go_a_way1
Old 06-13-2015, 07:04 PM   #2801
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by Campo View Post
what would the etc be? I'm a research junky and love to see all the options...
http://www.ft86club.com/forums/showthread.php?t=82041
RE71R and the Rivals are the two new hot tires, designed to compete and win SCCA Autocross competitions, there's some skepticism that they're actually 200 treadwear rating and will hold up to prolonged street use because they are very aggressive sticky compounds.
I suppose Dunlop Direzza ZII and Hankook RS3 may also fall into that category as they are still doing well, they're on the edge of what could be considered a street tire although the Direzza's have a decent rep for durability, I've heard they're commonly chosen for some endurance racing and spec Miata.
ineedyourdiddly
Old 06-13-2015, 10:32 PM   #2802
CSG Mike
CSG Mike's Avatar
Originally Posted by Teseo View Post
Standing water and ponds, sorry for not being clear
I'd recommend you stick to an all-season tire of your choice.
This is not my area of expertise, as I don't normally try to drive fast through large amounts of standing water.
Teseo (06-13-2015)
Old 06-13-2015, 10:32 PM   #2803
CSG Mike
CSG Mike's Avatar
Rivals and Rival-S refer to two *different* tires.
strat61caster (06-14-2015)
Old 06-13-2015, 10:33 PM   #2804
CSG Mike
CSG Mike's Avatar
595RSRR; the other tires are not readily available in the states, which preclude them from any sort of competition, as well as the general pubilc.
Old 06-13-2015, 10:42 PM   #2805
Teseo
Drives: frs
You should, put life in perspective.
The Following User Says Thank You to Teseo For This Useful Post:
Old 06-14-2015, 08:41 AM   #2806
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
That's what boats are for.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
The Following User Says Thank You to Deep Six For This Useful Post:
DocWalt (06-14-2015)
Old 06-14-2015, 09:01 PM   #2807
Campo
Campo's Avatar
Drives:
225/45/17 RE11A
If I'm using these strictly for the track is there any benefit to going with a 40 series instead of 45?
My transmission is automagic so I have taller gearing and have not decided if/when I'll change the final drive. (I know it's pretty track specific when you get good, but I'm not that good yet. )
I'm just thinking of sidewall stiffness vs roll and if there is any benefit to going shorter since I won't be on the street with these.
"Fuck, you've gone completely sideways, man."
~Raoul Duke
Gas is pretty cheap considering you're buying liquid explosive dinosaurs.
Campo is offline   Reply With Quote
Old 06-14-2015, 09:49 PM   #2808
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
Talking about wet track, which tires is "most" usefull in the wet condition?
I have ran my Michelin Pilot Sport A/S 3's in just about every wet condition (on @CSG Mike scale) damp -> lakes and they have performed flawlessly. They have similar dry grip to a PSS but much better wet traction. They are new tire tech.
Mine are 245/40ZR17 on 17x9. Skinnier tires may perform even better in the wet.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
The Following User Says Thank You to zdr93523 For This Useful Post:
Teseo (06-14-2015)
Old 06-14-2015, 11:28 PM   #2809
CSG Mike
CSG Mike's Avatar
For 225? Shorter gearing
Old 06-16-2015, 06:16 PM   #2810
superpenguin
Some Random
superpenguin's Avatar
Drives: 2015 FRS
There's a track day tomorrow. It's going to be 115 degrees. I don't have any cooling mods. Should I sign up or skip this one?
"You see, nursie, men love women. But even more than that, men...LOVE...CARS!" - Rush
2015 FRS NASA AZ #550
superpenguin is offline   Reply With Quote
Old 06-16-2015, 06:21 PM   #2811
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
What mods? What skill level? Doesn't NASA AZ run their events at night?
Mike
AZP Installs is offline   Reply With Quote
Old 06-16-2015, 06:24 PM   #2812
superpenguin
Some Random
Drives: 2015 FRS
Mike
It's an SCCA event, starting at ~ 4pm. I did one last month and it was super. My question was more geared towards the oil cooling issues with the FRS vs. the super high track temps. Last month it was around 80 degrees.
Old 06-16-2015, 06:39 PM   #2813
CSG Mike
CSG Mike's Avatar
If you're pretty new you'll be ok. If you're experienced, you should get an oil cooler...
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
AZP Installs (06-16-2015), PWBRZ (06-17-2015), WillRacer1jz (06-17-2015)
Old 06-16-2015, 06:41 PM   #2814
superpenguin
Some Random
Drives: 2015 FRS
Ha! Don't think it'd get here in time for the event tomorrow. I'll wait til it cools off a bit
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 07:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 01:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 08:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 08:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 10:54 AM
