Old 06-03-2015, 01:54 PM   #43
SeanD06
SeanD06's Avatar
Drives: Fr-S 2015
Originally Posted by FRSBRZGT86FAN View Post
Issue is completely fixed they replaced the TCM and reseated all the connections to it as well as reset my ecu and flashed the latest OEM firmware. I am now running oft stage 1 93 octane tune with no issues.
I just got back my Fr-S from the dealer, even if they saw the problem they won't help me because there's no check engine light on -_-... do you have by any chance the detailed invoice with the work they did on your car so I can show them how to fix my car? My dealer is really the worst dealer I've seen
SeanD06 is offline   Reply With Quote
Old 06-03-2015, 02:01 PM   #44
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Go to another dealer. Each dealership is independently owned.
N1rve
Old 06-03-2015, 02:32 PM   #45
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Will do later, but the important thing you MUST do is ask to drive with the tech to show him the problem, there's a tendency for the asshats at the desk through no fault of there own right a small little note like "transmission doesn't downshift" and the tech isn't sure about what the actual issue is. The dealer invoice basically says TCM replaced, reset and ask cables been reseated as to OEM spec and ecu code cleared
Old 06-03-2015, 03:41 PM   #46
SeanD06
SeanD06's Avatar
Drives: Fr-S 2015
That's what I did with my dealer and they told me it's normal-_- They told me that it was based on how I drive... So according to them an automatic car that stalls, give a knock on a shift and compress at a point where the wheel locks is normal... Friday I'm going to see another dealer hopefully they'll fix it!
Old 06-03-2015, 03:57 PM   #47
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Try another dealer, if not maybe then try Scion Canada direct....
Make sure you have a video if you can capture it
drewbot is offline   Reply With Quote
Old 06-11-2015, 11:15 AM   #48
OpteronO3
Drives: 2013 Scion FRS
Hey guys I'm new to the forum and a new owner of a 2013 FRS! I've been keeping an eye on this thread due to recently experiencing something strange with my Automatic Transmission... Hoping I could get some help since this issue sounds similar.
Anyways, just to get clarification on this AT issue. I'm crusing at 40mph on 6th gear. I downshift to 4th in regular mode and it'll "not catch" 4th gear until I let go of the throttle. Until I let go of the throttle it'll shift aggresively into 4th gear. If I don't let go of the throttle long enough it'll just keep revving.
Is this a similar to what you're experiencing? or is mine a whole different situation?
Please excuse my rookie terminology.
OpteronO3 is offline   Reply With Quote
Old 06-11-2015, 11:44 AM   #49
FRSBRZGT86FAN
Slightly different issue yours sounds like a serious slip, it could still be a TCM issue
Sent from my A0001 using Tapatalk
Old 06-11-2015, 01:44 PM   #50
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
Hmmm I do this all the time (6th to 4th) so I can pass other cars. RPM instantly shoot up right as I hit 5th and 4th. Never needed to let off of the throttle. Maybe some 2013 owners can chime in.
The Twins make me smile
Old 06-11-2015, 02:30 PM   #51
OpteronO3
TCM is the transmission control module correct? Yeah it definitely feels like a major slip issue. I think I will open a different thread for this so I don't high jack your thread. Thanks for your help!
New Thread
I understand the RPM’s would go up when down shifting, but my car won’t move when this issue happens until I let go of the throttle. Then it’ll get into gear and accelerate normally.
Old 06-18-2015, 03:57 PM   #52
SeanD06
SeanD06's Avatar
Drives: Fr-S 2015
@FRSBRZGT86FAN The other dealer also think its normal those problem... Would it be possible for you to send me the detailed invoice of what your dealer did to your car? That would definitety help me!
Old 06-18-2015, 07:01 PM   #53
FRSBRZGT86FAN
I'm really sorry I've been busy with work I'm scanning the invoice now, and I'll edit out all the stuff with my personal info
Old 06-18-2015, 07:55 PM   #54
FRSBRZGT86FAN
So I've edited it a bit and highlighted TCM up a bit for you to see
Old 07-14-2015, 11:06 AM   #55
SeanD06
SeanD06's Avatar
Drives: Fr-S 2015
Hey! i'm still having the issue since the both car dealers don't want to help. I am now in contact with the Owner of one of the dealer and I tried to acces to your invoice but I can't see it canyou help me out please!
Old 07-14-2015, 12:38 PM   #56
FRSBRZGT86FAN
Its an imgur link not sure where your issue is arising from
Can't downshift while warming up HMX-92 Issues | Warranty | Recalls / TSB 25 12-20-2014 02:20 PM
Rev match downshift possible with OFT Simon99 Software Tuning 24 08-17-2014 04:20 PM
downshift to first swpbrz Engine, Exhaust, Transmission 13 05-07-2014 08:33 PM
6th to 5th Downshift Crunch jcat5150 Issues | Warranty | Recalls / TSB 1 04-17-2014 03:41 PM
Downshift rattle?? driftartist Issues | Warranty | Recalls / TSB 17 08-03-2013 10:00 AM
