Old 06-17-2015, 01:22 PM   #29
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
One must be skillfully rev matching to keep the gears from chattering too much. Much better for clutchless shifting
What kind of fluid would you use with a dog box rather than a helical box? Or does it matter as long as your using an upgraded fluid from factory?
Old 06-17-2015, 01:32 PM   #30
Koa
Originally Posted by Chad_W View Post
I thought straight cut and synchromesh were exclusive, how does that work?
not mutually exclusive
CDR it's not a dogbox
Originally Posted by bur****jp View Post
I went to the thread. It talks about the symptoms, but doesn't say what actually broke in the transmission. For all we know, it could have been a shift collar, which this gear set wouldn't fix.
Ask @Reaper bro.
Old 06-17-2015, 05:40 PM   #31
RockySDS
Almost ******
Drives: 2014 Subaru BRZ
Originally Posted by crazyfrenchbiker View Post
Well that was quick! When are you installing it?
Right now! This is what it looked like when it was taken apart by the guys at Jacks Transmissions...
RockySDS is offline   Reply With Quote
The Following 4 Users Say Thank You to RockySDS For This Useful Post:
Boris_Petrov (05-01-2019), CxG (10-30-2015), GT86_PRAGUE (06-18-2015), weederr33 (09-05-2015)
Old 06-17-2015, 07:08 PM   #32
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I thought the spines on straight cut gears were called dogs, thus called a dog box because it has straight cut "dog" gears. also having the same characteristic of the loud whine that the gears cause.
The only thing that doesnt fit is that i thought dog boxes were sequential
Old 06-18-2015, 02:15 PM   #33
brianhj
Drives: 2017 Camaro 1SS
"Dog box" just refers to how the gears engage. Dog boxes don't use synchros. Dog boxes can have helical or straight cut gears.
brianhj is offline   Reply With Quote
Old 06-18-2015, 03:33 PM   #34
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Didnt know that, so this is just a straight cut trans gear set? Thx for the clarification
Old 06-18-2015, 03:42 PM   #35
brianhj
Yeah exactly, it's probably more strongly built than stock, also, so it can handle more torque
Old 06-18-2015, 03:45 PM   #36
brianhj
Also, straight cut gears don't produce any "axial loads" which I don't quite understand. Haha. I think that allows for more torque capacity
Old 06-18-2015, 03:52 PM   #37
Koa
Axial load is what it sounds like- load (force) along an axis
Look at the dude's GIF posted a few up. It shows very plainly the load's vector when it comes to a sequential gearset application
The Following User Says Thank You to Koa For This Useful Post:
cdrazic93 (06-18-2015)
Old 06-18-2015, 04:35 PM   #38
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
helical gears literally more surface area for the gears to mesh, thus more area for the load to translate to the axles. Since straight cut gears have less surface area to mesh on, there is less load on the axles. There is however more stress on those dog splines (if shifting wrong its easy to sheer straight cut gears as well), which is a cause of the whine that a lot of people hear with these kind of gears.
The Following User Says Thank You to cdrazic93 For This Useful Post:
Koa (06-19-2015)
Old 06-19-2015, 10:15 AM   #39
Koa
more stress on every component horizontal to the helical spline direction as well- main bearings, main/input shafts etc..
the efficiency of helical gears, all else being equal to spur (or straight cut) gears is less as well- since this load is a sliding contact, the system both projects an axial thrust downstream and generate more heat. Power losses that translate to a less efficient system than if spur gears were used.
Helical gears also need additional supports then as well. Ball bearings alone won't work for most applications of helicals, yet with spurs ball bearings are usually the only required assembly support parts, along with the shafts to mount them of course.
Both are positive-power transmitting members of a mechanical system- unlike belts, these are always engaged
The noise reduction alone is why most manufacturers have gone helical- spur gears are easier to manufacture by a longshot,
The Following 2 Users Say Thank You to Koa For This Useful Post:
cdrazic93 (06-19-2015), jcw99 (03-04-2016)
Old 06-19-2015, 11:14 AM   #40
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
*cracks knuckles* you wanna go Koa? I can do this all day lemme at em, LEMME AT EM!
yeah, basically what he said. I got nothin.
Koa (03-28-2016)
Old 06-19-2015, 11:26 AM   #41
D K
Stig's dark passenger
Spur gears are stronger AND more efficient than helical gears.
The only reason for helical gears to exist is less NVH.
Helical gears are also much more prone to damage from shaft flex than spur gears.
Originally Posted by lamawithonel View Post
It depends...
All else being equal, straight-cut teeth are "weaker" than helical teeth. In a helical gear (diagonal-cut) the teeth gradually come together at the sides, rotating through and gradually lifting at the opposite side. With straight-cut gears the teeth smack into each other all at once. This creates the characteristic whine, but also a lot of shock stress on the teeth. Helical gears also distribute the forces through more material. All else is probably not equal here, though. I'm guessing the alloy and manufacturing process for these are far better than the stock gears.
There's also a trade-off with helical gears as they transmit forces axially (red arrows), putting stress on the bearings and transmission case. Lower angled gears reduce these forces, and straight-cut gears nearly eliminate them. With our boxes, though, AFAIK this hasn't been been an issue. But if the teeth can hold, it's one less thing to worry about down the line.
Anyway, I'm interested to see how these perform. Keep us updated.
D K is offline   Reply With Quote
Old 06-19-2015, 01:02 PM   #42
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
I'm headed to the track tonight, hopefully my trans will make it through the night haha. Looking forward to your results and can't wait for jacks to get my set worked out. I just want a few clean passes before I have to pull this trans
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following User Says Thank You to spitfire481 For This Useful Post:
Koa (06-22-2015)
P&L Headers Arrived today! mrjester FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 8 07-12-2013 05:21 PM
Package Arrived Today zerodark Engine, Exhaust, Transmission 7 04-24-2013 01:32 PM
New England Subaru Allocations arrived at port today ngabdala New England 22 08-15-2012 10:58 PM
My Firestorm arrived today, but the radio didn't Nitro Scion FR-S / Toyota 86 GT86 General Forum 24 06-06-2012 11:45 AM
My SWP BRZ arrived today! (Connecticut) speedracer38 BRZ First-Gen (2012+) — General Topics 19 06-02-2012 09:28 PM
