Old 05-24-2015, 10:19 PM   #3095
ksconekiller
Drives: Subaru BRZ
If you can get more camber with one type of strut over another, it is illegal for street class. Apparently you can get more than stock with Koni full replacements and the camber bolts, but it won't fly in C Street.
ksconekiller is offline   Reply With Quote
Old 05-25-2015, 12:22 AM   #3096
markw
Drives: 2014 FR-S
Sounds like people are pulling 1.9 degrees with TRD springs and stock struts.
markw is offline   Reply With Quote
Old 05-25-2015, 12:31 AM   #3097
markw
Drives: 2014 FR-S
Originally Posted by bslate3 View Post
That is insane that people are getting 1.9 with Koni shocks and TRD springs!
I got a massive 1.0 on my BRZ with just camber bolts and pushing in as best as I could. I need more front negative camber.
Can you get more negative camber with the Bilsteins too?
It's not insane, there is a camber curve with the front end, as the suspension compresses, it will gain negative camber to an extent. So by lowering the car with the springs, without anything else, it is quite possible to gain a half a degree of camber at static ride height. A double wishbone suspension will gain more than a strut suspension. My EF honda gained 2.5 degrees when I put koni's and GC springs on it. I think I dropped it about 1.5" or so, but that was an STS car.
Old 05-25-2015, 12:34 AM   #3098
markw
Drives: 2014 FR-S
I was at 1.5 degrees, crash bolts, loosened top hat, jack under hub applying pressure, tightened everything.
Old 05-25-2015, 01:16 AM   #3099
renfield90
The Stig's German cousin
Manufacturing tolerances. Hell, that's the whole reason why camber bolts exist in the first place.
Can someone explain to me how the Koni strut is illegal if it fits within OEM manufacturing tolerances?
Can someone explain why some of you want to ban a part that makes your life considerably easier than if you had to install inserts?
Does anyone want to guess who a protest committee is likely to believe more: you stating the part is illegal, or Koni (with their excellent reputation in the community) stating the part is a direct OEM replacement? Do you have a plan to prove Koni wrong?
Hopefully we can put this to bed and work on finding a way to beat the MX-5s and the RX-8s with the cheater engine rebuilds. Now there is a juicy protest candidate if someone can find out what secret sauce is going into the blender...
Old 05-25-2015, 01:21 AM   #3100
renfield90
Yup. Not all strut suspensions have a camber curve (my old Celica didn't) but we got lucky.
How much camber you gain under compression varies from car to car because of, once again, manufacturing tolerances. You're going to have a very hard time throwing paper at someone because their wheel looks more bent than everyone else. "That's illegal because I don't think it's possible" is a good way to burn $100.
If you like watching that much money disappear instantly, I recommend instead that you bring a keg to nationals.
Old 05-25-2015, 03:30 PM   #3101
scirocco78
Drives: Scion FRS
What are you TRD suspension adopters using for a front sway bar?
I know of one person using a Hotchkis.
scirocco78 is offline   Reply With Quote
Old 05-25-2015, 03:33 PM   #3102
markw
Drives: 2014 FR-S
I did the TRD bars front and rear. Front is a 21mm and the rear is a 16mm. Car feels really good, with a tad bit of oversteer, nothing like the other option springs and bars where it felt like it wanted to snap all the time.
Old 05-25-2015, 03:36 PM   #3103
ButteR
Drives: 2015 Scion FR-S
Trd front and rear sway bar for me
ButteR is offline   Reply With Quote
Old 05-25-2015, 03:36 PM   #3104
scirocco78
Drives: Scion FRS
I'm running the Strano bar with Koni's and have the car dialed in where I love it. I'm trying to figure what's going to happen if I buy the TRD springs and just run the rear TRD bar.
Old 05-25-2015, 04:12 PM   #3105
Laloosh
Laloosh's Avatar
Drives: 2014 BRZ
So if I can get -1.2 with bolts, buy replacement shocks and go to -2.2 that is now fine? If -2.2ish is now within "tolerances " then I'll just slot my OEM shocks which NO WAY in hell get that camber. Why should I be screwed with tire wear because Koni decided to do this?
2014 BRZ C-Street #11 245/40/17 RE71R's, Camber Bolts, Koni Shocks, Perrin 19m Bar, 5mm Spacer/Longer Studs, Berk Track Pipe, KNN Drop In, Fancy alignment
Laloosh is offline   Reply With Quote
Old 05-25-2015, 05:02 PM   #3106
Cueman
Cueman's Avatar
Drives: In Perfect Control At All Times
I've done three events with a stiff set Hotchkis. Switched it to the soft setting after the last event, as I decided that as awesome as the car is in transition, sweepers were too painful. Have yet to try it...
Cueman is offline   Reply With Quote
Old 05-25-2015, 05:12 PM   #3107
markw
Drives: 2014 FR-S
No one says you have to crank it all the way over. Besides, you're in a BRZ, you probably won't get 2.2 degrees as you're sitting an inch higher.
Mark
Old 05-25-2015, 06:04 PM   #3108
MTeator
First 86
Switched to soft for the last two, still painful in sweepers.
Scion First 86 in Lexington KY - Firestorm 6MT - Delivered May 17, 2012
Mods: Motegi 17x7 TrakLites, BFG Rivals, K&N 33-2300 Filter, Nameless Perf. Track Pipe, TRD springs & rear bar, Hotchkis front bar (eh), Kask trailer hitch
MTeator is offline   Reply With Quote
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
