Old 06-16-2015, 04:20 PM   #1513
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
300whp is so hard to define because every dyno reads differently.
3" exhaust from downpipe back, no catalytic converters, and 13psi netted me 305whp last month, with a dyno that reads low 150ish whp on a stock BRZ.
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 06-16-2015, 07:23 PM   #1514
slyphen
Drives: Man
Send a message via AIM to slyphen Send a message via Yahoo to slyphen
hm. according to bob from drift office, he told me i can get about 330+ with 2.5" running on E85, which is why i wonder if 300 can be achieved using 92 oct. 3" is also louder, not sure if i want that as a DD. whats the highest you guys have gotten with 2.5 so far?
slyphen is offline   Reply With Quote
Old 06-16-2015, 08:02 PM   #1515
Astroboy
Astroboy's Avatar
Drives: None
Would you be needing upgraded fuel injectors if I want to exceed 300whp?
Sent from my LG-D850 using Tapatalk
Astroboy is offline   Reply With Quote
Old 06-16-2015, 09:52 PM   #1516
kbogarto
Drives: 2013 BRZ limited WRB
Yes, and probably clutch too
92 240sx (sold), 03 350z (sold), 13 BRZ (AVO turbo)
kbogarto is offline   Reply With Quote
Old 06-16-2015, 10:00 PM   #1517
Astroboy
Astroboy's Avatar
Drives: None
Will that be all, besides the e85?
Old 06-17-2015, 01:59 PM   #1518
kbogarto
you would need an e85 tune too.
Old 06-17-2015, 02:57 PM   #1519
Dammod
Dammod's Avatar
Drives: .
Hey guys,
Just a quick message to let you know that we are in the process of tuning a AVO turbo kit we have fitted to a car down here in Cape Town, South Africa.
This turbo kit is really stretching far and wide across the world and I'm not surprised, it really is a seriously well thought out piece of kit!
Instillation was pretty straight forward with the main hiccup being a slightly warped flange on the STOCK exhaust which I seem to have sorted out.
We don't have the best fuel down here (worse then cal 91 in comparison), the car made a 120fkw in stock form - I'll be posting up the results for the FI build once tuning is done - tune is currently being made from scratch.
"Some will follow your footsteps, easier than they will your advice."
Dammod is offline   Reply With Quote
Old 06-17-2015, 03:01 PM   #1520
surfuxalot
Drives: Toyota Frs
hey just wondering, is this kit with factory ecutune carb approved?
Thanks
surfuxalot is offline   Reply With Quote
Old 06-17-2015, 04:44 PM   #1521
AVOturboworld
Thanks
No, we cannot get any CARB approval on any kit that modifies or removes the two catalytic converters in any way. While you can retain the standard secondary cat, the primary gets replaced by the turbocharger and exhaust manifold.
Old 06-17-2015, 05:10 PM   #1522
surfuxalot
Drives: Toyota Frs
Old 06-18-2015, 02:00 AM   #1523
Fastbrew
Drives: 2014 Pearl White BRZ
You might get 260 or so on a 2.5" exhaust running 92 and a safe tune at around 8-9psi. But - not all 2.5" systems are really 2.5" either. Nameless comes to mind since I have one sitting in a box in my garage after replacing it
Fastbrew is offline   Reply With Quote
Old 06-19-2015, 08:21 PM   #1524
Astroboy
Astroboy's Avatar
Drives: None
Anybody had any issue fitting the inlet tube onto the the turbo intake? Mine is apparently coming off. I guess from after extended use. Just wondering if anybody had the same issue
Old 06-20-2015, 12:04 AM   #1525
kbogarto
Yea mine never fit flush but since it sees no pressure I just got it as good as I could and monitor it to make sure it doesn't move. If you climb under the car and push up on it you might be able to push it back on and then tighten down the clamp.
Old 06-20-2015, 09:29 PM   #1526
Astroboy
Astroboy's Avatar
Drives: None
I tried that today, and unfortunately the tube slid out a little after tightening the tube back up -___-
I'll try using a different clamp
avo, avoturboworld
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
