Old 05-12-2015, 02:46 AM   #1037
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by yomny View Post
Question.. do our cars or ecutek tunes for our cars implement any logic to factor in temp changes to adjust open loop AFR at WOT? Just wondering.. I know your tunes use closed loop which would run ideal AFR all the time
@sales@delicioustuning.com
Yes, there are actually a few compensation tables that will alter both fueling and timing based on several different environmental factors, temperature included. However, it's not nearly as precise as closed loop correction is.
Sincerely,
The Following User Says Thank You to DeliciousTuning For This Useful Post:
yomny (05-12-2015)
Old 05-12-2015, 06:20 PM   #1038
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Sincerely,
Zach
Looking forward to your tune!, just pulled the trigger.
PS- Thanks for your support and showing your face around the forum so much, also replying to emails so promptly.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
The Following 2 Users Say Thank You to yomny For This Useful Post:
xxscaxx (05-13-2015)
Old 05-12-2015, 06:44 PM   #1039
DeliciousTuning
Thank you for YOUR support sir, we're more than happy to provide a tune for your vehicle.
Can you email me as to whether your JDL kit has the BOV on the end tank or the charge pipe btw? Slightly different tune depending on that tidbit and I don't recall if you mentioned it before.
Sincerely,
yomny (05-12-2015)
Old 05-12-2015, 09:06 PM   #1040
yomny
yomny's Avatar
Sincerely,
Zach
E-mailed.
The Following User Says Thank You to yomny For This Useful Post:
Old 05-25-2015, 06:41 PM   #1041
kster1
kster1's Avatar
We're working on finalizing a new version of both the Flash & Go tunes and the NA tunes we have. All a part of the continuous improvement our tunes go through. While they aren't ready for release quite yet, they should be soon.
Did these new NA tunes get released? If not, did you guys change your mind and cancel the update? Just wondering because it's been a few months. Thanks.
kster1 is offline   Reply With Quote
Old 05-30-2015, 11:56 AM   #1042
ramosryan
Drives: Frs 10 series
Can someone explain how the Flex fuel software works? I see you have up to 4 maps for ecutek tune, now does the flex fuel use the 3 e85 transition tunes? Do you have to switch between maps for flexfuel or does computer do it for you? I was under the impression with flex fuel set up all you do is fill up with whatever and drive. Im not sure if you need to switch tuning maps or what?
ramosryan is offline   Reply With Quote
Old 05-30-2015, 12:20 PM   #1043
Kodename47
Kodename47's Avatar
Drives: UK GT86
It's independent from the map switching. Flexfuel uses an ethanol content sensor which ECUtek takes the output and adjust the current tune accordingly. In theory you could have flexfuel enabled in any/all/none of the 4 mapswitch modes.
.: Stealth 86 :.
Kodename 47 DJ:
ramosryan (05-31-2015)
Old 05-31-2015, 11:29 AM   #1044
ramosryan
so I do not need to get e85 transition maps when I purchase my base tune on 93 octane, just kit flexfuel tune when I purchase kit?
Old 06-01-2015, 03:39 PM   #1045
DeliciousTuning
That's correct. E85 transition maps are for those without Flex Fuel kits. We actually plan on removing this option as it gets too inaccurate with varying ethanol content in the tank.
Sincerely,
ramosryan (06-02-2015)
Old 06-02-2015, 11:49 PM   #1046
DeliciousTuning
The app has been released as a production ready version and is now available through the Google Play Store. Just search for "Ethanol Content Analyzer"
Cheers,
William Knose
The Following 2 Users Say Thank You to DeliciousTuning For This Useful Post:
civicdrivr (06-03-2015), Ethan (06-03-2015)
Old 06-03-2015, 10:44 AM   #1047
brianhj
Drives: 2017 Camaro 1SS
Yayyyyyy
This is 3/4 tank 93oct and 1/4 tank e85
brianhj is offline   Reply With Quote
The Following User Says Thank You to brianhj For This Useful Post:
Old 06-09-2015, 11:06 PM   #1048
Ethan
Drives: Subaru BRZ
Bill and Zachary, I just wanted to say that I love your flex fuel kit. The car runs sooooo smooth on e85. The engine loves it. This may seem odd, but the clutch is easier to engage when I am running e85. It is a clutch masters 300 and it is really grabby when running 91. With e85 it is much easier to drive in traffic.
Ethan is offline   Reply With Quote
The Following User Says Thank You to Ethan For This Useful Post:
Old 06-13-2015, 03:02 PM   #1049
spdfreak
spdfreak's Avatar
Drives: GBS BRZ Limited
Hey guys, just loaded your stage 2 NA tune on my BRZ and I can't seem to get map switching to work. So far I've tried turning the car on and pulling back on the cruise control stalk but the tac needle never moves.
Is that something you have to have that RaceROM software for?
spdfreak is offline   Reply With Quote
Old 06-13-2015, 03:07 PM   #1050
DeliciousTuning
You don't need the RaceROM upgrade for those features; can you email me at sales@delicioustuning.com.com with your full name and your order number? Thanks!
Sincerely,
Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 24 09-20-2013 03:04 PM
Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-19-2013 05:58 PM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 05:55 PM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 01:34 AM
Delicious Tuning and HG Motorsports: 86Fest Only Special - Take $100 off EcuTeK DeliciousTuning Announcements, Contests, Giveaways 5 08-26-2013 02:33 PM
