Old 06-03-2015, 12:29 PM   #2339
bear89103
Old Fart
bear89103's Avatar
Thanks once again @CSG Mike , All back to normal.
Also question for anyone... I'm getting readings of approximately -11 to 5.5 lbs of boost (measured on my Torque Pro).. does this seem low to you? the 5.5 was WOT... I'm on the CARB tune. And that tune brings it up to 7 lbs doesn't it?
Project Panda86 Journal -
bear89103 is offline   Reply With Quote
Old 06-03-2015, 12:32 PM   #2340
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
I'm seeing a max of 5.4ish on torque as well, custom tune.
Someone mentioned the stock MAP can't read higher.
In other news, made a turn and hit the gas and my car starting sputtering and barely driving and my AFRs were going crazy and the car pretty much turned itself off when I stopped.
I pretty much shit my pants... But the hose going to the TB somehow came off. I was relieved to say the least.
The Following 2 Users Say Thank You to Andrew025 For This Useful Post:
bear89103 (06-03-2015), Jmonty (06-03-2015)
Old 06-03-2015, 01:47 PM   #2341
CSG Mike
CSG Mike's Avatar
Your factory MAP sensor can read 20 psi absolute.
Boost is going to be what your MAP sensor is reading minus ambient. Sea level is about 14.7 psi, or 1 bar.
20 - 14.7 ~~ 5.5 psi.
You'll notice your 5.5 psi occurs quite a bit before redline, and as you know, your boost continues to climb as you rev higher. The boost is there; you just don't have the equipment to read it.
If you go somewhere where ambient pressure is lower, you will see a higher boost reading.
*dont* change your MAP sensor; you'll need a custom tune if you do so.
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
Andrew025 (06-03-2015), bear89103 (06-03-2015), Deadpool_25 (06-03-2015), keithr (06-03-2015)
Old 06-03-2015, 02:00 PM   #2342
CSG Mike
CSG Mike's Avatar
When you get to a safe area, take the hose off, and wipe it with a *clean* paper towel. If there's any oil at all, I recommend you get a set of catch cans for your car.
Make sure you clean the pipe and connecting hose with soap and water first to get the oil off before you put it back on, or it may pop back off from the oil.
Old 06-03-2015, 03:33 PM   #2343
alpax
alpax's Avatar
Drives: 2013 Subaru BRZ AT JRSC
Question for you... this morning while driving to work, I got a CEL. Pulled up Torque Pro and it said...
P0172 Powertrain
System too rich (Bank 1)
I was getting this periodically, turns out the MAF sensor is the most probable cause. As Mike already mentioned - clean it, and make sure the sensor is exactly vertical (for this you can slightly rotate the tube, where it's inserted). Check that the MAF sensor O-ring seals properly - it must not be damaged or crumpled. My CEL issues were fixed for a while after I slightly rotated the tube and replaced the O-ring.
Unfortunately, the P0172 came up on mine again on the weekend, and the LTFT level is again too low. I expect another CEL today or tomorrow, as it appears when LTFT reaches about -30.
While we are on this subject, does anybody know the part number for the MAF sensor O-ring? My Subaru dealer couldn't find it - said, it only comes with the sensor itself.
alpax is offline   Reply With Quote
Old 06-03-2015, 03:43 PM   #2344
Andrew025
Andrew025's Avatar
I already have the PCV side can.
Do you recommend the crank case can as well?
Everything is clean. I'm assuming it just wiggled itself lose.
Old 06-03-2015, 04:03 PM   #2345
Xuningshen
Drives: Subaru BRZ
I tried to find it, and even went to the dealer to see if their guys can find the part number, with no success.
The tech told me, it must not have an O-ring and I said no, it has an O-ring... I just came to the conclusion Subaru only sells the whole MAF "assembly" which comes with the O-ring
Still looking for a place to order 10 of those rings...
2014 WRB BRZ
Xuningshen is offline   Reply With Quote
Old 06-03-2015, 04:07 PM   #2346
alpax
alpax's Avatar
Same here.
Just called Scion/Toyota - they don't know it either.
Only have the whole sensor assembly on their part list.
I've found one for Corolla, but not sure if it will fit.
@CSG Mike: You guys should have these O-rings available. Is there a part number?
Old 06-03-2015, 05:42 PM   #2347
Xuningshen
Drives: Subaru BRZ
Same here.
I tried to find random ones at home depot but they're too thick...
Mike offered to send me an O-ring, which was very nice, but I want to buy a bunch of them haha... I like having extra parts laying around the garage.
2014 WRB BRZ
Old 06-03-2015, 06:47 PM   #2348
Jackson Racing
Jackson Racing's Avatar
Drives: JR FR-S,
MAF O-Rings? We might have them.
You shouldn't have to clean your MAF very often. Make sure your PCV valve and MAF are oriented properly. The MAF should not be tilted to one side or the other. Also make sure there are no aftermarket electronics in your engine bay that could alter with the MAF signal.
-Oscar Jr.
Jackson Racing is offline   Reply With Quote
The Following 2 Users Say Thank You to Jackson Racing For This Useful Post:
alpax (06-03-2015), Xuningshen (06-03-2015)
Old 06-03-2015, 07:35 PM   #2349
alpax
alpax's Avatar
Excellent! Can we order from you?
-Oscar Jr.
Well, I wouldn't touch the MAF if I hadn't got the P0172 error. Last time fiddling with the MAF seemed to fix the issue, but now it's back. I'm still using the stock O-ring, and it seems to be a bit stretched. Last time I tried to use the one which came with the kit, but it didn't help, and when I removed it I found it's slightly damaged - not sure if it's a defect, or it was somehow damaged during the installation.
Anyway, I'd like to put a new O-ring for a proper seal - hope this will fix the P0172.
Old 06-03-2015, 08:16 PM   #2350
CSG Mike
CSG Mike's Avatar
PM me your mailing address and I will send you one on the house.
alpax (06-03-2015), Jackson Racing (06-03-2015)
Old 06-03-2015, 08:17 PM   #2351
CSG Mike
CSG Mike's Avatar
Anything blowing oil into the intake tract is from the crankcase side.
If the tube is clamped down properly, it cannot wiggle itself loose; the throttle body has a small lip on the upper portion to assist in keeping the tube on.
Old 06-03-2015, 08:18 PM   #2352
CSG Mike
CSG Mike's Avatar
Same here.
I don't know the part numbers.... I just (personally) have spares.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
