause the caster to go off?
Thanks
Old 06-19-2015, 03:34 PM   #4
DSV-UltraGL
TSC Off
Drives: 2011 Genesis Coupe 3.8 ZF Track
also check your front bushings. on a macpherson strut car, I would check the tension rod bushings as its -very often- the reason why the caster is off.
EDIT: the yellow one >>
DSV-UltraGL is offline   Reply With Quote
Old 06-19-2015, 03:41 PM   #5
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
what are your FULL alignment numbers after checking with the better shop?
Old 06-19-2015, 03:55 PM   #6
wparsons
wparsons's Avatar
Thanks
100% that's the reason, I'm kinda surprised an alignment shop wouldn't have caught that.
Get everything back in working condition and get another alignment afterwards.
flickr
The Following 3 Users Say Thank You to wparsons For This Useful Post:
dem00n (06-19-2015), solidONE (07-17-2015), Ultramaroon (06-20-2015)
Old 06-19-2015, 04:10 PM   #7
dem00n
dem00n's Avatar
Drives: Scion FRS
Here are the specs, stock suspension.
Old 06-19-2015, 06:17 PM   #8
Calum
That Guy
Drives: 2013 asphalt FRS MT
Another reason a steering wheel might not center is worn strut mount bearings.
Old 06-20-2015, 04:02 PM   #9
a_dee
a_dee's Avatar
Drives: '14 BRZ CBS
The caster is definitely an issue, anything greater than .5 degrees left right will start to exhibit pull to one side. It will also affect the ability for the car to center the wheel
'14 BRZ CBS
>>Pretty Stock
a_dee is offline   Reply With Quote
Old 06-20-2015, 04:15 PM   #10
dem00n
dem00n's Avatar
Drives: Scion FRS
Figure I'd give a small update. The local Toyota dealership wouldn't sell me an individual balljoint, they said I'd have to buy the whole front lower control arm. They even showed the me the exploded diagram and it even stated that as well. I was told that it could be a Subaru thing.
Odd.
Either way, i ordered an OEM one online from another parts center.
Old 06-21-2015, 12:16 PM   #11
wparsons
wparsons's Avatar
Where'd you get just the balljoint? There were numerous other posts/threads about not being able to find the balljoint without the whole LCA!
flickr
Old 06-21-2015, 12:36 PM   #12
Racecomp Engineering
Mitsubishi did this, so a lot of evo guys would just get the white line roll center adjusters.
- andy
wparsons (06-21-2015)
Old 06-21-2015, 03:27 PM   #13
dem00n
dem00n's Avatar
Drives: Scion FRS
Here are two places.
http://www.villagescionparts.com/sho...category=19383
Part#: SU00300358
https://parts.olathetoyota.com/2013-...r-s-parts.html
I ordered it from olathetoyota.
I saw that Buddy Club and Megan Racing make aftermarket ones, but i don't want more adjustment on this car...
Edit: You guys know if the balljoint has to be pressed in via hydraulic press? Or can a balljoint press tool can be used without a problem?
Old 06-29-2015, 02:22 PM   #14
dem00n
dem00n's Avatar
Drives: Scion FRS
Update:
Turns out you can't order the balljoint individually, it does have it's own part number but it has to be ordered with the LCA. Olathetoyota told me this a week after ordering.
What do you guys recommend? Buddy Club or Megan Racing?
Replaced transmission fluid, now it's causing problem frslee Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 37 11-02-2016 05:35 PM
Caster, SAI, Steering and Camber Wepeel Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 02-24-2015 08:09 PM
HVT vs Raceseng Caster Camber Plates? Phaedrus29 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 40 12-22-2014 05:34 PM
Adjust camber/caster from top or bottom? diss7 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 06-22-2014 04:03 PM
Rear Caster Adjustment Questions RWDRIFT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 12-05-2012 11:47 AM
