#939 | |
Drives: 2013 Black FR-S
| The Following 3 Users Say Thank You to sw20kosh For This Useful Post: |
#940 | |
Drives: BRZ Limited
Ah okay. Thank you very much. I will eliminate it from my consideration. I will talk with the shop and see what we decide on. My guess is we end up doing something custom.
Build Thread
PTuning Turbo & Exhaust / JDL UEL Header / Delicious Tuning Flex Fuel / Eibach Pro-Kit Springs |
#941 |
20 row or 15 row series 9 setrab
| The Following User Says Thank You to sw20kosh For This Useful Post: | Deadpool_25 (06-04-2015) |
#942 |
Drives: BRZ Limited
I have a question about some of the dyno graphs. If this is true:
"The formula for figuring HP is TQ x RPM / 5252. So HP is a function of engine TQ and is directly related to RPM. As you can see from the formula, HP will always be lower than TQ below 5252 RPM's and above TQ at over 5252 RPM's." - https://www.amsperformance.com/resou...-tq-dyno-chart How come some of the charts don't cross at 5252? Just curious what causes it to be different sometimes.
Build Thread
#943 | |
| The Following User Says Thank You to mkivsoopra For This Useful Post: | Deadpool_25 (06-08-2015) |
#944 | |
| The Following User Says Thank You to sw20kosh For This Useful Post: | Deadpool_25 (06-08-2015) |
#945 |
Drives: BRZ Limited
Ah. Obviously. Yup, thanks guys.
Build Thread
#946 |
Drives: 2013 Scion FR-S Firestorm Red
Quick question guys.. I'm wrapping up the install of my turbo kit tonight.. is the basemap preloaded on the supplied usb flash drive or do I have to get the file from PTuning?
#947 |
Drives: Scion FRS
#948 | |
Drives: 2013 Whiteout FR-S
They should be open in a little bit I would give them a call as that is the fastest way to get a hold of them
| The Following User Says Thank You to kanundrum For This Useful Post: | MooKz (06-09-2015) |
#949 |
NASA SpecE30 Racer
Dat PTUNING low turbo lifestyle bro:
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| The Following 3 Users Say Thank You to King Tut For This Useful Post: |
#950 |
| The Following 4 Users Say Thank You to Raven604 For This Useful Post: |
#951 | |
Usually, we use road speed as it is the quickest/easiest way to do it but its not the most accurate. Just like how the vehicle measures road speed at an axle, we measure RPM by using a ratio of MPH/RPM. The problem is that the tires like to expand at higher torque numbers so the MPH/RPM ratio changes. This isn't a problem because the HP/torque is measured independently of the RPM reading but can make tuning irritating because we have to figure out where we are relatively in the RPM range. We always end the pull at redline so the end point is always a known RPM but the entire scale may be off. For a cleaner reading, we can take a reading directly from the ECU's tachometer output wire. This lets us plot the true RPM and is the most accurate. Depending on the vehicle, this is the hardest source to get as normally we have to T-tap directly into factory wiring. Worse yet, the FR-S doesn't have a tachometer signal wire! We have to use a patch harness to connect to a pin that exists on the ECU, likely there for development and R&D purposes. We'll normally do this on high HP builds (turbo, SC, etc). The third way is to use an inductive clamp like a timing light, but getting to the ignition coil wires is not the easiest thing (no space). |
| The Following User Says Thank You to Ken@PTuning For This Useful Post: | Deadpool_25 (06-09-2015) |
#952 | |
Sideways and Smiling!
Drives: Scion FR-S
So would you recommend an oil cooler for my oil cooler so i can cool while im cooling? |
| The Following User Says Thank You to Darryljr11 For This Useful Post: | sw20kosh (06-09-2015) |
| Tags |
| ptuning, turbo kit |
| Full Blown Turbo Kit Owners Topic | King Tut | Forced Induction | 2639 | 04-05-2026 10:31 PM |
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
| AVO Turbo Kit Owners Topic | Sportsguy83 | Forced Induction | 1935 | 02-20-2023 10:46 AM |
| FA20Club Turbo Kit Owners Topic | pixel67 | Forced Induction | 1531 | 09-09-2014 12:36 PM |
| P&L Turbo Owners Topic Thread | GTB/ZR-1 | Forced Induction | 4 | 09-01-2013 06:27 PM |
