| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#15 |
Drives:
#16 |
Drives: 2004 Subaru Forester 2.5XT
#17 | |
Drives: Some rust bucket
#18 | |
http://www.motul.com/us/en-US/produc...%5Brange%5D=25 300V is excellent oil, but for info, it has not been submitted to the API or ILSAC for certfication for those that want to run a "certified" oil. 300V 5W-30 would be overkill for most applications here. It has a high HTHS of 3.5 and will behave similar to a 40 grade oil. There are some uoa's here on tracked and street driven 300V 0W-20 and Red Line 0W-20. Some in forced induction and raced applications. There are also uoa's here on tracked cars running regular Subaru 0W-20. Motul 8100 0W-20 would work well for most applications and 300V 0W-20 is for those that need/want high ZDDP, high molydenum, high High Temp High Shear, and tri ester base stocks. If you have a built engine then 300V 5W-30 or 0W-40. The high HTHS of 300V 5W-30 means that it will likely have oil pressure comparable to some 40 grade oils. -Dennis |
| The Following User Says Thank You to bluesubie For This Useful Post: | ayau (01-13-2014) |
#19 |
Drives: 2013 Asphalt FRS
#20 |
Drives: 2013 Scion FRS "Raven"
we have speced out the FA20 and there is a good reason they say 0-20w. The clearances are very tight and we would recommend running a quality synthetic oil over a thinker weight.
| The Following User Says Thank You to DAMotorsports For This Useful Post: | mfbmike (01-28-2014) |
#21 |
Drives: None
What if the car is turbocharged and easily exceeds past 100c? Would you recommend I switch to a 5w30 grade oil. I've been running Toyota's 0w20 for the first 4k miles and then switched to motuls 8100 x clean 5w30 for the next 3k miles.
#22 | |
Oil 5w30
That should be fine in a turbocharged car. Although most GF5 5W30's shear to a 20 grade with hard use, X-clean meets ACEA C3 specs so it has a high HTHS and thick 30 grade viscosity when hot (it's nearly a 40 grade). As shown in WRX uoa's, X-clean typically stays in grade under hard use. If you want to go a little lighter next time, Motul Eco-nergy is a thinner 30 grade. FWIW, Subaru Japan allows 5W40 in the BRZ in severe conditions. |
| The Following User Says Thank You to bluesubie For This Useful Post: | Astroboy (05-23-2015) |
#23 | |
Drives: None
So what you are telling me is that it's basically a 40 grade? My cars only pushing 250whp and 200tq. Should I be concerned? Sent from my iPad using Tapatalk |
#24 | |
-Mike Paisan ![]() Maintaining, Modifying and Educating TriState Enthusiasts since 2001. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs "Race Tested, Enthusiast Approved!" |
#25 | |
Drives: None
#26 | |
Drives: FT86
http://www.ft86club.com/forums/showp...&postcount=305 look at you oil temps if your getting over 235 then you need an oil cooler or a better oil cooler or you need to go to a thicker oil. an oil cooler air\oil type will drop a few psi oil pressure due passage of oil through cooler. Australian and south africian dealer now putting in 5w30 or 10w30 at standard service. if you have forced induction you should have an oil cooler and be running at least 5w30 10w30 or even 10w40 depending on climate\season unless you live in iceland and drive so sedatly your oil never gets over 230 f Modern synthetic oils wont break down till mabe 300F but its the oil pressure drop as the oil thins out due high temps you need to be concerned about. The viscosty rating is usually quoted at 100C\212F so as it heats past that its getting thinner than the rated viscosity I can get my NA car on E85, oil temp to 240+ F on track and i dont push it that hard on a warm day and easily 230 on a monutain run before oil cooler install I run 5w30 or 10w30 NA Last edited by steve99; 05-26-2015 at 10:49 PM. |
#27 | |
The HTHS is 3.5 in order to meet European specs (similar to some light 40 weights) and the viscosity at 100C/212 is 12.0 which is thicker than Eco-nergy and any off the shelf GF5 oil. https://www.motul.com/system/product...pdf?1302202191 |
| The Following User Says Thank You to bluesubie For This Useful Post: | Astroboy (05-27-2015) |
| Quickie: 0w20 vs 5w20 / 5w30 | empower-auto | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 43 | 12-17-2016 01:54 PM |
| Where to buy Eneos 5w30? | mswhong | AUSTRALIA | 0 | 03-26-2013 06:25 AM |
