Old 06-11-2015, 01:55 AM   #57
D K
Stig's dark passenger
Originally Posted by Sammakko View Post
back in the day, timing CHAIN vehicles
By highlghting chain, are you referring to the fa20 as a timing belt engine?
D K is offline   Reply With Quote
Old 06-11-2015, 01:56 AM   #58
Sammakko
Bilge monkey
Sammakko's Avatar
Drives: '13 BRZ, 82 starlet
Originally Posted by HaDDeS View Post
there is no reason to worry about the head gasket.
it seemed super important a few posts back.. i.e.. different cams per head gasket change..
Sammakko is offline   Reply With Quote
Old 06-11-2015, 01:58 AM   #59
Sammakko
Bilge monkey
Sammakko's Avatar
no. i'm referring to many engines in the past who still used a chain..
chains have very low resolution, accuracy-wise. less room for adjustment in length vs belts. belts can be more accurate because there are fewer teeth per inch, per say. there are some very reliable chain engines, but they're being phased out.
Old 06-11-2015, 02:06 AM   #60
Sammakko
Bilge monkey
Sammakko's Avatar
Tweak means what it means
Old 06-11-2015, 02:12 AM   #61
stugray
Drives: 2013 GBS BRZ Limited
So you dont care that you are advancing the cam timing on one side and retarding it on the other side?
A quick back of napkin SWAG says that the difference between a .5mm & 1mm head gasket is less than half a degree per cam gear.
Do you honestly think these cams are capable of controlling to within less than 1 degree when under VVT control?
And if your answer is yes, then wouldnt the VVT system compensate for it anyway without tuning??
Old 06-11-2015, 02:15 AM   #62
D K
This is another point missed....
It has nothing to do with accuracy or resolution.
Do you know what happens when you have 2 heads 180 degrees from eachother and you bring them closer to the crankshaft with a fixed length chain?????
Go ask a qualified Porsche race technician and tell them you have this bright idea of changing headgsket thickness.....
Let me know what he says lol
Old 06-11-2015, 02:17 AM   #63
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
From the home page of this forum there are, at this point in time, 5,149 threads in the Engine,Exhaust,Transmission thread. The next most popular section is Cosmetic Modification with 5,037 threads. Cosmetics ffs!!! I'd better get over there and tell all those people they are wasting their time and money.
The Following 2 Users Say Thank You to Captain Snooze For This Useful Post:
fika84 (06-11-2015), themadscientist (06-11-2015)
Old 06-11-2015, 02:20 AM   #64
Sammakko
Bilge monkey
Sammakko's Avatar
so many hairdressers! my 40 yr old aunt went to school for cosmetology.
she's a dentist now.
go>show
Old 06-11-2015, 02:23 AM   #65
Captain Snooze
Drives: Red Herring
go>show
Not for a lot of people it would seem.
Old 06-11-2015, 02:24 AM   #66
D K
I havent dne the math but I think its a little bit more.
This sentance makes 0 sense.
But if you are asking whether or not the VVT can control the cams within 1 degree of crank timing, then the answer is yes.
wouldn't VVT system compensate for it anyway without tuning??
Are you serious????
Or just playing?
Old 06-11-2015, 03:16 AM   #67
stugray
Yes - the ECU has a target cam angle. The control system tries to keep the angle as close to the target as possible. Does this system typically run within 1 degree of target cam phase angle?
Are you serious????
Or just playing?
Quite serious. The cam sensor senses the controlled side of the cam (opposite side from cam gear). The side that floats.
The control system modulates the system to move floating side of the cam to the target angle.
If you believe that the system can control to within 1 degree than it clearly can remove one degree of difference between the two cams just as it will compensate for (slightly) stretched chains.
And back on topic:
Increasing the engine stroke not only gives more torque due to increased displacement, but it also increases the lever arm length of the rod pushing on the crank.
So there is another factor that increases overall hp by stroking.
There is yet another factor of increased maximum piston velocity (harder on wrist pins) that affects VE.
Old 06-11-2015, 12:17 PM   #68
D K
Allright.
Well thanks for clearing that up.
Old 06-11-2015, 12:28 PM   #69
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Originally Posted by themadscientist View Post
I'm American and my Japanese is atrocious, but I get by.
I don't know about him, but he seems schizophrenic, he keeps referring to himself as "we."
Schizophrenia and multiple personality disorder are completely different mental illnesses. Linking the two is like saying everyone with a cold has swine flu.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 06-11-2015, 03:59 PM   #70
celek
Resident Gear Head
celek's Avatar
HKS offers three different metalic headgasket for the FA20 to use in addition of the stroker kit. 0.5 , 0.7 , 1 mm they respectively lower the compression ratio (in case of a FI setup) to 12.4 , 12.1 and 11.7
It doesn't sound like much, but it makes a difference and all elements put together offer that litle more wiggle room for tuning and more output.
The HKS cams are also stated to require the HKS pistons and the higher capacity / stroker kit. People keep in mind you can not just toss these in a stock motor as I think the valves will make contact with the pistons.
Have we covered that already?
celek is offline   Reply With Quote
Toda 2.3 stroker kit brn12345 Engine, Exhaust, Transmission 116 09-29-2016 08:47 PM
HKS New Stroker Kit and Evasive Motorsports Engine Build Evasive Motorsports Forced Induction 58 05-28-2015 12:45 PM
HKS New Stroker Kit and Evasive Motorsports Engine Build 2014 UPDATE 9/9/14 Evasive Motorsports FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 41 09-15-2014 03:52 PM
Any stroker kits yet? HighLife Engine, Exhaust, Transmission 26 01-29-2014 04:16 PM
Toda headers + stroker kit in development diss7 Engine, Exhaust, Transmission 2 08-09-2013 07:55 AM
