Old 03-20-2015, 12:30 PM   #57
mush
mush's Avatar
mine is still going strong lol
Old 05-24-2015, 10:34 AM   #58
Synkronicity
Drives: Ford Escape to BRZ
Going to be a bump for this question but:
What's the Bracket's part number in the first post? I bought mine used and it didnt come with it AND it didnt get anything drilled into the front (!!) so I'm rolling around illegally till my magnets come in but I need to make sure I get the right bracket.
Synkronicity is offline   Reply With Quote
The Following User Says Thank You to Synkronicity For This Useful Post:
Sisko's_Baseball (12-30-2019)
Old 05-24-2015, 12:10 PM   #59
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
http://estore.subarupartswarehouse.c...10-590-02.html
it's 57751K
shiumai is offline   Reply With Quote
The Following User Says Thank You to shiumai For This Useful Post:
Old 05-24-2015, 01:31 PM   #60
Synkronicity
Originally Posted by shiumai View Post
That was EXTREMELY helpful, thank you so much.
shiumai (05-24-2015)
Old 08-27-2015, 03:13 PM   #61
kch
Senior Misanthrope
kch's Avatar
Bumping this thread with a word of caution: I did this project in October 2014 with the magnets specified by OP, secured behind the bumper with superglue and gorilla tape. Everything was great.
However, I got a little bolder and have been running without a front plate for at least 6 months now. It turns out that one of the larger magnets has gone missing. I'm sure if I had kept the front plate attached more, the magnet would not have fallen loose. But just know that the superglue + gorilla tape method will not secure the larger magnets forever if you leave the front plate off.
Old 09-04-2015, 09:02 AM   #62
shiumai
shiumai's Avatar
Good warning! Superglue tends to be hard/brittle, and can crack under vibration. they do have a rubber-toughened version that's more suitable:
http://www.loctiteproducts.com/p/sg_...el-Control.htm
That's why I used the 3M weatherstrip cement as it's rubber-based. I'm surprised the gorilla tape came off too, though.
Old 09-04-2015, 09:52 AM   #63
Rosticles
Drives: 1966 Mustang, 2013 FR-S
I used super glue and duct tape behind the magnet. I live in Texas and have had them installed for over a year. I got interesting confirmation that they are still in their original position.
Rosticles is offline   Reply With Quote
The Following User Says Thank You to Rosticles For This Useful Post:
Hyper4mance2k (02-03-2016)
Old 09-04-2015, 11:08 AM   #64
shiumai
shiumai's Avatar
You can buy a small sheet of clear bra material and cover the area under the license plate if you want to protect the paint. it'll be unnoticeable with the plate off under normal conditions.
Old 09-04-2015, 11:23 AM   #65
Rosticles
That is not paint damage. It is small amounts of metal adhering to the magnets like a Wooly Willy toy. I just need to wash it.
The Following 4 Users Say Thank You to Rosticles For This Useful Post:
8R6 (09-09-2016), Davegixxer (02-02-2016), haimichaeltran (06-14-2016), shiumai (09-04-2015)
Old 12-22-2015, 09:57 PM   #66
Speedforce
Speedforce's Avatar
Drives: Subaru Brz Hyper Blue
Thanks
Thank you works perfectly! hope it last forever a long time. Great post!
Speedforce is offline   Reply With Quote
The Following User Says Thank You to Speedforce For This Useful Post:
shiumai (01-17-2016)
Old 02-02-2016, 03:33 AM   #67
Davegixxer
Davegixxer's Avatar
Drives: 2016 Subaru BRZ
I am definitely going to do this because stupid Illinois requires front plates and I refuse to put holes in my bumper! Shipping is rather expensive from that site. Anyone found similar strength magnets from a local store to buy from or online without crazy shipping pricing?
Davegixxer is offline   Reply With Quote
Old 02-02-2016, 06:53 AM   #68
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
I couldn't find any place that had them cheaper with shipping. They are simply the best priced and easiest to navigate when looking for something specific. Remember that they require special packaging (and I'm not 100% sure, but possibly special shipping).
Luckrider is offline   Reply With Quote
Old 03-16-2016, 02:21 PM   #69
scubastove
Drives: Subaru BRZ Series.Blue
Bump for question... Anyone who did this, how long has it stayed on? How reliable would you say this mod is?
scubastove is offline   Reply With Quote
Old 07-05-2016, 08:38 PM   #70
cjny
Drives: 2016 BRZ
Originally Posted by 8987846 View Post
Is it possible to do this without taking out the bumper?
Yes, I think so.
1) Attach the magnets to the license plate bracket just as the OP describes. Place it on the front of the bumper, holding it in place somehow ( I enlisted a helper) while you move on to step 2.
2) Slip one of the magnets in between the plastic outer bumper and the foam behind it. You can do this from the bottom rear of the bumper. Make sure it is oriented in the proper direction to attract to the companion magnet in the bracket.
3) Use a fifth magnet held at the front of the bumper to attract the loose magnet that you placed behind the bumper and drag it toward the companion magnet attached to the bracket. All you have to do is get it close and it will snap into place.
4) Repeat on the other side.
You might be able to drive it this way but I think it will eventually slip downward due to vibration. In the original method this is prevented by gluing the magnets to the back of the bumper. In my case I used ty-wraps to attach a small piece of foam pipe insulation to the grill just beneath the bracket. It acts as a bump stop on downward movement of the plate bracket. It sounds ghetto but the foam is well obscured by the license plate.
It's only been on a few days but so far so good!
cjny is offline   Reply With Quote
front license plate mount? Jeong Cosmetic Modification (Interior/Exterior/Lighting) 16 02-13-2014 10:54 PM
Frs Cap and OEM Subaru Front license plate bracket Xdragonxb0i Miscellaneous 1 01-16-2013 12:25 AM
Front license plate: Why you don't want the dealer to drill your bumper CircuitJerk Issues | Warranty | Recalls / TSB 53 08-27-2012 02:02 AM
USA front license plate mounting? Slimline bracket mount.. Help across the world :P WTF Scion FR-S / Toyota 86 GT86 General Forum 32 08-23-2012 07:25 AM
2013 BRZ License Plate Bracket Kit Installation Revision‏ taosracer Cosmetic Modification (Interior/Exterior/Lighting) 19 05-26-2012 02:28 PM
