Old 06-17-2015, 11:15 AM   #15
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
Originally Posted by Packofcrows View Post
dafuq?
Clog somewhere or something? I drive mine till it has around 3-4 gallons left and pump gas. I always pump 9-10 gallons. Reset ECU?
When you pump and it clicks saying its full, check how much more you can put in as 'overfill' but really slow so that if it starts clicking every 2-3 seconds you know it is full and dont spill fuel. I can always add 3/4 gallon or so even after it clicks off.
My gf messed up some emission control stuff (breather valve? some kind of valve) in her Fiest ST by topping off the tank every time she filled up.
I've notcied that my BRZ clicks off around 3/4 gallon from full as well.
So you need to add this to the math as well, so really, if the tank is 12.5 gallons, and you cant fill the gallon almost, not leaving much to actually fill.
I will typical drive about 20 miles after the gas light clicks on, and my car will never take more than ~11.5-12 gallons
GotBRZ1691 is offline   Reply With Quote
The Following User Says Thank You to GotBRZ1691 For This Useful Post:
Clipdat (06-17-2015)
Old 06-17-2015, 12:54 PM   #16
Koa
Originally Posted by extrashaky View Post
You're not supposed to do that. From page 76 of the manual:
● Stop filling the tank after the fuel nozzle automatically clicks off
● Do not top off the fuel tank
Originally Posted by billwot View Post
Bad practice!!
ayy guys why is this a bad practice? I'm too lazy to google (I know, ironic considering I'm the sweeper and all) and want some learnin from my ft86 brahs
Old 06-17-2015, 01:11 PM   #17
ScoobsMcGee
Junior Senior with Cheese
ScoobsMcGee's Avatar
Depending upon which website you believe, it is bad to top off for any of the below reasons:
1) Possibility of fuel spillage
2) If the pump is equipped with a vapor recovery mechanism, you could be increasing the cost while the fuel goes back into the station's tank. This could also damage the station's system.
3) All passenger cars produced after 2000 have an onboard refueling vapor recovery system. (https://en.wikipedia.org/wiki/Onboar...vapor_recovery) Apparently topping off can result in raw fuel getting into a system designed for vapor, causing damage to both it and the engine.
Source: http://www.epa.gov/donttopoff/ (EPA website, powered by Geocities)
RobertPaulson (06-17-2015)
Old 06-17-2015, 01:22 PM   #18
Koa
I hate the EPA! buuut
#1 is definitely what I've witnessed first hand and second.. #2 also didn't think too far into!
Old 06-17-2015, 01:43 PM   #19
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
It was most likely the charcoal canister
Scenic Driver is offline   Reply With Quote
The Following User Says Thank You to Scenic Driver For This Useful Post:
Old 06-17-2015, 01:50 PM   #20
xxscaxx
Drives: 2013 SWP BRZ
Do you still have the stock Purge valve solenoid connected or are you running an EBCS?
xxscaxx is offline   Reply With Quote
Old 06-17-2015, 02:06 PM   #21
GotBRZ1691
GotBRZ1691's Avatar
That or another part of the system @ScoobsMcGee mentioned
Wasn't my car and it was covered under warranty so I didn't look TBH
Old 06-17-2015, 02:16 PM   #22
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
dafuq?
Bad practice!!
@Packofcrows listen to these guys thats a stupid practice it's called "topping it off" and I'm not sure how you haven't seen signs everywhere near the pump saying not to do that
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Koa (06-17-2015)
Old 06-17-2015, 04:05 PM   #23
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by Simisimi View Post
Only other thing to mention is that my Port Injection fuel pump was replaced with a bigger unit when I went from 7 to just over 9PSI boost. Not sure that would be involved but it's in that area. Help!
Ding ding ding. It could be a shorter aftermarket pump so the pickup is not sitting as low in the tank as the OEM pump and thus you no longer have access to that fuel at the bottom of the tank.
Old 06-17-2015, 04:30 PM   #24
tyrantcf
Drives: '16 WRX, CBR1000RR
^^thats it.
#firstworldproblems
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
tyrantcf is offline   Reply With Quote
Old 06-17-2015, 06:11 PM   #25
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Don't get angry. I was merely wondering if it (op's car) is taking what the tank is capable of or near.
11.5 Gallons as op stated means there's more or less room for 2 gallons. If he was at 2 gallons or so, he shouldn't have gone oog(out of gas). Thus, I was wondering if this problem was unique to him?
For the book, I do not advocate for topping off. Nor for letting your gas tank reach "E." Once I am bit bellow 1/4 I pump.
Old 06-17-2015, 06:13 PM   #26
FRSBRZGT86FAN
Not being angry lol
Sent from my A0001 using Tapatalk
Packofcrows (06-17-2015)
Old 06-17-2015, 06:14 PM   #27
Packofcrows
Not being angry lol
Beer time then. I'll drink one for you.
Old 06-17-2015, 06:22 PM   #28
FRSBRZGT86FAN
No biggie lol
Stock In-Tank Fuel Filter Degradation sw20kosh Engine, Exhaust, Transmission 96 07-28-2014 03:36 AM
Fuel gauge misreading actual fuel in tank. Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 19 10-09-2013 03:39 PM
AEM High Flow In-Tank Fuel Pump JPxM0Dz Engine, Exhaust, Transmission 0 04-13-2013 12:15 PM
“saddle-shaped” fuel tank ft86Fan Engine, Exhaust, Transmission 13 06-26-2012 04:22 AM
