Old 06-17-2015, 01:23 AM   #2003
SilverlightPony
SilverlightPony's Avatar
Drives: '13 Subaru BRZ, '06 Toyota 4Runner
Lots of us run Waze on this. Just keep in mind, you need a mobile data connection of some sort (aircard, hotspot, or phone w/ hotspot capability) in order for Waze to work.
SilverlightPony is offline   Reply With Quote
The Following 2 Users Say Thank You to SilverlightPony For This Useful Post:
Khánh (06-18-2015), Pwolf (06-17-2015)
Old 06-17-2015, 01:24 AM   #2004
Pwolf
Pwolf's Avatar
Drives: 2013 GBS BRZ Limited
Yes. Works great.
Pwolf is offline   Reply With Quote
Old 06-17-2015, 05:07 AM   #2005
petr
Drives: Mazda Miata
Coming back to that solution http://ca-fi.com/forum/viewtopic.php...013fdd95#p5084
Is there a way to edit "file "multi_navi_config" in the "manufactorycfg" map" without reflashing FW? I found factory.prop somewhere in filesystem, but editing it didn't make the trick.
petr is offline   Reply With Quote
Old 06-17-2015, 06:15 AM   #2006
SilverlightPony
Probably not.
Old 06-18-2015, 06:42 PM   #2007
shadoken
shadoken's Avatar
Drives: FRS RS 1.0
I thought Waze allows you to download the Maps onto the phone? Or was that Google Maps?
shadoken is offline   Reply With Quote
Old 06-18-2015, 06:55 PM   #2008
Pwolf
Pwolf's Avatar
You can download your route via wifi first then drive off but you lose some features, obviously.
Old 06-18-2015, 08:53 PM   #2009
SilverlightPony
Waze does store map chunks locally, but it's still intended to be run with a mostly-constant data connection (for its social features, among other things), and will throw a fit if goes to long without one.
Old 06-19-2015, 06:15 AM   #2010
Tareim
Drives: 2013 Subaru BRZ
Originally Posted by burmjeff View Post
I saw you guys were having trouble with getting write permissions with root so I spent some time to make a rooted stock rom (3/18 update). I don't have this unit anymore so I can't test to see if it works but feel free to try it and let the others know if it works
http://burmjeff.com/dashlinq4-rom/
I tried this one the other day and it just stayed on the splash screen and wouldn't proceed any further, luckily I was able to flash another rooted firmware on but that seems to be buggy and I want to go back to a stable official build, can I ask how you rooted it so I can then root a stock image myself
Tareim is offline   Reply With Quote
The Following 2 Users Say Thank You to Tareim For This Useful Post:
Calum (06-19-2015), petr (06-25-2015)
Old 06-19-2015, 08:30 AM   #2011
Calum
That Guy
Drives: 2013 asphalt FRS MT
With a rooted firmware can you change the icons on the carhome screen? This is one of the few things about the system that bugs me, all of the unsed icons and being almost forced to use the stock music player.
Old 06-19-2015, 08:44 AM   #2012
Tareim
I've not played around with it too much on root but I tried deleting some of the standard apps such as the swc but it wouldn't let me so just moved it along to the end where I wont see it
The Following User Says Thank You to Tareim For This Useful Post:
Calum (06-19-2015)
Old 06-22-2015, 11:50 PM   #2013
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
What I said was based on reading articles on TheVerge and AndroidCentral.com. I would like to see your sources, please.
You're misinterpreting whatever you read, I promise. Here's a couple of links from those two sites, and another one, all of which clearly state that Android Auto is not an OS and runs on top of your car's existing OS.
http://www.theverge.com/2015/5/26/86...hyundai-sonata
http://www.androidcentral.com/android-auto
http://www.wired.com/2014/06/android-auto/
Those links don't specifically state that Android Auto runs on QNX, so here: http://www.androidheadlines.com/2015...roid-auto.html Note here that it isn't stated that Android Auto doesn't run on Android, only that it most likely is running on QNX.
Another link showing that Android Auto runs on QNX: http://www.androidcentral.com/audi-c...-vehicles-2015
Also just for kicks, here's the Parrot RNB6, announced at CES this year: http://www.engadget.com/2015/01/04/p...apple-carplay/ It's an Android head unit like ours that has Android Auto and CarPlay build in. Not sure how they got CarPlay in there, but Android Auto runs on Android, so at least that makes sense.
Prog is offline   Reply With Quote
Old 06-23-2015, 12:51 AM   #2014
phanguy
phanguy's Avatar
Drives: Scion FR-S Ultramarine
No, but really, solid links!
phanguy is offline   Reply With Quote
The Following 2 Users Say Thank You to phanguy For This Useful Post:
Prog (06-24-2015), Pwolf (06-23-2015)
Old 06-23-2015, 01:38 AM   #2015
SilverlightPony
Um... "it's not a stand alone os, it's an app" is what I've been saying.
Old 06-23-2015, 01:45 AM   #2016
Kevinn
Drives: 2014 BRZ Limited, Black, Manual
Sounds like something that could be side loaded anyway.
Kevinn is offline   Reply With Quote
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 06:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 03:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 04:58 AM
