Old 06-03-2015, 08:22 PM   #2353
enivid
enivid's Avatar
Drives: WRB JR BRZED
How about just getting the delicious tune so you don't have to deal with all these MAF issues.
enivid is offline   Reply With Quote
Old 06-03-2015, 08:28 PM   #2354
CSG David
CSG David's Avatar
We have a pretty awesome refined hybrid...
Old 06-03-2015, 08:34 PM   #2355
CSG Mike
CSG Mike's Avatar
There's a reason the kit comes with a new MAF ring...
Old 06-03-2015, 09:07 PM   #2356
enivid
enivid's Avatar
Your Church tune? Wish I was in Cali. Would love to try it out.
Old 06-03-2015, 09:36 PM   #2357
alpax
alpax's Avatar
Drives: 2013 Subaru BRZ AT JRSC
You think another tune will fix the possible leak around MAF sensor?
Actually it should probably work, if it'd take into account the actual MAF sensor data in that condition, but I'm not sure it would be the right approach.
alpax is offline   Reply With Quote
Old 06-03-2015, 09:46 PM   #2358
CSG David
CSG David's Avatar
We've had a lot of dyno time and probably all the starting tunes that get plugged into the cars now just before refinement actually came from working on our car. In other words, you're welcome. LMAO
Delicious Tuning uses a MAP sensor and tunes via Speed Density, hence why @enivid talked about going the DT tuning route.
We do like the Flex Fuel that DT has offered to the market. We are selling the DT FF kits and have helped a few get their setups started.
The Following User Says Thank You to CSG David For This Useful Post:
alpax (06-03-2015)
Old 06-03-2015, 09:46 PM   #2359
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
I would guess a pure speed density tune (using the MAP sensor) would completely get around the problem.
The Following User Says Thank You to BigFatFlip For This Useful Post:
alpax (06-03-2015)
Old 06-03-2015, 09:59 PM   #2360
alpax
alpax's Avatar
Ah, got it. Thanks for the clarification - I missed that small detail. Now it makes sense to me.
Old 06-03-2015, 10:42 PM   #2361
dj2020
Church comes by Vegas twice a month or so and I would be interested in a more refined and mature tune that was developed with the CSG cars. Has Shawn Church worked on a flex fuel tune on your company cars? I'm concerned about getting a tune that is as drivable at low speeds/partial throttle as my current CARB tune.
My other option would be just going with the DT Flex Fuel Kit with their Flash n Go tune. Is a pure speed density tune as drivable and refined as a hybrid tune? Both types of tubes would require upgraded fuel injectors and MAP sensor?
Thanks for the insight.
dj2020 is offline   Reply With Quote
Old 06-03-2015, 11:18 PM   #2362
CSG David
CSG David's Avatar
Well it's more like he has a solid idea on the base to start with. Every car is different so if you were to ever look at the refined tunes of two identical cars, they are actually pretty different, that's not to say that the CARB tune itself is bad...it's actually cultivation of hundreds of hours on the dyno and testing on multiple cars to create that tune...
Church uses a Dynapack and that allows Church to dial in the parameters for the types of driving you will do on a daily basis and what you do on the track. Custom tune on the dyno is recommended.
DT has a good Flash and Go tune available for our cars. Driveability is good and on top of that DT is constantly refining his tunes. Hybrid (MAP & MAF) takes longer to build and may test the patience of certain people, however, Church did our tune without any issues.
Our car has the DT FF kit and is tuned by Church. He will have no issues dialing in the FF kits whether you are NA or FI.
The Following 2 Users Say Thank You to CSG David For This Useful Post:
dj2020 (06-03-2015), Jmonty (06-05-2015)
Old 06-03-2015, 11:58 PM   #2363
Xerious
Speed Chaser Thrill Seekr
Xerious's Avatar
Drives: 2014 Asphalt Monogram FR-S 6MT
I can say I'm very happy with my Church hybrid tune. No flex fuel for me yet but will consider it in the future.
Performance: Jackson Racing SC & Oil Cooler, 18x9.5 Gram Lights 57Xtreme Wheels, 255/35 Yokohoma Tires, Rays Volk Racing Black 17hex 12x1.25 lugs, KW V3 C/O, Stance Control Arms
Exterior: LED DRL MOD Kit, Tom's Tail-lights, 5%/40% tint
My Build
Xerious is offline   Reply With Quote
Old 06-04-2015, 12:17 AM   #2364
dj2020
Did you have to get a larger MAP sensor for your hybrid tune? Did you ever run with the CARB tune? Any difference in feel, drivability and power?
The Following User Says Thank You to dj2020 For This Useful Post:
Xerious (06-04-2015)
Old 06-04-2015, 01:19 AM   #2365
enivid
enivid's Avatar
Hmmmm, I'd drive to Vegas for his tune. I'll have to talk to him.
I have the JR CARB MAF tune, dyno MAF tune, 2 etune hybrid tunes, and the Delicious speed density tune. Believe it or not, the full speed density tune has been the best at low speeds/partial throttle.
The Following User Says Thank You to enivid For This Useful Post:
Old 06-04-2015, 01:31 AM   #2366
dj2020
Thanks for your insight. Just trying to figure out which direction to go with my next round of mods. With a FnG Flex Fuel tune from DT, I can just do the injector and MAP install at home, flash, and be done with it. Heck, I might even throw in a cat less header while I'm at it. But if I go with a custom tune with Church, I imagine I would have to tow my car to him when he's in town.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
