Old 03-30-2015, 11:32 PM   #169
Originally Posted by tazz786 View Post
so the slight vibration is normal? i dont use my car for the track just a daily driver..i feel it when im pulling my car out of the driveway
Yup. Perfectly normal. When the engine is applying torque to accelerate, the rear wheels resist rotating at different speeds, hence the term "limited slip."
When operating at steady speed or coasting, it behaves just like an open diff.
This is my first car with one. I got a big shit-eating grin when I first noticed it because it feels just like my brother's 911.
Old 05-05-2015, 12:06 PM   #170
Jhood
Jhood's Avatar
Drives: 2014 BRZ Limited [6MT/SWP]
Finally changed mine out, dealership told me with a straight face "oh the BRZ is supposed to feel that way when shifting, it's notoriously notchy.. it's a brand new car I can assure you that it doesn't have any metal flakes in it already." I think I might send these over.
Jhood is offline   Reply With Quote
Old 06-12-2015, 06:20 PM   #171
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
For reference, here are my drain plugs at 7400 miles. Pretty dirty for a break in. Guy next to me with a ZL1 Camaro was pretty shocked, but said every manufacturer is different. Hope so.
Sent from my SCH-I545 using Tapatalk
DoomsdayJesus is offline   Reply With Quote
Old 06-12-2015, 06:21 PM   #172
DoomsdayJesus
Whoops forgot to attach the photos.
Old 06-17-2015, 02:34 PM   #173
DarkSunrise
DarkSunrise's Avatar
Thanks for the writeup! Changed out my diff and transmission fluid using Motul 300. My transmission took 2.3 L and my rear differential took 1.1 L.
The new fluid feels thinner. I get more sensation through the shifter. Also makes the transmission less notchy when cold. When warm, it's not too much of a difference and I still get an occasional grind into 3rd/5th.
Haven't noticed a difference with the rear diff fluid, but will see after my next track day.
2022 BRZ Build
2013 FR-S Build
Old 07-11-2015, 01:38 PM   #174
AlexTheGreek
AlexTheGreek's Avatar
Drives: BRZ Premium Black
DIY - Transmission / Diff Fluid Change Reference Guide
Ordered 4x Motul 300 75w90 from NoLimitMotorsport. Came with the rear diff crush washers!!! Thx LJ. (Also 2x cuzies and 2x parachute men lol)
Here is what the drain bolt looked like. Car is 35k mi.
Here is what the tranny drain bolt looked like:
Attachment 115053
I reused the washers. Flipped them.
AlexTheGreek is offline   Reply With Quote
Old 09-07-2015, 06:08 PM   #175
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
30,000 kms, did both trans and diff (motul for diff, pentosin for trans) - worked great thanks to the excellent walk-thru. My plugs looked like the ones above - full of crud.
Khyron686 is offline   Reply With Quote
Old 10-06-2015, 05:03 PM   #176
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
Is someone able to explain or post a pic of filling Trans from above car instead of while underneath? I assume you don't drop the fill hose through the body somewhere and just rely on gravity over any incline in hose angle to fill hole?
I usually pull shifter assembly for filling up tranny in my other car lol. Eff those nozzle deals...
Thx
Toyarzee is offline   Reply With Quote
Old 10-06-2015, 05:32 PM   #177
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
Thx
If your hose is long enough, as long as the source (bottle) is higher than the destination (fill hole) gravity will do its job.
aegisdrgn is offline   Reply With Quote
Old 10-08-2015, 11:53 AM   #178
StinkyLinky8
Drives: Subaru BRZ Limited
Crush washers
Does anyone know where I can pick up (prefer to order online) the crush washers needed for this job?
Maybe some part numbers? I'm hoping I could just pick them up from the Napa around the corner but prefer to have a part number on hand.
Also, is there any difference between the Oil pan crush washer/Trans/Diff crush washers?
StinkyLinky8 is offline   Reply With Quote
Old 10-08-2015, 12:07 PM   #179
Toyarzee
Shibby!
Toyarzee's Avatar
Yes they are different and part numbers listed earlier in this thread
Old 11-05-2015, 05:16 PM   #180
scionfr_s
scionfr_s's Avatar
Drives: Scion FR-S
So for an auto tran, u need 7.5L of ATF and 1.2L of differential fluid?
scionfr_s is offline   Reply With Quote
Old 11-13-2015, 06:39 PM   #181
Mikeez
Engineering Student
Drives: Scion FR-S 2015
Can't I use Allen key instead of the hex bit socket??
There’s no time to stop for gas, we’re already late
Mikeez is offline   Reply With Quote
Old 11-13-2015, 06:56 PM   #182
aegisdrgn
aegisdrgn's Avatar
Of course you can use Allen keys to loosen it, if you have the confidence in breaking those bolts loose with stubby Allen keys. But to tighten it, unless your hand and arm is an biological torque wrench, kinda hard to tighten to proper torque specs.
Do it right, with the right tools so you don't regret it later.
differential, diy, fluid, transmission
Transmission fluid swap? flawedchemical Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 48 09-12-2014 02:23 PM
What Differential fluid is in your BRZ/FRS? ft86Fan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 11-12-2012 08:57 PM
Anyone change transmission lube yet? BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 08-21-2012 05:47 AM
FR-S quick reference and warranty / maintenance guide is up pkny Scion FR-S / Toyota 86 GT86 General Forum 15 06-20-2012 11:33 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
