Old 06-05-2015, 11:17 AM   #3207
ChrisV
Drives: 2014 FR-S 6MT
Originally Posted by Arigh View Post
Degassing konis for more camber? So you end up with less damping AND your shocks are going to start having issues with cavitation??
Sounds like an amazing idea for a marginal amount of camber.
A+, would laugh again.
A difference in gas pressure is just one of the factors that can result in a different ride height, it's also been a common technique in autocross to get around the rules limitations.
And I'm not even saying degassed, but lower than OEM or a comparable Bilstein. That's my speculation, FYI.
Also, I PM'd Lee Grimes from Koni on another board and he said that the struts were intended to be replicas of OEM on all external measurements that matter. If they measure out incorrectly, it would be the first time it has happened and he would like to know so that they can get engineering involved.
So unless someone has some hard numbers that say otherwise, can we drop this? I'll still measure when I install mine, but I think we can trust Koni over a bunch of speculation and non-evidence.
ChrisV is offline   Reply With Quote
Old 06-05-2015, 01:22 PM   #3208
ksconekiller
Drives: Subaru BRZ
Alright, dammit. I'm going outside to take dimensions on mine right now. Results to come...
ksconekiller is offline   Reply With Quote
The Following User Says Thank You to ksconekiller For This Useful Post:
DylanFRS (06-05-2015)
Old 06-05-2015, 01:54 PM   #3209
Laloosh
Laloosh's Avatar
Drives: 2014 BRZ
Originally Posted by ksconekiller View Post
The Koni full replacements allow too much camber up front. If you are using the full Koni struts along with the smaller camber bolts maxed out, you will have an illegal amount of front camber. I'd say over 2.5 degrees is easily possible. I personally wouldn't have a problem with someone using the replacements as long as they keep the camber where it's possible with OEM struts (1.5 or less).
So I dug this up from a couple pages back. Is this something you tried and confirmed or is this theory?
2014 BRZ C-Street #11 245/40/17 RE71R's, Camber Bolts, Koni Shocks, Perrin 19m Bar, 5mm Spacer/Longer Studs, Berk Track Pipe, KNN Drop In, Fancy alignment
Laloosh is offline   Reply With Quote
Old 06-05-2015, 02:01 PM   #3210
ksconekiller
Drives: Subaru BRZ
Okay, here we go. Here's my Koni strut. Note the round (not slotted) holes.
I took the dimensions I thought were relevant to this conversation on both the OEM strut and the Koni. OEM listed first, then Koni. All measurements in millimeters taken with a digital caliper.
Bottom of spring perch to middle of top knuckle hole: 111.61/111.48
Top knuckle hole diameter: 16.28/16.32
Lower knuckle hole diameter: 13.97/14.02
Shock body to inboard edge of top hole: 20.25/20.32
Shock body to outboard edge of lower hole: 40.82/40.88
These should be the dimensions that could affect camber. As you can see, they are all ridiculously close (probably within manufacturing tolerances). I'm not an engineer, but I'd say they would qualify as being the same as far as production is concerned.
I won't be driving the car for a couple of days, so I will leave it apart in case anyone thinks of another measurement that needs to be taken.
The Following 9 Users Say Thank You to ksconekiller For This Useful Post:
ChrisV (06-05-2015), Cueman (06-05-2015), DocWalt (06-07-2015), Laloosh (06-05-2015), renfield90 (06-05-2015), simpleisbest (06-05-2015), solort (06-07-2015), TrqlessWonder (06-05-2015), u/Josh (06-10-2015)
Old 06-05-2015, 02:03 PM   #3211
ksconekiller
Drives: Subaru BRZ
That was based on comments I had seen throughout the community. Sorry, I should have been more clear about it. As noted just above, mine measured out like stock, and I got the same camber with the Konis as with OEM.
Old 06-05-2015, 02:19 PM   #3212
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
So the people getting 2+ deg are going to have to start sharing their secrets...
DylanFRS is offline   Reply With Quote
Old 06-05-2015, 02:43 PM   #3213
ksconekiller
Drives: Subaru BRZ
No kidding. I would love to find a way to legally get more.
Old 06-05-2015, 02:45 PM   #3214
ChrisV
Nice work ksconekiller. Now we can put it to rest.
I just need my front struts to come in now so I can
I'll post my alignment numbers when I get it, but it may still settle a bit afterwards because I'm going to be putting on the TRD springs at the same time.
Old 06-05-2015, 07:10 PM   #3215
solort
Drives: Series 10 FRS
Compression and rebound have nothing to do with whether the struts are gassed or degassed. The valving does that. The gassed stock Koni Sports will always rise back to their original max length on rebound. Degassed will stay in the same position until they are compressed or stretched.
solort is offline   Reply With Quote
Old 06-06-2015, 01:10 PM   #3216
markw
Drives: 2014 FR-S
Degassed, they'll cavitate, and valving is designed for fluid. You remove the charge from a shock, it will definitely effect compression and dampening.
Now that the holes look to be within stock part dimensions, I'm going to go crank mine up to 2.5 degrees.
Mark
markw is offline   Reply With Quote
Old 06-06-2015, 04:17 PM   #3217
ksconekiller
Drives: Subaru BRZ
Are you serious? Do you have the full struts and are able to get more camber? Or are you just playing off what's been said here lately? If you can get more, I'd sure like to know how it's physically possible.
Old 06-06-2015, 06:13 PM   #3218
markw
Drives: 2014 FR-S
Bone stock Koni's just like the one you pictured. Camber is right at 2 degrees. When I took it in for alignment after installing them, the shop had the initial at like 2.6 on one side and 2.3 on the other. I have the factory camber correction bolts in the upper hole, and I tightened them with a jack under the hub compressing the spring, then tightened the two bolts at the spindle, and then the top 3 bolts. I told them to pull it back to 2 degrees as I "daily drive" it.
Mark
Old 06-06-2015, 07:01 PM   #3219
Cueman
Cueman's Avatar
Drives: In Perfect Control At All Times
Mark
Hrmm... if one more person would like to share the same experience... I'd like to order some Koni's...
Cueman is offline   Reply With Quote
Old 06-06-2015, 09:11 PM   #3220
solort
Mark
So is the crash bolt approved for the top or bottom hole of the 2 strut alignment holes?
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
