Old 05-19-2015, 11:41 AM   #57
Byrd
Drives: 2013 BRZ Limited
"If you want more than about 35-40 wheel horsepower gain then your going to need to go Forced Induction FI either Turbo or Supercharger, just skip NA mods "
Thats weird to me... Who gets FI with stock exhaust / no E85 / no tune? All NA mods are perfect add-ons to FI and should be first in the build.. except for the Perrin inlets and pulleys the FI replaces
Byrd is offline   Reply With Quote
The Following User Says Thank You to Byrd For This Useful Post:
Strife26 (11-07-2015)
Old 05-19-2015, 12:03 PM   #58
Thatguyjeremy
Drives: 13' Asphalt FRS
@steve99 been contemplating about the Perrin cold air intake. Would I have to adjust anything with my tune, or should it be "ok" ?
IG: __thatguyjeremy
Thatguyjeremy is offline   Reply With Quote
Old 05-19-2015, 12:03 PM   #59
steve99
Drives: FT86
most turbo kits require different header than used for NA
Yes you could re-use most NA header for supercharger except maybe Nameless or PLM header
most turbo kits and many supercharger kits don't use stock intake or require a different intake setup than you would use when NA , to fit turbo or supercharger and/or drive belts pullys ect.
A lot of people move from OFT/tactrix/brzedit tune system to Ecutek when they go FI as its the only system that supports flex fuel at present and most FI tuners use ecutek.
Unless your using the OFT SBD specific FI kits
Many will upgrade to 3" exhaust components on high output turbo setups, where 2.5' is suffient for NA and also keeps noise/rasp levels down NA, turbo's are great mufflers.
Old 05-19-2015, 12:08 PM   #60
steve99
Drives: FT86
The 2.5" perrin intake is fairly close to stock maf scaling, but would benefit from custom scaling for best results
The 3" big maf definitely requires maf rescale to be safe.
honestly if you NA then leave intake stock , just a drop in filter will get most of the gains you can get from an entire intake without the associated hassles.
Old 05-19-2015, 12:29 PM   #61
Byrd
Thanks for the info man! Personally im staying NA & If I ever decide to go the FI route (supercharger) I'll be okay because Im getting all NA mods you listed except for a header. I enjoy my current exhaust setup too much to change it up
Old 05-26-2015, 09:32 PM   #62
zach597
Drives: 2013 scion fr-s
Preferred - aem tuned intake or grimmspeed?
zach597 is offline   Reply With Quote
Old 05-28-2015, 12:15 AM   #63
steve99
Drives: FT86
Their is not much power in intakes, the grimspeed will work well as its wont require maf scaling
Old 05-28-2015, 12:40 AM   #64
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Nice job steve!
Old 05-28-2015, 12:41 AM   #65
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
If anything the supercharger is the best FI option to keep it feeling like stock, dont forget about the electric supercharger either. Always a good alternative if someone wants right on that edge between NA and FI hp.
Old 06-07-2015, 07:42 PM   #66
isolato
Drives: 2015 Subaru BRZ; 2001 Mazda Miata
Major props for this thread! This will be very helpful. Thank you!
isolato is offline   Reply With Quote
Old 06-15-2015, 03:25 PM   #67
Canehda
poverty cause racecar
Canehda's Avatar
Drives: Subaru BRZ JRSC'd
I'm interested in whether or not properly deleting the cat in the stock headers would produce most if not all of the gains as some of the major third party company's headers... I have a turbo kit on order and wouldn't mind deleting the cat and playing with stage 2 before I go boost but I don't feel like spending a fortune to do so :P
Ive also notice that there is a single digit percent difference between the "unequal-ness" of the ft86speedfactory header vs stock... would I then use the Stage 2 UEL or Stage 2 EL file?
Canehda is offline   Reply With Quote
Old 06-15-2015, 03:41 PM   #68
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
The stock header lacks the proper collector and scavenging that the aftermarket ones do so it will limit your power. It's built for economy (cheap), not necessarily performance.
If you're going turbo, you'll already have a manifold as most of them all come with one or you'll need a turbo compatible one.
You won't want a cat in the header if you're turbo. It will get burned up pretty quick. You'll also want EL especially if going turbo. The difference on N/A is pretty minor with torque response in different areas, but turbo you'll start to see the gap between UEL and EL.
2016 Camaro SS is offline   Reply With Quote
Old 06-16-2015, 07:56 AM   #69
steve99
Drives: FT86
see perrin post here the stock header was better without cat but not as good as aftermarket catless headers
http://www.ft86club.com/forums/showthread.php?t=13991
The Following 2 Users Say Thank You to steve99 For This Useful Post:
86 South Africa (10-16-2015), raven1231 (06-16-2015)
Old 06-16-2015, 08:04 AM   #70
raven1231
This and you would want to run the EL tune.
Useful/Frequent mods: a BRZ/FRS/GT-86 basic ! Simon99 BRZ First-Gen (2012+) — General Topics 104 10-10-2016 12:45 PM
What mods next? Exhaust? Intake? Ludacrits Scion FR-S / Toyota 86 GT86 General Forum 7 09-05-2013 08:25 PM
Question about basic performance mods bdanisi Engine, Exhaust, Transmission 2 01-25-2013 05:40 PM
