Old 05-22-2015, 07:40 PM   #6385
vaderbloke
Drives: 2014 Subaru BRZ
O'Reilly auto has them.
vaderbloke is offline   Reply With Quote
Old 05-22-2015, 07:42 PM   #6386
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
They don't here in Victoria Texas.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 05-22-2015, 07:57 PM   #6387
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Originally Posted by Chad86 View Post
The kit appears to be in perfect condition. The better packaging seems to have done its job. No damage to the supercharger mounts or intercooler fins this time.
Thanks for getting this issue resolved @moto-mike and @SprintexUSA
Glad it got straightened out finally. I agree in @SprintexUSA's decision to remove the hose from the barb. Seems to be a safer bet.
Xero-Limit is offline   Reply With Quote
The Following User Says Thank You to Xero-Limit For This Useful Post:
Chad86 (05-22-2015)
Old 05-22-2015, 08:00 PM   #6388
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Do I just push it together to attach the hose?
Chad86 is offline   Reply With Quote
Old 05-22-2015, 08:02 PM   #6389
CK_Bladesmith
Drives: Raven FR-S
Yes. Lube it with a little wd40 or white grease and carefully push it onto the nipple.
The Following 2 Users Say Thank You to CK_Bladesmith For This Useful Post:
Chad86 (05-22-2015), SprintexUSA (05-22-2015)
Old 05-22-2015, 08:02 PM   #6390
Xero-Limit
Xero-Limit's Avatar
That's it, just slip it on there.
Chad86 (05-22-2015)
Old 05-22-2015, 08:08 PM   #6391
stockysnail
Just the tip
stockysnail's Avatar
Originally Posted by SprintexUSA View Post
I have spares. 855-591-2778.
New valve ordered from you. I forgot to ask if there's anything special when installing the new one, once I get it? Do I just unbolt the metal bracket, take off the hose, and somehow remove the metal rod, then bolt the new one on or is there anything I'll need to make sure I do or don't do? I'm guessing I don't need to remove the whole supercharger and all I'd need to do is take off the engine bay brace?
Old 05-22-2015, 08:25 PM   #6392
Chad86
Chad86's Avatar
Drives: Toyota GT86
Originally Posted by dpgfunk View Post
Looks ok, you'll just need to attach the hose onto that nipple
Excellent, thanks @dpgfunk, @CK_Bladesmith, @moto-mike. No lube required, but I can see how easily this could break. Just took a bit of elbow grease.
The Following User Says Thank You to Chad86 For This Useful Post:
CK_Bladesmith (05-22-2015)
Old 05-22-2015, 09:09 PM   #6393
Chad86
Chad86's Avatar
Drives: Toyota GT86
Not sure if this is a forum member, but I am liking the sound of their setup.
[ame="https://www.youtube.com/watch?v=klUMfcNixKY"]Sprintex BRZ Tune #2 91 octane. - YouTube[/ame]
[ame="https://www.youtube.com/watch?v=OuCx5mYYsb8"]Sprintex BRZ shakedown. - YouTube[/ame]
[ame="https://www.youtube.com/watch?v=I0VyS2N2RAc"]Sprintex intercooled BRZ startup. - YouTube[/ame]
Old 05-22-2015, 09:10 PM   #6394
Chad86
Chad86's Avatar
Drives: Toyota GT86
Also a Sprintex install video.
[ame="https://www.youtube.com/watch?v=LUTn13Bmcpk"]Sprintex BRZ EMP Supercharger install - YouTube[/ame]
Old 05-24-2015, 10:26 PM   #6395
Vex
How full should the sight glass be?
Also can I use this oil?http://m.supercheapauto.com.au/Produ...ecommendations
Vex is offline   Reply With Quote
Old 05-26-2015, 10:07 AM   #6396
Dream20b
Y u do dis?
Question- Does anyone make a short intake like moto-east uses on their 335, but for the 210 kit?
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 05-26-2015, 10:49 AM   #6397
stockysnail
Just the tip
You can use the same one they use on their 335 kit on the 210.
The Following User Says Thank You to stockysnail For This Useful Post:
Dream20b (05-26-2015)
Old 05-26-2015, 11:05 AM   #6398
Dream20b
Y u do dis?
I had the wrong picture in my head; what i'm throwing around in my head is essentially a short ram intake that would sit near the blower so I can shorten the path to from the filter to blower, but i'm thinking that would cause some amount of heatsoak. Is there a kit that does that or is this a bad idea?
Excuse my crude drawing, but essentially something to remove the pipe (circled in white) and move the intake (circled in red) Where the pipe was.
Dat Hot Lava Doe
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
