Old 06-07-2015, 08:02 AM   #183
cab33
Drives: Fast
Where can you find CL brake pads?
cab33 is offline   Reply With Quote
Old 06-08-2015, 09:59 AM   #184
JozhGoober
Drives: 2020 718 GT4, 2013 FR-S (Turbo)
Try Essex: http://www.essexparts.com/
JozhGoober is offline   Reply With Quote
Old 06-15-2015, 03:35 PM   #185
DarkSunrise
DarkSunrise's Avatar
Originally Posted by BRZZZZZZZZZZ View Post
I've got some Project MU HC+ on order, I don't see many people if any posting how they like them so far, anyone else have anything to chime in with?
I just went through a set of HC800+. Only lasted 4 track days before my front pads were worn down to this:
I wasn't too happy with them to be honest. They may actually have less hot bite than my old cheap Stoptech pads. The only good thing is they didn't fade as bad through a 20 min session.
2022 BRZ Build
2013 FR-S Build
Old 06-15-2015, 10:55 PM   #186
Sleepless
Drives: 2016 FR-S
I've read through this thread, what's a good set up that works for both... a daily driver and trackdays?
Realistically, there is no such pad if you are past novice level track driving.
The pads are so easy to change on these cars; get separate pads for street and track.
Sleepless is offline   Reply With Quote
Old 06-16-2015, 10:10 AM   #187
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
I haven't had a chance to try mine yet, July 1st will be my first day out this year. At least I got mine cheap I guess...
BRZZZZZZZZZZ is offline   Reply With Quote
Old 06-16-2015, 11:16 AM   #188
DarkSunrise
Yeah I'm curious what you'll think of them. My expectations might have been too high for a street/track hybrid pad, but I was definitely surprised they wore like that after 4 days.
2022 BRZ Build
2013 FR-S Build
Old 06-16-2015, 11:37 AM   #189
BRZZZZZZZZZZ
Car Nut
If they don't go well, Ill probably finally go BBK over winter if it doesn't go well. I don't want to lose my fog lights so cooling is tough.
Old 06-16-2015, 11:58 AM   #190
OkieSnuffBox
Drives: '23 BRZ Limited
TF duct kit doesn't use the fog lights and has better backing plates than the APR setup. Although I don't like the way ducts look in the grill.
Old 06-16-2015, 12:02 PM   #191
BRZZZZZZZZZZ
Car Nut
Not sure how well it will fit with my intercooler and oil cooler.
Old 06-16-2015, 12:04 PM   #192
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
The ducts are discrete, at least they appear to be in my car. You wont notice them unless youre intentionally looking for them. I went the way and added some copper mesh to keep residue out; even the mesh is hard to see through the grille. You'll forget about them
. ck
|| My Build Thread ||
ck-GT86 is offline   Reply With Quote
Old 06-16-2015, 01:09 PM   #193
CSG David
CSG David's Avatar
Hybrid pads are generally meant to be used for absolute noobs. You're not a noob anymore so get some pads designed and engineered for your specific application. We've been preaching this for years and we have many converts...mostly from just telling people to try it out.
If you haven't worked with proper track pads, don't discuss BBK. BBK works, but if you use them incorrectly, your braking distances are increases despite having less fade issues. This is actually a repeatable observable occurrence which seems to be overlooked.
Brake ducting is a popular subject and should not be overused. Some pads like heat and some don't.
Old 06-16-2015, 01:11 PM   #194
BRZZZZZZZZZZ
Car Nut
I've used proper stuff before but not on this platform, previously on other vehicles. I have all sorts of limitations I am trying to work around on this car and there's no perfect solutions.
Old 06-16-2015, 01:15 PM   #195
CSG David
CSG David's Avatar
Solely dependent on your application and your setup. Boost + road course tells me these pads should not survive. Some people make it happen, but that also tells me that they are sandbagging their pace.
Old 06-16-2015, 01:17 PM   #196
BRZZZZZZZZZZ
Car Nut
Sadly this car was never meant to be lapped after I got my Miata but now that I have realized I am too tall to pass the broomstick test even with a modded seat this is all I have
If I had more time I could have figured something out but I only have two weeks now and I just realized last week I am screwed.
Anime Discussion Thread ERA Off-Topic Lounge [WARNING: NO POLITICS] 2698 02-14-2024 11:55 PM
Gundam Universe - General All Discussion Thread poormans_LFA Off-Topic Lounge [WARNING: NO POLITICS] 273 03-23-2014 11:45 PM
S2000 vs BRZ at the track: track oriented discussion CSG Mike Tracking / Autocross / HPDE / Drifting 33 01-13-2013 06:54 PM
Track/Racing Discussion Allch Chcar Tracking / Autocross / HPDE / Drifting 9 05-26-2012 04:39 PM
Forza 3 vs. GT5 Discussion Thread Snaps Off-Topic Lounge [WARNING: NO POLITICS] 386 03-06-2011 12:10 AM
