Old 06-03-2015, 12:32 AM   #1
Thet
Drives: Blue
Just bought my N1 exhaust. How easy is the install?
Hey guys just bought my invidia n1 exhaust. I am pretty noob when it comes to installling stuff on cars.
what tools will i need for this type of job?
would anyone be able to explain the installation process?
thank you
Thet is offline   Reply With Quote
Old 06-03-2015, 12:38 AM   #2
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
PB Blaster. Couple ratchets, couple sockets.
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 06-03-2015, 01:14 AM   #3
No tools required.
Just let down the back of the back seat, place exhaust inside, drive up to your local auto shop and have them install it.
Have a cup of coffee and read a car magazine. They will have it installed before you finish your cup of coffee. Pay them about $35, then drive around and be amazed as to how much faster your car is (or at least sounds).
No tools, no laying on a cold , hard concrete floor, no skinned knuckles …..
The Following 4 Users Say Thank You to humfrz For This Useful Post:
86geek (06-22-2015), kch (06-03-2015), NWFRS (06-03-2015), stevemp5 (06-03-2015)
Old 06-03-2015, 01:18 AM   #4
Sammakko
Bilge monkey
Sammakko's Avatar
Drives: '13 BRZ, 82 starlet
i'll be the first helpful poster (depending on how many people post while i'm typing)
if you ever want to swap back, there's an amazing tool to help remove exhaust hangers.
these pliers are totally worth the cost.
basic hand tools needed otherwise.
buy the tools, and be the exhaust-install-guru on your block, charge $35 each time, and pay off your new pliers on install 1. (check amazon for the plier)
look up exhaust hanger pliers
Sammakko is offline   Reply With Quote
The Following 5 Users Say Thank You to Sammakko For This Useful Post:
8R6 (06-03-2015), Bergen23 (06-22-2015), DuMa (06-03-2015), D_Thissen (06-23-2015), Jrryjms07 (06-03-2015)
Old 06-03-2015, 01:30 AM   #5
Thet
Drives: Blue
would you be able to briefly explain the install process?
thanks
Old 06-03-2015, 01:33 AM   #6
Phantobe
Phantobe's Avatar
thanks
http://www.ft86club.com/forums/showthread.php?t=24139
I used that diy. Should be all the info you need.
Old 06-03-2015, 08:21 AM   #7
Jake360
Jake360's Avatar
Drives: 2013 10-Series FRS, 1993 Yota
unbolt stock exhaust, bolt on new exhaust. start car, check for leaks. done
Jake360 is offline   Reply With Quote
Old 06-03-2015, 08:22 AM   #8
ShackontheTarget
ShackontheTarget's Avatar
Drives: GT86 Aero
I'm a noob at mods and I installed the N1 all by myself.
I used WD40, ratchet and spanner.
I put the car up on self made wooden/brick ramps. The most difficult bit is getting the OEM exhaust off the rubber brackets that hold it. That's where you need WD40 and to push the brackets/mounts side to side to losen them up.
Everything else is pretty easy to figure out. I installed the N1 in sections, losely connecting them to the hangers and each other before aligning them and torquing them up. You have to re-use the OEM gasket and bolts/springs that connect to the cat (the very front of the section you'll be working on).
I would advise having a 2nd person to help you, but it isnt necessary.
ShackontheTarget is offline   Reply With Quote
Old 06-03-2015, 10:27 AM   #9
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
Make sure you're using the silicon spray version of WD-40 and not regular WD-40. That will cause the hangers to crack over time.
I just do it by hand and no tool is needed if you use a lubricant on the hangers.
2016 Camaro SS is offline   Reply With Quote
Old 06-03-2015, 11:05 AM   #10
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
Everybody else has basically covered everything. Most importantly take your time and don't rush as to make sure you do everything properly. If it takes you a little longer don't freak out. Everybody had to start and learn at some point so we've all been there. Good luck, have fun!
MokSpeed is offline   Reply With Quote
The Following User Says Thank You to MokSpeed For This Useful Post:
RobertPaulson (06-22-2015)
Old 06-03-2015, 11:29 AM   #11
Good point.
Back in the day, some of us learned when our cars were parked in the barn, on a dirt floor, with nothing for light but a kerosene lantern, below 0 degrees F, with snow blowing under the door, rats attacking our toes, using old, rusty monkey wrenches ......
Someone just shoot me ......
Old 06-03-2015, 03:49 PM   #12
extrashaky
Drives: 2014 BRZ Limited
You might appreciate this: The best jack stands I have ever used were my grandfather's. He made them out of a couple of Model A axles. He machined the shafts and pins on his own lathe and welded the pieces together. He used to raise up his cars on those things on the dirt in the back yard without any worry at all because the bases were so wide that they were stable on practically any level surface.
My dad has all kinds of tools like that that you can't buy anywhere because my grandfather just made what he needed. My dad and brother just recently restored the lathe and have been making some of their own tools just for fun.
The Following User Says Thank You to extrashaky For This Useful Post:
humfrz (06-03-2015)
Old 06-03-2015, 04:30 PM   #13
G-awesome
Drives: 2015 Firestorm Scion FRS
psssh...forget tools for hangers...I installed my trd exhaust over the weekend with my buddy and his dad and we used wd40, muscles, and sweat to get those suckers off! :P (........buuuuuuut those would've been useful)
G-awesome is offline   Reply With Quote
The Following User Says Thank You to G-awesome For This Useful Post:
Old 06-03-2015, 05:17 PM   #14
8R6
8R6's Avatar
Drives: FRS
thats badass. i've always used just a long flathead and lots of elbow grease and even more cussing. this tool wouldve made it so much quicker lol
8R6 is offline   Reply With Quote
The Following User Says Thank You to 8R6 For This Useful Post:
Another Nexus 7 install: Clean and Easy Sojhinn Electronics | Audio | NAV | Infotainment 264 10-30-2015 09:26 AM
EZCarLift Easy car lift portable super easy car lift bren5279 Mechanical Maintenance and Tools 16 09-11-2015 02:57 PM
Any Really Good Exhaust Shops in Easy Bay?? F1fletch Northern California 5 02-17-2015 09:51 PM
FI Guys: Were you more excited when you bought your car, or when you bought boost? husker741 Forced Induction 28 02-25-2014 04:57 PM
Forester XT/Legacy GT exhaust tips on the twins stock muffler (easy/cheap option) Kostamojen Engine, Exhaust, Transmission 8 09-08-2013 02:36 PM
