Old 09-25-2014, 06:05 PM   #57
kh060
Drives: FR-s Ignition
Does it have to be soldered? Or can I just use a wire nut?
kh060 is offline   Reply With Quote
Old 10-15-2014, 02:04 AM   #58
Top-Secret
Drives: FRS monogram
Does it matter which end of resistor the diode goes
Ie. Pin 5 - resistor - diode - pin 1
Or pin 5 - diode - resistor - pin 1
Top-Secret is offline   Reply With Quote
Old 04-16-2015, 05:16 PM   #59
cdo221
Drives: 2013 Ultramarine FR-S, 2015 RS 1.0
Is there a specific reason why you need a 10 watt resistor? Would something like a 6 ohm 50 watt resistor work as well?
cdo221 is offline   Reply With Quote
Old 04-17-2015, 06:56 PM   #60
Diode Dynamics
Diode Dynamics's Avatar
Hey guys! Plug-and-play adjustable modules now available. Pictures coming soon. Thanks!
http://www.diodedynamics.com/store/c.../category/814/
John C.
Diode Dynamics
Old 04-17-2015, 07:27 PM   #61
STV3
Señor Member
STV3's Avatar
How about for the few of us that installed the Monogram/10 series lights on a base FRS. Right now the LED strips come on at full brightness with the corners and stay on at full brightness with the headlights. Need to tone these bad boys down for night time.
STV3 is offline   Reply With Quote
Old 05-28-2015, 06:42 PM   #62
Top-Secret
Dear @Diode Dynamics
please get this back in stock
yours truely.
someone who pays to much in shipping because i always find new things that i want AFTER i buy stuff from you
Old 06-08-2015, 05:03 PM   #63
FRSHunter
Drives: Asphalt FRS
Hey guys had a question. I have the same problem as STV3. The car is currently wired the way I want it, but I just want to lower the brightness on the LED strip. I'm assuming I just wire a resistor somehow somewhere between the connector of the car (Wire that corresponds to parking brake/headlight on the base FRS its the unused wire) and the connector of the headlights (Wire that corresponds to the LED) correct? If so what would be the best way to do this being able to revert back?
FRSHunter is offline   Reply With Quote
Old 06-22-2015, 07:22 AM   #64
solort
Drives: Series 10 FRS
If I wanted to use a rheostat to adjust the resistance vs a resistor, what characteristics would I need for it? And to confirm wiring, all I need to do is connect one end to the #1 brown looking wire with blue grommet on bottom and the other into #5 red wire with brown grommet on top (harness pic on the first post)?
solort is offline   Reply With Quote
Old 12-19-2015, 11:42 AM   #65
ir1064
Drives: 6MT, C7P
i use 50ohm 10W resistor to tone down my 2013 base FRS with Monogram/10 series LED light strip, i use the original "flasher wire" that already build into my car and put the resistor in serious, and i never get flash from the in coming traffic, but i'm waiting for the tech stream OBDII to USB cable coming next week, and hopefully i can fix it via software and remove the resistor, as of now, i have no DRL (regardless of handbrake position), and LED strip is on with the same dim down output for both parking light (1 tick), main HID (2 tick) and high beam.
ir1064 is offline   Reply With Quote
Old 01-30-2016, 02:31 AM   #66
Gregorio3
Gregorio3's Avatar
Drives: 2015 Scion FR-S RS1.0
Was wondering if anyone has theirs at 100% brightness. Currently have 100ohm resistor but I'm wanting it at full brightness like when just driving with DRL's on. If anyone has any idea how to achieve full brightness would be greatly appreciated.
Gregorio3 is offline   Reply With Quote
Installed 10 Series Headlights Today Calavera Cosmetic Modification (Interior/Exterior/Lighting) 58 02-15-2024 03:18 PM
Scion 10 series headlights gusbarragan Cosmetic Modification (Interior/Exterior/Lighting) 19 04-20-2014 11:26 PM
86 Headlights (10 Series) $656 Each at www.onlinetoyotaparts.com YMMV Calavera Cosmetic Modification (Interior/Exterior/Lighting) 42 08-21-2013 06:54 AM
GT86 European headlights ? rikdrt1 Cosmetic Modification (Interior/Exterior/Lighting) 7 07-18-2012 04:32 AM
European delivery date ? Sylvain44 BRZ First-Gen (2012+) — General Topics 6 06-04-2012 07:27 AM
