Old 06-17-2015, 02:47 PM   #43
CSG Mike
CSG Mike's Avatar
Originally Posted by enivid View Post
I'm wondering this as well. How do I tell where I'm engaging ABS when looking at the logs?
You'll see your wheel speed spike downward (when the wheel is momentarily locked up), and then spike back upwaard to your approximate GPS speed.
Old 06-18-2015, 06:33 PM   #44
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
I don't have a file in front of me to try this out on, but have you tried creating a math channel and looking at the rate of change of your brake pressure? I created one called "dBrakePres" with the equation deriv(TOYO_BRAKE_PREX) and it pretty clearly shows how hard I hit the brakes each time. That may highlight an obvious difference between your braking, and ABS braking.
Jake
GSpeed is offline   Reply With Quote
Old 06-19-2015, 10:03 AM   #45
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
I think this was covered before in another thread, but I can't find it.
when pedal position is at 100%, throttle reads at 96%
any idea why that is?
Old 07-01-2015, 08:08 PM   #46
jdp530
Drives: 2014 BRZ
How can I shift or adjust time for laps so that each lay overlays the other? Looks like they are off slightly.
BTW, I did find a way to change 'units of measure' in software. Logger was set to read in standard measurements (psi, F) but data in RS2 was still showing in metric. It can be changed in program.
jdp530 is offline   Reply With Quote
The Following User Says Thank You to jdp530 For This Useful Post:
CSG Mike (07-02-2015)
Old 07-01-2015, 11:01 PM   #47
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Is GPS>Runs Aligned checked?
The Following User Says Thank You to GSpeed For This Useful Post:
Old 07-02-2015, 08:42 PM   #48
jdp530
Drives: 2014 BRZ
PST, I have checked for that. I will look later, but last night at our club meeting someone clicked the 'snap' button and it expanded the time line for all three laps and it was easy to drag the time line for each lap and line them up together.
Old 07-02-2015, 08:48 PM   #49
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Okay, I was going to suggest that next, but I wasn't sure exactly what the issue was. I'm glad you figured it out!
Jake
Old 07-02-2015, 09:40 PM   #50
enivid
enivid's Avatar
Drives: WRB JR BRZED
On the lap manager tab, click the GPS Lap Insert button to align the sessions. I "think" that is how you're supposed to do it.
enivid is offline   Reply With Quote
Old 07-14-2015, 06:51 AM   #51
Alan
Alan's Avatar
Drives: 2013 SWP BRZ Ltd. / E60 M5
Would mounting the Solo DL with this give adequate signal reception? I don't want to use a Ram mount as some groups don't allow suction cups.
http://www.proclipusa.com/dashboard-...812-19052.cmsv
2013 BRZ Limited | SWP | Verus Ventus 1 and High-Efficiency Rear Wing | Invidia N1 Ti | JR Oil Cooler | RCE T2 | RaceSeng Cas/Cam | SPL LCA & TA | Wilwood/RR Racing Stage II/Sport Performance | XP10 | Apex ARC-8 | Toyo R888R | 245/40-17 | Sparco Ergo II/Evo II | AIM MXP | SmartyCam GP HD 2.2
Alan is offline   Reply With Quote
Old 07-14-2015, 01:40 PM   #52
CSG Mike
CSG Mike's Avatar
Yes.
Make sure when you power it on, you give it clear signal of the sky to "lock on", and then place it there using the magnetic mounts.
Alan (07-14-2015)
Old 07-19-2015, 05:05 PM   #53
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Originally Posted by ubernostrum View Post
Is it possible for the SoloDL to indicate when ABS is engaging? Either on the unit itself or afterwards when reviewing the data in RaceStudio? The documentation says it does not pull the ABS activation channel for our car like it does with the Miata, but can it be inferred by the brake pressure channel?
This problem has been bothering me for a while now. I think I figured out a method using the OBD wheel speed sensors and brake pressure. Simpler methods like derivatives of wheel speeds and brake pressure didn't work well enough on their own, but when you combine the two, you get a useful output. I detailed it here, with the formulas I used. I'd love to hear if it works for you guys too.
http://www.ft86club.com/forums/showt...41#post2326641
Old 01-17-2016, 10:07 PM   #54
TCR
Drives: 2013 Toyota 86 GT
Hi guys, quick question.
I'm currently using the Torque Pro App to monitor my oil and water temps on track, but would like to use a data logger as well. Can the Solo DL be configured to display oil and water temps as well as lap times/predictive times at the same time or via scrolling screens?
TCR is offline   Reply With Quote
Old 01-17-2016, 10:41 PM   #55
kster1
kster1's Avatar
Yes, this is supported. I have my screen customized to show: lap time, predictive lap time and oil temp.
kster1 is offline   Reply With Quote
The Following User Says Thank You to kster1 For This Useful Post:
TCR (01-17-2016)
Old 01-17-2016, 11:02 PM   #56
TCR
Great, thanks.
Is all the info on one screen or is it shown on different screens that scroll?
2014 SCCA Solo Nationals/Pro Solo Finale thread edj Tracking / Autocross / HPDE / Drifting 206 09-19-2014 12:34 PM
SCCA Socal Solo 2 at El Toro, Socal, 3/22-23, noob questions JB86'd Tracking / Autocross / HPDE / Drifting 52 03-29-2014 05:00 AM
Wax Sealant Pad Questions / Care Questions l0aded Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 03-25-2014 12:19 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 09:08 AM
