Old 06-06-2015, 06:10 AM   #15
jiaim
Drives: Enthusiast
at 3800$ this charger is really a great option.
jiaim is offline   Reply With Quote
Old 06-06-2015, 10:23 PM   #16
fluffy-reindeer-slayer
Drives: fr-s and tc2
what is the diffrence between the ver 1 and ver 2, other than the obvious intercooler and piping?
fluffy-reindeer-slayer is offline   Reply With Quote
Old 06-07-2015, 12:58 PM   #17
FRSCanuck
Drives: Scion FRS
V2 utilizes the stock airbox as well.
http://www.hks-power.co.jp/en/produc...tsc/index.html
FRSCanuck is offline   Reply With Quote
The Following 2 Users Say Thank You to FRSCanuck For This Useful Post:
CxG (08-02-2015), fluffy-reindeer-slayer (06-07-2015)
Old 06-07-2015, 01:30 PM   #18
thanks, so it looks like the actual supercharger itself is the same unit. i hadve a really good deal going on for the version 1.just wanted to ask.
Old 06-07-2015, 03:39 PM   #19
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
V2 with 43mm restrictor which comes with the HKS injectors. Delicious Flash & Go tune. Did not measure on a dyno yet.
Car is now grounded due to unknown issue which seems like the DI seals failure but after replacing those and checking various other possible reasons the problem remains... Tried everything. No idea what to do next. Probably will buy the HKS stroker kit and get the engine re-built
Efferalgan is offline   Reply With Quote
The Following 2 Users Say Thank You to Efferalgan For This Useful Post:
armythug (06-20-2015), FRSCanuck (06-17-2015)
Old 06-10-2015, 10:52 AM   #20
10Stars
Drives: 14 Subaru BRZ Limited WRB
I'm really liking the v2 supercharger from hks. The v2 shipped from japanparts to my location is $3500, very tempting.
Couple questions though:
1). How much plug in play is the v2 kit? Any cutting, modifying needed?
2). What oil cooler are you guys running? Is it required to use a specific hks oil cooler or can I use a different aftermarket oil cooler? Will I need an oil cooler for a daily street setup?
3). Will a uel header be compatible?
4). Does it work with a 6AT?
I'm ways away from getting this but I'm definitely looking to go FI in the future. I'm thinking either this or JRSC.
10Stars is offline   Reply With Quote
The Following User Says Thank You to 10Stars For This Useful Post:
Traktor (08-04-2016)
Old 06-11-2015, 09:57 PM   #21
wbradley
Sarcastic SOB
wbradley's Avatar
Dyno tuned today with ECUtek for 94 octane with restrictor delete on Dynapack. Result 275 WHP, 210 ft/lbs torque. Speed density tables were applied. Tuner said he typically sees up to 50 HP powertrain loss on these cars so I'm somewhere between 315 to 325 BHP for people who don't know cars haha.
I have the smaller pulley and 700c injectors never installed if anybody wants them to go Stg 3. I am Stg 2 with upgraded intercooler BTW.
wbradley is online now   Reply With Quote
The Following User Says Thank You to wbradley For This Useful Post:
10Stars (06-12-2015)
Old 06-11-2015, 11:39 PM   #22
HaDDeS
Touge worship
HaDDeS's Avatar
Drives: Forester STi SG9
Hey hey HKS V2 friends nice to see this setup is popular on the other side of the Ocean as well !
My BRZ is also "HKSed".
Previous user of the V1 kit , this time we upgraded to V2 ...fully unrestricted, the supercharger blows in a fully rebuild engine with HKS 2.1 stroker, HKS Vcams, HKS injectors, HKS manifold , no cats, Tomei over Pipe, Blitz straight pipe and finaly HKS highpower Spec-L firing trough pretty much every gears.
The results are ... interesting on the same type of dyno (dynapack) as wbradley it scored 366 whp, and 295 ft/lb of torque, there is still meat on the bone, but for the sake of not killing the transmission too fast we decided it was good enough ... best run was 380whp, that sets for way over 400 crank hp
here is the dyno for the records, as you see the dynapack isn't a very forgiving device given the 145hp stock at the wheels, but that's just the norm on it .. So its more than x2.5 stock power.
Small video of the Dyno run:
[ame="https://www.youtube.com/watch?v=0eqPdwBZM_s"]https://www.youtube.com/watch?v=0eqPdwBZM_s[/ame]
And the car in action, it is just a beast ...
[ame="https://www.youtube.com/watch?v=rb0u41Qy8wI"]https://www.youtube.com/watch?v=rb0u41Qy8wI[/ame]
Can't be happier with the setup ! feel free to ask for anything you would like to know.
HaDDeS is offline   Reply With Quote
The Following 8 Users Say Thank You to HaDDeS For This Useful Post:
10Stars (06-12-2015), armythug (06-20-2015), CxG (08-02-2015), GTHachiRoku (08-14-2016), hamzam (03-22-2016), snk828 (07-15-2015), SPCorBUST (06-11-2015), wbradley (06-13-2015)
Old 06-11-2015, 11:48 PM   #23
HaDDeS
Touge worship
HaDDeS's Avatar
1 fairly plug & play , yet better let it done by a pro if you aren't one! cutting will be needed for the HKS Engine oil cooler if you want one, as it sits in the wheel well. Other options are possible, but this one is the best as everyhting has been routed with HKS v2 piping in mind.
2 well, see 1
3 yes, but EL is the best option, UEL will drastically lower the performance, on a V2 setup, UEL headers typicaly score 20-25hp less, that is what SCREEN's boss usually see on the dyno.
4 yes totally works on AT, yet the results won't be as high, more losses in the transmission
The Following User Says Thank You to HaDDeS For This Useful Post:
Old 06-11-2015, 11:58 PM   #24
wbradley
Sarcastic SOB
wbradley's Avatar
Porsche killer!
And on a lighter note, as a Frenchman in Japan (single?), you should do pretty well with the ladies. I understand from a long time dating back before WW2 the more worldly Japanese had big appreciation for French culture. The champion Japanese Iron Chef on TV is a French Chef.
My teenage daughter and many of her friends are into the somewhat innocent Lolita scene from Japan. People photograph us when we go out all the time and the pictures get thousands of hits on Instagram. Not all Japanese girl stuff is so innocent though
Old 06-12-2015, 12:05 AM   #25
HaDDeS
Touge worship
HaDDeS's Avatar
Originally Posted by wbradley View Post
Porsche killer!
Funny you say that, because yes, it is indeed a Porsche killer, on my local mountain road a Cayman S doesn't stand a chance, specialy on the way down where i can just rely on my lighter car and the monstrous brakes. It actually became a "many things" killer indeed, should I be brave enough coz, let me tell you passed 5.000 it really wakes up and offers you a pretty juicy shoot of adrenaline in the pants.
As for "japan", well I got married two weeks ago, but yes indeed, i'm an "exotic" here, so attract a lot of ... attention
I hope to see more of the HKS chargers around, will report that to my friends at HKS Dev they'll be super happy !
Here is where your stuff comes from, crafted at the feet of the Fuji !!
The Following 3 Users Say Thank You to HaDDeS For This Useful Post:
10Stars (06-12-2015), CxG (03-17-2016), JMon85 (11-05-2017)
Old 06-12-2015, 12:09 AM   #26
wbradley
Sarcastic SOB
wbradley's Avatar
Congrats on the marriage. Saw a nice writeup this week on the HKS complex on NASIOC. Cool.
Old 06-12-2015, 01:20 AM   #27
10Stars
Thumbs up
Originally Posted by HaDDeS View Post
1 fairly plug & play , yet better let it done by a pro if you aren't one! cutting will be needed for the HKS Engile oil cooler if you want one, as it sits in the wheel well. Other options are possible, but this one is the best option as everyhting has been routed with HKS v2 piping in mind.
2 well, see 1
3 yes, but EL is the best option, UEL will drasticaly lower the performance, on a V2 setup, UEL headers typicaly score 20-30hp less, that is what SCREEN's boss ususaly see on the dyno.
Thank You. Btw i absolutely love your car. I'm also wrb
What else exactly needs modification/cutting to fit?
Wow thats a hell of a drop when using a uel header hard to believe as other rotrex superchargers dont suffer the same when running uel headers. I'll take your word for it though
From what I understand is that hks has a specific oil cooler for the v2 supercharger. I'm honestly not sure I need one as this will probably just be a daily driver with a few pulls every now and then. No track days for me.
Is this whats recommended?
https://www.japanparts.com/parts/detail/43635
for
https://www.japanparts.com/parts/detail/43298
Im not looking for much but i'd like to make 300 at the crank using 91 shell v power tuned with ecutek(no 93 or e85 here). Mods would be el header and a catback exhaust(maybe a front pipe and overpipe if i need it to achieve those numbers)
Old 06-12-2015, 01:26 AM   #28
HaDDeS
Touge worship
HaDDeS's Avatar
[url]https://www.japanparts.com/parts/detail/43635[/url
for
You ABSOLUTELY NEED AN OIL COOLER !! don't even make the mistake not to fit one. It is absolutely critical, this and to be able to monitor oil temp, and pressure ! Daily driving your car can be a real issue as well, sitting in the traffic could be bad, with a V2 blowing in its lungs, trust me, temps can go sky high if you don't have an oil cooler. If you are ready to invest thousands of $ for the V2 kit, don't go cheap fit a proper oil cooler, and yes the S type is the one to use.
Your setup seems good for the power you want, yet if you live in a hot area it might be a litle more complicated but still that's the way to go.
V2 supercharger, EL no cat header, over pipe, front pipe, exhaust , Oil cooler, break pads, tires, and possibly clutch ...
On the EL / UEL debate, i'm going to talk on what i know, HKS has also an UEL header, they don't recommend it at all for any perf oriented setup ... some will argue it is horse s** but fact is i've seen two 86 on the dyno, one with a UEL hks header, other with EL one, the UEL was down by 20hp ... would it be the same with other UEL setup, I don't know but you got my note on it UEL isn't a "performance" setup anyway ... subaru doesn't use it anymore for a reason, so isn't Porsche ... Yes it sounds cool, but comes at a price.
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
Five Axis Edition FR-S Owners Thread digital_assassin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 563 07-08-2015 09:22 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
Supra Owners Build Thread BoostJunkie Other Vehicles & General Automotive Discussions 164 03-12-2012 09:37 AM
