Drives: Blue
Just bought my N1 exhaust. How easy is the install?
Hey guys just bought my invidia n1 exhaust. I am pretty noob when it comes to installling stuff on cars.
what tools will i need for this type of job? would anyone be able to explain the installation process? thank you Last edited by Thet; 06-03-2015 at 01:30 AM. |
#2 |
Drives: 14 Ultramarine FR-S
PB Blaster. Couple ratchets, couple sockets.
2014 Ultramarine Scion FR-S 2000 Integra LS - SOLD ![]() |
#3 | |
Just let down the back of the back seat, place exhaust inside, drive up to your local auto shop and have them install it. Have a cup of coffee and read a car magazine. They will have it installed before you finish your cup of coffee. Pay them about $35, then drive around and be amazed as to how much faster your car is (or at least sounds). No tools, no laying on a cold , hard concrete floor, no skinned knuckles ….. ![]() humfrz |
#4 |
Bilge monkey
Drives: '13 BRZ, 82 starlet
i'll be the first helpful poster (depending on how many people post while i'm typing)
if you ever want to swap back, there's an amazing tool to help remove exhaust hangers. ![]() these pliers are totally worth the cost. basic hand tools needed otherwise. buy the tools, and be the exhaust-install-guru on your block, charge $35 each time, and pay off your new pliers on install 1. (check amazon for the plier) look up exhaust hanger pliers |
#5 |
Drives: Blue
#6 |
http://www.ft86club.com/forums/showthread.php?t=24139
I used that diy. Should be all the info you need.
#7 |
Drives: 2013 10-Series FRS, 1993 Yota
unbolt stock exhaust, bolt on new exhaust. start car, check for leaks. done
#8 |
Drives: GT86 Aero
I'm a noob at mods and I installed the N1 all by myself.
I used WD40, ratchet and spanner. I put the car up on self made wooden/brick ramps. The most difficult bit is getting the OEM exhaust off the rubber brackets that hold it. That's where you need WD40 and to push the brackets/mounts side to side to losen them up. Everything else is pretty easy to figure out. I installed the N1 in sections, losely connecting them to the hangers and each other before aligning them and torquing them up. You have to re-use the OEM gasket and bolts/springs that connect to the cat (the very front of the section you'll be working on). I would advise having a 2nd person to help you, but it isnt necessary. |
#9 | |
Drives: Fast
I just do it by hand and no tool is needed if you use a lubricant on the hangers. |
#10 |
Granny Shifter
Drives: 2014 FR-S
Everybody else has basically covered everything. Most importantly take your time and don't rush as to make sure you do everything properly. If it takes you a little longer don't freak out. Everybody had to start and learn at some point so we've all been there. Good luck, have fun!
| The Following User Says Thank You to MokSpeed For This Useful Post: | RobertPaulson (06-22-2015) |
#11 | |
Back in the day, some of us learned when our cars were parked in the barn, on a dirt floor, with nothing for light but a kerosene lantern, below 0 degrees F, with snow blowing under the door, rats attacking our toes, using old, rusty monkey wrenches ...... ![]() Someone just shoot me ...... ![]() humfrz Last edited by humfrz; 06-03-2015 at 02:15 PM. |
#12 | |
Drives: 2014 BRZ Limited
My dad has all kinds of tools like that that you can't buy anywhere because my grandfather just made what he needed. My dad and brother just recently restored the lathe and have been making some of their own tools just for fun. |
| The Following User Says Thank You to extrashaky For This Useful Post: | humfrz (06-03-2015) |
#13 | |
Drives: 2015 Firestorm Scion FRS
| The Following User Says Thank You to G-awesome For This Useful Post: | Bergen23 (06-22-2015) |
#14 | |
Drives: FRS
| The Following User Says Thank You to 8R6 For This Useful Post: | Bergen23 (06-22-2015) |
| Another Nexus 7 install: Clean and Easy | Sojhinn | Electronics | Audio | NAV | Infotainment | 264 | 10-30-2015 09:26 AM |
| EZCarLift Easy car lift portable super easy car lift | bren5279 | Mechanical Maintenance and Tools | 16 | 09-11-2015 02:57 PM |
| Any Really Good Exhaust Shops in Easy Bay?? | F1fletch | Northern California | 5 | 02-17-2015 09:51 PM |
| FI Guys: Were you more excited when you bought your car, or when you bought boost? | husker741 | Forced Induction | 28 | 02-25-2014 04:57 PM |
| Forester XT/Legacy GT exhaust tips on the twins stock muffler (easy/cheap option) | Kostamojen | Engine, Exhaust, Transmission | 8 | 09-08-2013 02:36 PM |
