Old 05-30-2015, 05:06 PM   #15
iJeff
iJeff's Avatar
Drives: 2016 Raven FR-S
Originally Posted by RWfan View Post
Which HIDs did you use, and what colour temperature + wattage are they?
iJeff is offline   Reply With Quote
Old 05-30-2015, 10:10 PM   #16
RWfan
RWfan's Avatar
Drives: '13 Scion FR-S
its almost identical...
35w 5k bulb / 35w HID ballast
cheers
RWfan is offline   Reply With Quote
Old 06-16-2015, 09:30 AM   #17
Fang
Fang's Avatar
Drives: '13 Asphalt FR-S
cheers
RWFan, seriously i was getting so frustrated that the mod didn't work, thanks for posting this! just fixed it this weekend
Fang is offline   Reply With Quote
Old 06-24-2015, 02:36 AM   #18
RWfan
RWfan's Avatar
trust me when i say this, i was literally pulling my hair from frustration before figuring this out. glad i could help
Old 06-24-2015, 02:58 AM   #19
RWfan
RWfan's Avatar
Originally Posted by tim.earles View Post
I would like to sincerely thank RWfan for this howto. Earlier today I got my lights to work as expected and I could not be happier.
Thanks again RWfan!
Old 09-29-2015, 05:25 PM   #20
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Thanks again RWfan!
thanks so much for posting this! I bought the same kit on ebay thinking it was the ft86 kit. the seller is terrible as far as customer service and selling a kit that doesn't work 100%? thankfully i have hope now, i just ordered fogs so i'll hopefuly fix my winjets while i'm installing my fogs. thanks guys!
this DIY is for this product.
here's the link:
http://www.ebay.com/itm/SCION-FR-S-W...-/191335866653
Attachment 107984
i thought i was getting the FT86 product for a third of the price but after watching their video, that's when i realized that i did not...
...ill spare you the details on how i got it working and just show the results.
OK, this product came with an installation guide. STEP 1, STEP 2 and STEP 3. i need you to put a pause on this for now. we will incorporate both guides(eBay & FT86) to complete this install.
Attachment 107989
the main difference between these two products is that the FT86 model came with an extra pin and the eBay item did not. you are going to need those missing pins so lets start.
what you need to do is to pay close attention of this segment(0:09 - 0:23) of the video from FT86. this will show you how to take the pin out of the harness.
you need to get your stock(OEM) headlights and look for the harness that is similar to the Winjet harness as shown on the video. you are going to unpin two of these wires. the picture below is the harness that came from the stock headlights.
Attachment 107985
make the cut at least giving you four inches of slack from the pin to give you extra room to work with. this was painful for me to do but essential unless you can get a hold of these pins somewhere else.
Attachment 107986
you will notice that there's a brown rubber grommet on the pin that came from your stock headlights. do not worry about this for it will just slide back out when your about to install it. you'll know what i'm talking about after watching the video again.
Attachment 107987
you are now going to splice one of the wires where you made the cut on the end of the white wire to the eBay harness using the red wire tap provided as illustrated below or you can do the cleaner look...ie.solder & heat shrink.
Attachment 107988
repeat process on the other harness...
time for the install.
looking back on the FT86 video, do exactly what the video is showing from start up to 0:57. the provided pin is the pin we took from the stock headlight.
looking back at the installation guide that came with the harness from eBay. follow STEP 1 & STEP 2. do not and i repeat DO NOT follow STEP 3.
start the engine and give it a test before tucking everything in place.
CONGRATULATIONS, you have now finished the install.
Attachment 107990
Hey guys @fteightysix is using a similar
Attachment 107991
i wanna say thanks for the video #fteightysix has provided us.
this could not have been possible for me to accomplish.
@fteightysix is using a similiar mod now, and I spoke to Thomas who did a wonderful job explaining it and couldn't find any issues installing it on lights he had there. You can follow the given instructions on the paper that comes, using pins or what they use, just make sure all the butt connections are properly done and don't forget to switch the red and black wires that go to the connector that connects to the car. Step 3 should work fine if the aforementioned step is followed.
Old 12-06-2015, 09:48 PM   #21
86SPEED
86SPEED's Avatar
Drives: The silvertrooper 10 series
Ok guys - We did a little more digging into this new mod - And want to thank @RWfan for what he showed you guys already.
Let me first explain why we do not offer the mod with the pin or make them available with winjetd pre- installed -
The main reason was 1. availability of the pins and 2. The time to do the Mod - It took us too long and too much time to unbox the lights solder up the mod and rebox the mod and get it shipped back out - That might sound simple but it was taking away from our customer service and shipping your orders fast -
By offering the DRL Mod like this and us not building every one ourself we can ship orders faster and drop ship from Winjet if we are in between stock orders Plus it is cheaper cost for you and projects with Friends are fun.
The catch and why we always switched the pins around is that Winjet actually has the colors of to of the wires different vs what the out puts are on the factory wires - no this really does not matter in most cases since a LED or a bulb only needs a 12 Volt and a ground and polarity does not matter
The Pin was also added to an additional spot on the plug to get power from the running light to keep the DRL on during headlight operation
Here is the video for the correct instructions
[ame="https://www.youtube.com/watch?v=_AN2bjUhMOE"]WINJET DRL MOD V2 - YouTube[/ame]
Thanks
Malen
86SPEED is offline   Reply With Quote
Old 02-03-2016, 01:39 PM   #22
pleong
Drives: 2013 Whiteout FR-S
Thanks
Malen
Would you happen to know how I can do this same mod, but with switchbacks to use as turn signals?
TEAM NEMESIS | NEM 86 | IG: @NEM_86
PTE5858 Turbo | Integrated Engineering Fuel Surge Tank | 1300cc Injectors | Exedy Twin Disc | RAYS Volk ZE40 | 295/30/18 | 522whp @ 6,600 Dyno Dynamics
The NEM86 Build Thread
pleong is offline   Reply With Quote
Old 02-04-2016, 11:16 PM   #23
Manic
Is not fast.
Manic's Avatar
Drives: 2014 Whiteout M/T
Pretty interesting OP, I actually want the issue you had if I bought winjets. I ONLY want the DRL strip to be on while the low-beams are.
I generally can't stand having DRLs on all the time which is why I disabled the stock ones almost immediately.
"America is all about speed. Hot, nasty, badass speed." - Eleanor Roosevelt, 1936
Manic is offline   Reply With Quote
Old 02-07-2016, 01:59 AM   #24
illmatic_frs
illmatic_frs's Avatar
Drives: n/a
@fteightysix in the new video what kind of diode is required? Looks like there are two of them
Sent from my HTC One M9 using Tapatalk
illmatic_frs is offline   Reply With Quote
Old 03-09-2017, 11:42 PM   #25
FRSToyota86
FRSToyota86's Avatar
Drives: 2013 Scion FRS
I did everything as you show in the v2 diy vid, however only the low beams work on both sides, highbeam and drl won't turn on at all. I have checked continuiti no problems in the solders. I tested the circuit and the drl works fine.
All I can say is its so wierd...
Thanks
Malen
Vortech V3 Supercharger| 12 PSI|E85 MotoEast Flexfuel kit|Crawford AOS| Mishimoto Oil Cooler|3"Perrin Resonated CBE| 3" JDL Front/Over Pipe|OpenFlash Performance Headers|Exedy Stage 2 Ceramic Clutch |Yonaka Coilovers|17x9 O.Z. Wheels| 245/40r/17|TRD Brake Pads|Perrin Master Cylinder Brace |ChaseBay SSBrake Lines|CF Side Fins|OEM Shark Fin Athena|Yospeed Console Plaque|R/T Shift Knob|Fog Lights|Backup Camera|Navigation| |TRD Quickshifter|Motul Gear Oil|
FRSToyota86 is offline   Reply With Quote
Old 02-08-2018, 08:13 PM   #26
adamskilla
adamskilla's Avatar
Thanks
Malen
@86SPEED
The instructions I got from your site do not indicate anywhere to cut the black wire and marry it with the red wire from the mod kit. So I wired everything exactly like the instructions say to (red to red). By doing it this way my DRL strips only turn on with the lowbeams. SO, do you think that just re pinning the black and red on the connector will alleviate this issue?
I'm not an electrical genius so maybe I'm missing something. Just kind of frustrating since I don't feel like taking the lights out again and changing all the wiring at this point. If it's just swapping pins from the connectors I should be able to do so without taking the lights out.
Also, it's 2018... Why were the instructions not changed to reflect this yet?
Should also note that I have installed the Morimoto 5500k HID as well.
Thanks,
Adam
adamskilla is offline   Reply With Quote
Old 02-08-2018, 08:25 PM   #27
adamskilla
adamskilla's Avatar
here's the link:
Attachment 107984
Attachment 107989
Attachment 107985
Attachment 107986
Attachment 107987
Attachment 107988
Attachment 107990
Attachment 107991
@RWfan
I got my mod kit directly from ft86, it did not come with a pin connector.
DIY: Winjet DRL Always-on l0aded DIY (Do-It-Yourself) Guides 5 04-03-2016 06:41 PM
WINJET HID'S 5AD86D Cosmetic Modification (Interior/Exterior/Lighting) 1 03-26-2015 09:50 PM
Winjet Questions 636 Cosmetic Modification (Interior/Exterior/Lighting) 1 11-08-2014 07:12 PM
WTT: Winjet Black Headlight for Winjet chrome dezmoondo Exterior Parts (Aero, Lighting, Etc.) 0 04-13-2014 03:02 AM
Custom Purple Winjet and Black Winjet Headlights xclusive_brett Cosmetic Modification (Interior/Exterior/Lighting) 35 12-17-2013 08:28 AM
