Old 05-25-2015, 08:27 PM   #3109
ksconekiller
Drives: Subaru BRZ
Originally Posted by renfield90 View Post
Manufacturing tolerances. Hell, that's the whole reason why camber bolts exist in the first place.
Can someone explain to me how the Koni strut is illegal if it fits within OEM manufacturing tolerances?
Can someone explain why some of you want to ban a part that makes your life considerably easier than if you had to install inserts?
Does anyone want to guess who a protest committee is likely to believe more: you stating the part is illegal, or Koni (with their excellent reputation in the community) stating the part is a direct OEM replacement? Do you have a plan to prove Koni wrong?
Hopefully we can put this to bed and work on finding a way to beat the MX-5s and the RX-8s with the cheater engine rebuilds. Now there is a juicy protest candidate if someone can find out what secret sauce is going into the blender...
I don't want to ban the Koni replacements at all. I just want people who run them to realize that, with no other changes, Koni struts allow more camber than the OEM struts. If someone were to max the camber by using the smaller bolts, it would be in excess of OEM tolerances and therefore illegal. If you're on factory springs, keep camber below 1.5; if you're on the TRD springs, a tad more should be fine. As long as you keep the camber to the degree it would be with OEM struts, nobody will care. Like markw said above, nobody says you have to crank the hub all the way over to max camber.
ksconekiller is offline   Reply With Quote
Old 05-25-2015, 08:32 PM   #3110
ksconekiller
Drives: Subaru BRZ
BTW, Ogburn matched the quick MX-5 time today in Lincoln. As Dave gets more time in the car, I'd expect him to keep pace with Fenter/Harvey. The course had lots of high speed elements and was a blast. Those who weren't there missed out.
Even I and the other sucker in the BRZ had a good time.
Old 05-26-2015, 10:59 AM   #3111
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
I definitely had fun at the tour. I was glad to improve from day 1 to day 2, I rarely do.
Definitely going to have to pick up the RE71Rs. My old ZIIs aren't going to cut the mustard.
DylanFRS is offline   Reply With Quote
Old 05-26-2015, 11:03 AM   #3112
piknockout
Drives: 2014 BRZ
Was Dave on the TRD stuff in Lincoln?
piknockout is offline   Reply With Quote
Old 05-26-2015, 11:19 AM   #3113
Briankbot
Briankbot's Avatar
Drives: 2013 FRS
I think he said he has the springs and I would guess the bars also but maybe he'll chime in and confirm.
CS really has a great bunch of guys in it. Everyone was very friendly and it was cool meeting a bunch of people from this forum.
Briankbot is offline   Reply With Quote
Old 05-26-2015, 03:45 PM   #3114
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
I'm hearing that the RE71Rs don't last very long. Someone said after 44 runs theirs were corded.
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 05-26-2015, 05:50 PM   #3115
renfield90
The Stig's German cousin
I know someone who ran them for 8 hours at an enduro.
He then rotated front to rear and kept running.
Old 05-26-2015, 06:25 PM   #3116
48Spoons
Drives: Ultramarine FR-S
I'm at about 45 runs and they are still totally fine. The centers wear a little odd though. This is on regular pavement though so it might be worse on concrete or just generally crappy pavement.
Edit: I run STX so the added camber may help some too.
48Spoons is offline   Reply With Quote
Old 05-26-2015, 06:58 PM   #3117
Jawnathin
Drives: Toyobaru FRZ
44 runs sounds like a bit much. Maybe in CS trim, with a narrow wheel, no camber, oversized tire. And you didn't flip or rotate them, and you were hard on the sidewalls. Maybe that is 44 runs.
In my experience, mine got pretty beat up due to rough surfaces from SD and Crows. They got about 40 runs on those surfaces. We have another local site which is nicer to tires for another 35~ runs. In total they've got about 75 or so runs on them now. I did have to rotate and flip them. I expect another 30-40 runs on the 'kind' surface before they're toast. On a rougher surface, maybe 20 runs.
Jawnathin is offline   Reply With Quote
Old 05-26-2015, 07:01 PM   #3118
ButteR
I remember talking to 'whatboubob' in san diego and he would remount his tires onto his wheels...moving the lefts to the right and rights to the left to get extra life out of the tires...not sure if this is very cost effective in CS, but now that the trd springs opened the doors for an extra degree of camber, this could be a viable option to extending the life of dedicated autoX tires.
Anyone currently doing this?
ButteR is offline   Reply With Quote
Old 05-26-2015, 08:49 PM   #3119
YawMomentRacing
YawMomentRacing's Avatar
Drives: 2013 Red 6MT Scion FR-S
Yes TRD springs and both bars.
Dave Ogburn | Yaw Moment Racing
2013 Scion FR-S - C-Street
http://yawmomentracing.blogspot.com/
YouTube Channel
YawMomentRacing is offline   Reply With Quote
Old 05-26-2015, 08:58 PM   #3120
vroom4
Maybe I missed it, how is anyone getting more camber from the front due to springs? That's not even geometrically correct....?
vroom4 is offline   Reply With Quote
Old 05-26-2015, 09:05 PM   #3121
solort
Drives: Series 10 FRS
I have been thru a protest at Nationals for excess camber, and was found compliant because I followed the rules. This was for a different stock car (SRT4 ACR). I used the factory strut housings with inserts so the spring perch would be at the correct height (with the original stock Tokico struts). If the spring perch of the Koni full struts is in a different position than the stock strut, it is illegal. If the spring perch and all other strut measurements are the same as stock struts, it will be legal. Some struts will get more neg camber than others and some cars will get more neg camber than others. If you follow the rules with legal parts, the resulting negative camber (unless Scion lists a max negative camber with the crash bolts) is legal.
Sooooo, use the legal parts that give you the most legal camber...
solort is offline   Reply With Quote
Old 05-26-2015, 10:08 PM   #3122
bslate3
Drives: 2015 CWP BRZ
For those going to the Mineral Wells Pro Solo that don't live very far away. Equipe Rapide is having a mirror cross the Sunday before the Pro Solo.
Wouldn't hurt to get a little experience in if you're able to.
bslate3 is offline   Reply With Quote
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
