Old 04-17-2015, 06:48 PM   #281
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Originally Posted by G-awesome View Post
I know this a wheel thread but....need to know what front lip is that on the white FRS? I WANTS!
Looks like a varis lip.
http://www.evasivemotorsports.com/mm...IS-FRONTBUMPER
Old 04-19-2015, 01:38 AM   #282
ET86
Perfectionist
ET86's Avatar
Drives: 2014 Scion FRS
Stivo front lip. Wheeldude use to sale them but i'm not sure anymore.
ET86 is offline   Reply With Quote
Old 04-22-2015, 11:38 AM   #283
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Old 04-24-2015, 01:37 PM   #284
dejxx
dejxx's Avatar
Drives: FT-86
does anyone here runs AP Racing Sprint kit with their ROTA´s ????
I want to buy some Titans 17x9 or 18x9.5 but i was wondering if it will fit with the kit?
Also, only suspension mods are Eibach Pro Kit + Whiteline camber bolts front. Might get coils in the future (roads in Argentina suck, so cant lower the car more than 1 inch)
thanks!
dejxx is offline   Reply With Quote
Old 04-27-2015, 01:52 PM   #285
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Rota RT-5
Old 05-03-2015, 12:44 PM   #286
FRZ
FRZ's Avatar
Drives: Subaru BRZ
@WheelDude.com
Can you give me a quote for a set of 18x9.5 +40 Rota Torques in Hyperblack, shipped to Toronto, Canada for BRZ? I tried to PM you but your mailbox is full.
Does anyone know what the costs at the border will be? (Customs, duties.. etc)
FRZ is offline   Reply With Quote
Old 06-08-2015, 05:07 PM   #287
Benschneider06
Benschneider06's Avatar
Drives: Satin White Pearl Subaru BRZ
Could someone tell me the difference between:
17X9 ROTA TITAN - SPORTS BRONZE (5X100/E42/73)
and
17X9 ROTA TITAN - SPORTS BRONZE (5X114.3/E35/73)
Not understanding what the numbers at the end mean (wheel noob)
Benschneider06 is offline   Reply With Quote
Old 06-08-2015, 05:10 PM   #288
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
and
You need 5x100, that's the bolt pattern.
Old 06-09-2015, 05:57 PM   #289
wheelhaus
wheelhaus's Avatar
and
5x100 is what we need.
5x114.3 puts the lug holes too far out and they don't fit (larger diameter pattern).
e35 or e42 is the offset in mm. This is how far off center the wheel's mounting face is (where it meets the hub). 0 offset means the wheel's mounting surface is dead center. e42 means it's 42mm offset toward the wheel's face. These are both positive offset (left image below), so the knuckle fits inside the wheel. This purpose of this is to alter where the hoop (outer part of the rim) is located when mounted on the vehicle. Low offset pushes the wheel outward and results in a deeper looking dish. High offset pulls the wheel into the wheel well and makes a flatter looking dish.
73 is the hub bore. This is the big hole in the center. You don't NEED hubcentric rings for this car because the wheel will center onto the lugs since they're all conical. But hubcentric rings are typically recommended as they help to initially center the wheel onto the hub flange. Our hub is 56mm I believe, so you'd want hubcentric rings with OD 73mm, and ID 56mm.
for a 17x9 wheel, I THINK 35mm offset will fit and not rub the OEM springs. 42mm may be too much, and the tire might rub the spring.
Do some searches for wheel fitment and you'll get a better idea of what does and doesn't work. Some wheels require coilovers because the shock body and spring is narrower, which allows more clearance for wide wheels/offsets.
Old 06-16-2015, 01:42 PM   #290
sweetspeed
sweetspeed's Avatar
Drives: 2014 Raven Black FR-S
Rubbing Question
Originally Posted by JesseE View Post
18x9 +35 235 width tires
So you get no fender liner rubbing with these wheels right? They look BA dude, what type of supercharger are you running?
Looking at running a similar setup; got the same color car with CF hood/NRG steering wheel/lots of suspension upgrades and an entire aftermarket exhaust.
sweetspeed is offline   Reply With Quote
Old 06-29-2015, 02:49 PM   #291
kayoh
kayoh's Avatar
Drives: 2014 SWP Limited BRZ
I'm trying to pick up Rota RT5s 18x8.5 +44 and wheeldude is currently out of stock. Does anyone have any recommendations on where else I can buy these wheels?
kayoh is offline   Reply With Quote
Old 06-29-2015, 11:04 PM   #292
Zetta
Does anyone know if Rota Grid's in 18x9 or 17x9 will rub at all or have and issues on stock suspension? also looking to get Ebachi Pro kit down the road so I was wondering the same thing with that as well.
Thanks !
Zetta is offline   Reply With Quote
Old 07-09-2015, 11:59 AM   #293
WheelDude.com
Drives: 2013 FRS
Send a message via AIM to WheelDude.com
Thanks !
you should be ok with the 17x9 offset 42, same with the 18x9 e42. what tire size are you planning on running?
joseph
WheelDude.com is offline   Reply With Quote
Old 07-13-2015, 08:21 PM   #294
Th3rdSun
Drives: 2013 FR-S MT Hot Lava
Anyone have a set of Rota RB's on their car? I would really like to see what they look like on an FR-S.
Th3rdSun is offline   Reply With Quote
The ROTA Thread WheelDude.com BRZ Photos, Videos, Wallpapers, Gallery Forum 47 02-28-2015 12:17 PM
Group Buy - Rota Slipstreams or Rota Grid davidsolarbell Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 12-17-2013 12:04 PM
Rota D wheel thread Mach V Dan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 03-05-2013 11:46 AM
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 12:24 PM
Feeler thread: 18x8.5 +44 Rota DPT's JoeBoxer Wheels and Tires 4 09-10-2012 01:59 AM
