| View Poll Results: Is the chattering engine sound normal when accelerating in 2nd gear at 1500-2000rpm? | |||
| Yes, the sound is normal. (please explain what the sound is) |
19 | 44.19% |
| No, you should slip the clutch a bit |
11 | 25.58% |
None of the above. (tell me what is right below )
13 | 30.23% |
| Voters: 43. You may not vote on this poll | |||
Drives: GTS86
is it ok to slip my clutch often in 2nd gear when my rpm is below 2k?
Am I better of feathering at 1500-2000rpm in 2nd gear and have that chattering,rattling or grinding noise or should I slip the clutch to bring the revs up ?
Also, What's that noise when accelerating below 2000rpm in 2nd gear ? Am I lugging the engine or is it something else ? Last edited by awhatzable; 06-10-2015 at 09:07 PM. |
#2 |
Drives: FRS
when im stuck in traffic (every morning), if my car is moving even at like 5mph ill keep it in 2nd. the only time im in 1st is when ive come to a dead stop and then start to move again but barely. once i shift to 2nd, i stay in it (or higher if needed) until i come to complete stop. once in awhile i'll revmatch to 1st again if speed drops to like 3mph or less and we're all creeping forward without actually stopping.
#3 |
Drives: 2018 BMW M240i
You shouldn't need to slip your clutch in 2nd gear regardless.
Dont slip clutch for no reason. |
| The Following 7 Users Say Thank You to tennisfreak For This Useful Post: | fika84 (06-10-2015), humfrz (06-10-2015), kch (06-10-2015), RobertPaulson (06-12-2015), serialk11r (06-12-2015), Tcoat (06-10-2015), Ultramaroon (06-11-2015) |
#4 |
THIS ^ PERIOD!
| The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
#5 | |
Drives: GTS86
does your engine lug or chatter a bit ? mine lug at 16-17mph and below
#6 |
Drives: GTS86
#7 |
Drives: GTS86
#8 |
Drives: 2020 718 GT4, 2013 FR-S (Turbo)
If you're lugging in 2nd at those speeds, you likely just need to be smoother on the gas. The car is perfectly comfortable in 2nd down to 1.5k RPM or lower as long as you ease on the gas when you want to accelerate.
| The Following 4 Users Say Thank You to JozhGoober For This Useful Post: |
#9 |
Drives: GTS86
Really ??? even if I'm going uphill with passengers ? I'm noob sorry
#10 |
#11 |
I don't accelerate at low RPM in 2nd so don't have a noise but would expect that it is lugging. My car rarely sees anything under 3000 while in gear. In the case you said at the start of the thread I would be in first with revs up.
#12 |
Drives: GTS86
Sowhen your making a turn in 2nd gear it doesn't drop to 2000rpm and below? How fast are you turning ?
#13 |
From a stop stay in first. Moving start turn, clutch all the way in if too fast through turn clutch out again at end of turn or this is the one time I may let it drop below 3000 but certainly not down to 1500 or less. 3000 rpm in 2nd is not all that fast.
| The Following User Says Thank You to Tcoat For This Useful Post: | JohnJuan (06-10-2015) |
#14 |
The Fail Boat
Drives: CWP S.B.
When I roll forward in traffic I try to stay in 1st... but if u are just rolling forward in 2nd & gas it really slow I notice u can get by without lugging the engine at around 6-7 mile.
| The Following User Says Thank You to chaoskaze For This Useful Post: | Ultramaroon (06-12-2015) |
| 2nd gear grind while slowing down NO clutch | Muskokan | Issues | Warranty | Recalls / TSB | 12 | 07-18-2017 01:35 PM |
| What's this clunk sound coming from 2nd gear after letting go of the clutch ? | awhatzable | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 04-30-2015 02:14 AM |
| Limited Slip diff oil Motul GEAR 300 LS 75W-90 | FRSToyota86 | Canada Classifieds | 12 | 08-22-2014 12:47 PM |
| clutch/gear box getting softer | zERoTu | Issues | Warranty | Recalls / TSB | 3 | 06-05-2014 08:18 AM |
| Display current gear without clutch engaged? | cfusionpm | Scion FR-S / Toyota 86 GT86 General Forum | 45 | 03-26-2013 04:08 PM |
