Old 05-22-2015, 10:16 AM   #2759
MrFabulous
Drives: Between Cars
Does anyone have suggestions or opinions on rake? Between this and the suspension thread I think I've only seen it mentioned once (it was a lot of posts to go through) and that was just to say that Robbie's car is lower in the rear than CSG Mikes. Since I'm looking at a minimal drop with softer rates and I don't have scales (yet) I'm open to suggestions. Thanks!
MrFabulous is offline   Reply With Quote
Old 05-22-2015, 12:40 PM   #2760
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Ooh, something I actually know. Unless prevailing wisdom says otherwise I'd start with a level car and use rake to dial the amount of oversteer/understeer. A higher rear end than the front end will result in some oversteer as the rear is less grounded to the ground for lack of an easier description. A lower rear end than the front will result in the opposite adding some understeer to the setup. Aggressive changes will result in changing your static camber and maybe toe so I wouldn't go adding or subtracting a 1/4" at the track without knowing what that does first.
When I get coilovers I will certainly try throwing a turn or two at the front or back to see how it feels on track between sessions, that kind of thing may be unnoticeable to many drivers but it can show up in the data and lap times, in my experience, tire temperatures never lie, 1/16" of rake adjustment shifted the tire temperature delta front to back ~2-4 degrees F on the little karts when I was a teen.
Again, someone with experience could chime in that the car definitely likes a higher/lower front/rear end, anything more than a 0.XX" rake is undesirable, an adjustment of a 1/2 turn is or is not enough, etc. But in my past it's been a pretty predictable knob to turn, although racing circle tracks tilt was more effective.
As long as you're scientific about it (i.e. you don't make a bunch of changes at once) figuring that stuff out on your own is one of the reasons I love playing with cars.
ineedyourdiddly
Old 06-08-2015, 12:39 PM   #2761
DatApex
Drives: 2013 WRB BRZ Limited
Anyone have a lot of experience with ProjectMu brake pads? I've been running NS400s for street, and swapping to RC09s for track (which I have been loving, stock rotors and calipers, stainless lines with superblue fluid as I have a stockpile still.). I'm having a tough time finding any sort of direct comparisons from the ProjectMu line to other brake pads, and how they stack up. Basically everyone else I know is running Carbotech XPsomethings, so looking for a few more opinions from some of the more experienced track guys. The PMU a bit harder to find (and pricey) compared to some of the other options, but from my personal experience it seems like it might be worth it? I've tried pretty much all of Hawk's line (though not on this platform, admittedly) and been very underwhelmed, and I've only ridden in cars with Carbotechs, never driven one.
I'm looking to buy new street pads soon as my NS400s are getting fairly low. I like how I don't really need to re-bed the brakes swapping from NS400s to the RC09s, which is a big plus in my book.
DatApex is offline   Reply With Quote
Old 06-08-2015, 01:05 PM   #2762
redlined600
redlined600's Avatar
Drives: Fr-s
How bad is rear lift with a muffler delete? Should I put my stock muffler back on for track days or will I not notice.
redlined600 is offline   Reply With Quote
Old 06-08-2015, 02:31 PM   #2763
CSG Mike
CSG Mike's Avatar
It's there but unless you're pretty experienced, it will not make a large difference.
Old 06-08-2015, 02:37 PM   #2764
CSG Mike
CSG Mike's Avatar
I have tons of experience with PMU.
What specific questions do you have?
Old 06-08-2015, 06:26 PM   #2765
Jack Black
Drives: 2015 FR-S
Are there any parts store brake pads worth bothering with?
I'm not a novice (20+ track days, 12-ish years autox), just haven't bothered to track prep the car and I decided last week to do one of the SCCA track night events. Wondering if there's anything I could pick up locally that would last better than the stock pads.
Thanks!
Jack Black is offline   Reply With Quote
Old 06-08-2015, 06:43 PM   #2766
DatApex
How do you like them compared to other pads? What would be a more or less direct comparison to the RC09s from other brands? Any thoughts on their rotors/fluids/calipers? Everything I see from the company I like a whole lot, just been having a hard time finding first-hand experience on this platform.
I assume you'd be using the RC09s on track, how have they held up for someone like you who knows how to drive?
I've already hit the limit on what I want to mod for power, so I'm looking at brake upgrades next. For header/exhaust with tune on (eventually) E85, are the RC09s going to be sufficient as a track pad or will I need something more?
I've also noticed that after a day of track, the edges of the pads are sort of crumbling away. See attached, is that normal for these?
Old 06-08-2015, 08:08 PM   #2767
CSG Mike
CSG Mike's Avatar
Thanks!
Not really; you really should be on a race pad with that kind of experience.
Old 06-08-2015, 08:09 PM   #2768
CSG Mike
CSG Mike's Avatar
You're overheating the pads, whether it's from you being too quick for the stock braking system, or a dependence on ABS, I cannot discern.
Do you have any videos of your driving?
Old 06-09-2015, 01:04 AM   #2769
troek
troek's Avatar
Drives: 2012 Toyota 86
@CSG Mike i see a very very light amount of that on my project Mu rsf01 track pads around the edges only, is this a concern? i rarely hit my abs for more than a split second now and then.
troek is offline   Reply With Quote
Old 06-09-2015, 04:23 AM   #2770
CSG Mike
CSG Mike's Avatar
If it's edges only, no.
troek (06-09-2015)
Old 06-09-2015, 10:41 AM   #2771
DatApex
Only a single session (EDIT: Only a single video, that is, I had about 6 sessions that day). My last event was in the soaking wet so there was a fairly heavy "reliance" on ABS as it was nearly impossible to not have it engage with how wet it was out. That's interesting, though, I didn't know that ABS could cause that kind of pad overheat. I never noticed any sort of fade or lack of bite in the pads the whole day. Here's the vid:
[ame="https://www.youtube.com/watch?v=7wDYzXm3eSc"]#Gridlife 2015 - Rain Session Run - 2013 Subaru BRZ - YouTube[/ame]
Old 06-09-2015, 11:47 AM   #2772
Jack Black
Drives: 2015 FR-S
Yeah, normally I would be, but I didn't want to spend close to $500 on something that I may only do once. I haven't done a track day since around 2006, just felt like giving it a try in the new car.
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
