Old 05-24-2015, 04:57 AM   #183
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by cf6mech View Post
Congratulations man. That was a delightfully uneventful first fire.
Calum is offline
Old 05-24-2015, 07:58 PM   #184
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
@cf6mech would you be willing to let someone ride shotgun next weekend? PM me if you want to . When my engine goes this will be my swap!
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline
Old 05-25-2015, 06:12 PM   #185
cf6mech
Drives: FRS Silver LS1 swapped.
Originally Posted by Floggin Tires View Post
And I still want trans ratio.
2.66 or 2.97?
Not sure which option Vorshlag picked for the Tremec, but I'm sure it was the correct one of the two, they worked directly with a Tremec rep. and are aware of the ultimate purpose for the car.
cf6mech is offline
The Following 2 Users Say Thank You to cf6mech For This Useful Post:
cdrazic93 (05-26-2015), Floggin Tires (05-25-2015)
Old 05-25-2015, 06:14 PM   #186
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
Right on.
That is a sweet gearbox my friend.
Can't wait for you to get down with your fresh machine.
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline
The Following User Says Thank You to Floggin Tires For This Useful Post:
cf6mech (05-25-2015)
Old 05-25-2015, 06:14 PM   #187
cf6mech
I'm not expecting it back anytime real soon, there's still work to be done and then debugging and track testing later. No problem when its done getting a ride.
cf6mech is offline
The Following User Says Thank You to cf6mech For This Useful Post:
carbonBLUE (05-25-2015)
Old 05-25-2015, 06:18 PM   #188
cf6mech
Right on.
Its probably my favorite part of the swap,...wanted this same gearbox for my Boss Mustang as I wasn't to pleased with the Chinese made remote shifting Getrag
cf6mech is offline
Old 05-25-2015, 06:20 PM   #189
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
2.66 or 2.97?
Sorry, another noob question.
What is being asked here?
Captain Snooze is offline
Old 05-25-2015, 06:30 PM   #190
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
The t56 has two different first gear ratios available. 2.97 is (obviously) shorter, but slightly weaker than the 2.66 first gear ratio.
Sent from my XT1095
Parting out HERE
civicdrivr is offline
The Following User Says Thank You to civicdrivr For This Useful Post:
Captain Snooze (05-25-2015)
Old 05-25-2015, 07:23 PM   #191
Captain Snooze
Drives: Red Herring
Thanks @civicdrivr.
Next "I have no idea about these things" question.
Given the smaller mass of this project car might a 6 speed box result in too much ratio overlap? That is, given the lowish mass of car and monster torque spread of the V8 might a 5 speed box suffice?
Old 05-25-2015, 07:28 PM   #192
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Thanks @civicdrivr.
Yes, a 5spd would probably work better with a 2.97 ratio while the 6spd would better suffice with the 2.66. Im guessing since A LOT of thought, years, and effort went into this R&D and swap kit; im assuming they realized 2700 lbs and 350whp is good enough reason for the 2.66 first gear
Its always nice to see people asking questions about cars after reading/doing hobby research. Reading only gets you so far before questions arise that need to be answered, keep at it Capt
Last edited by cdrazic93; 05-26-2015 at 05:45 AM. Reason: First gear* not final drive lol my bad
cdrazic93 is offline
The Following 2 Users Say Thank You to cdrazic93 For This Useful Post:
Captain Snooze (05-25-2015), civicdrivr (05-25-2015)
Old 05-25-2015, 09:03 PM   #193
Floggin Tires
Thanks @civicdrivr.
Originally Posted by cdrazic93 View Post
Yes, a 5spd would probably work better with a 2.97 ratio while the 6spd would better suffice with the 2.66. Im guessing since A LOT of thought, years, and effort went into this R&D and swap kit; im assuming they realized 2700 lbs and 350whp is good enough reason for the 2.66 final drive.
As far as the transmission applied in this swap.
Two Gearsets are available as follows.
1st--2nd-3rd-4th-5th-6th-Reverse
2.66 1.78 1.30 1.00 .74 .50 2.90
2.97 2.10 1.46 1.00 .80 .63 2.90
Both choices we have a double overdrive.
Meaning for every 1 revolution of the crank into the trans,
you get more than one revolution out of the output shaft, and driveshaft.
ie: in 5th and 6th gear
Also 4th gear being 1:1 means,
In 4th gear the Crank spins once the output shaft spins once.
I'd rock the 2.66.
Enough torque to accelerate in whatever range.
Highway cruising like a champ.
That being said I would do either in a heartbeat.
ZC6-CBS, is home
civicdrivr (05-26-2015)
Old 05-25-2015, 09:11 PM   #194
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Waring this post could be filled with errors.
Its easy to get confused here.
Some say final drive is the Ring and pinion (differential) Ratio.
Other say ▼
Final drive is the Ratio of,
Final gear ratio(♠) times Ring and pinion ratio (♣)
So, ♠x♣ = Final Drive.
Some also include the above along with factoring overall tire circumference.
This post is not to tell you which way is right, its for your info.
My Opinion▼
I've always called Final drive the Ring and Pinion Ratio.
Actually, I rarely use the term Final Drive.
The way Ratios are measured is as follows.
The rear differential for example is 4.1:1.
So it takes the driveshaft rotating 4.1 times into the diff to spin the axles one time.
Hence the ratio of (4.1 to 1) or (4.1:1)
So,
assuming the rear differential remains stock gearing = 4.1:1 ratio.
The 2.66 having a .50 6th gear
The 2.97 having a .63 6th gear
Final drive on 2.66 is 4.1x.50 = 2.05:1
Final drive on 2.97 is 4.1x.63 = 2.58:1
I'd rock the 2.66.
This particular car is using a Magnum box, so the 5/6 ratios are not necessarily tied to the 1/2/3/4 ratios. Assuming this car is running a 2.66 box, there's a very good chance 5/6 is .80/.63.
Sent from my XT1095
Parting out HERE
The Following 2 Users Say Thank You to civicdrivr For This Useful Post:
cdrazic93 (05-27-2015), Floggin Tires (05-25-2015)
Old 06-03-2015, 06:53 PM   #195
Skurj
Drives: SOLD...
Ready to take my money yet? ...
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018
and its gone... Sept '18 tho I am sure I will miss it
Replaced with 18 50th edition ND
Skurj is offline
The Following 3 Users Say Thank You to Skurj For This Useful Post:
civicdrivr (06-06-2015), HATED1 (06-05-2015), wparsons (06-03-2015)
Old 06-03-2015, 06:54 PM   #196
brianhj
Drives: 2017 Camaro 1SS
What are they currently working on, specifically?
The suspense is killing me
brianhj is offline
FS: KW V3 Coilovers w/ Vorshlag Front Camber Plates Steeze_Its Brakes, Suspension, Chassis 7 06-27-2014 09:32 PM
FS: Vorshlag Front Camber Plates h4nh Brakes, Suspension, Chassis 1 03-01-2014 10:49 PM
FS: KW V3 w/ Vorshlag camber plates & oem stock suspension (SF bay area) serial gixxer Brakes, Suspension, Chassis 18 05-20-2013 08:51 PM
WTB: Front Vorshlag Camber Plates YDNA Brakes, Suspension, Chassis 0 05-03-2013 05:31 PM
Maybe a repost, but have you seen the Vorshlag project car? Bart1 BRZ First-Gen (2012+) — General Topics 3 01-07-2013 01:19 PM
