Old 05-29-2015, 10:58 AM   #1
Spacemane969
Spacemane969's Avatar
Drives: 2013 ARGENTO A/T
Normal amount of rust for a 13?
Over all the car is super clean, engine is flawless, not a spec. However looking under the rear this caught my eye.
Is this something I should be concerned about purchasing?
Thanks
Spacemane969 is offline   Reply With Quote
Old 05-29-2015, 11:00 AM   #2
SillySaxon
SillySaxon's Avatar
Drives: Sc10n Series FR-S
No, mine looked a lot worse and it's also a 2013.
That stuff under there is not stainless.
I figure as long as you smile while driving the car, you're doing it right.
SillySaxon is offline   Reply With Quote
Old 05-29-2015, 11:02 AM   #3
Thanks
Wouldn't let that worry me one little bit. The combo of heat and moisture causes exhaust systems to rust even with the best. Easy and relatively cheap to replace when they get real bad.
The rest of the parts in the pic look super clean!
Old 05-29-2015, 11:22 AM   #4
HunterGreene
Hail Magnet
HunterGreene's Avatar
OP: You're fine, trust us northerners.
Side story--Years ago, my sister moved to Las Vegas from Cleveland, and took her 1999 Ford Escort cross country. I've heard some had reliability problems, but I had one as well and they were tanks. She and my parents had the car checked over and repaired stem to stern, and it was in as good a shape as possible when she left.
She made it there fine, fast forward a couple months when she took her car in for an oil change and scheduled maintenance, and received a frantic phone call an hour later that the mechanics were convinced the car was totaled due to being "rusted out." They actually refused to work on it for fear of breaking it! These geniuses had never seen what a few northern winters will do to a car, and had to actually talk to a mechanic back here to convince them that the car was safe to work on and roadworthy. We all got a good laugh out of that one.
It has priests in it?
The Following 5 Users Say Thank You to HunterGreene For This Useful Post:
brandonblt2 (05-29-2015), Gunman (05-29-2015), humfrz (05-30-2015), strat61caster (05-30-2015), Tcoat (05-29-2015)
Old 05-29-2015, 11:30 AM   #5
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
That's like one month's worth of winter and salt
OP don't worry about it
drewbot is offline   Reply With Quote
The Following User Says Thank You to drewbot For This Useful Post:
Tcoat (05-29-2015)
Old 05-29-2015, 11:37 AM   #6
TheVoiceOfReason
TheVoiceOfReason's Avatar
Drives: BRZ Limited
It is still stainless, just not T304 like good aftermarket exhausts. Probably T409.
TheVoiceOfReason is offline   Reply With Quote
Old 05-29-2015, 11:38 AM   #7
NOHOME
Drives: RAVEN
I give these cars 10 years in the salt-belt until they are done.
NOHOME is offline   Reply With Quote
Old 05-29-2015, 11:39 AM   #8
Even the good ones will rust (or at least oxidize) eventually. Stainless is a great name but not a truly accurate description.
HunterGreene (05-29-2015), ricky rod (05-29-2015)
Old 05-29-2015, 11:42 AM   #9
Spacemane969
Thanks so much for the reassurance guys. Much appreciated!
The Following User Says Thank You to Spacemane969 For This Useful Post:
Tcoat (05-29-2015)
Old 05-29-2015, 11:44 AM   #10
gramicci101
Off Topic
Stain-resistant steel doesn't sound as good.
Old 05-29-2015, 11:45 AM   #11
Better than "guaranteed to stain if you piss on it steel"
Old 05-29-2015, 11:52 AM   #12
gramicci101
Off Topic
Why are you pissing on your exhaust pipe?
Old 05-29-2015, 11:54 AM   #13
There are better places?
We just had to replace all the stainless panels in the washroom at work since several were eaten right though from piss. Apparently our guys have accuracy issues.
Old 05-29-2015, 11:54 AM   #14
HunterGreene
Hail Magnet
Or "Its gonna change color and look like rust after you get it really hot a few times" steel.
The Following User Says Thank You to HunterGreene For This Useful Post:
Tcoat (05-29-2015)
Undercarriage (exhaust piping) rust, normal? gonzalj1 BRZ First-Gen (2012+) — General Topics 18 09-21-2015 01:22 AM
Normal amount of corrosion on brake calipers? Annahra Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 08-05-2014 03:19 PM
Rust? even with rust proofing? Chinadian Issues | Warranty | Recalls / TSB 8 01-26-2013 04:15 PM
