#3081 |
Drives: 2014 BRZ
It's obvious, it took me all of 5 seconds to ask an owner how he got so much camber up front. I would never protest it but just a heads up as people will. So if you are doing it and running towards the front...be careful.
2014 BRZ C-Street #11 245/40/17 RE71R's, Camber Bolts, Koni Shocks, Perrin 19m Bar, 5mm Spacer/Longer Studs, Berk Track Pipe, KNN Drop In, Fancy alignment
#3082 |
Drives: In Perfect Control At All Times
#3083 |
Autocross Nut
Drives: Argento 2013 Scion FR-S - MT
#3084 |
First 86
you guys are lucky. After the springs my LCA's are almost parallel with the ground now and I only gained a tenth-ish.
Scion First 86 in Lexington KY - Firestorm 6MT - Delivered May 17, 2012
Mods: Motegi 17x7 TrakLites, BFG Rivals, K&N 33-2300 Filter, Nameless Perf. Track Pipe, TRD springs & rear bar, Hotchkis front bar (eh), Kask trailer hitch |
#3085 |
Seriously anything more than 1.5 ish up front is cheating, the OEM struts with crash bolts are barely -1.2 if you're lucky.
#3086 |
Drives: 2013 Red 6MT Scion FR-S
Agreed. The TRD springs barely affect front camber b/c of the strut front suspension. The multi-link rear gains much more camber with the lowering springs.
Dave Ogburn | Yaw Moment Racing
2013 Scion FR-S - C-Street http://yawmomentracing.blogspot.com/ YouTube Channel |
#3087 | |
Drives: Series 10 FRS
#3088 | |
What is off on them? Are the holes on the ears in the wrong place? When I got my MCS shocks originally they just had slotted holes, so I contacted MCS and they quickly made inserts to locate the shock in the exact right spot. If it ain't exactly the same as stock it is illegal. |
#3089 |
Drives: 2014 FR-S
Is 1.9 with the stock strut? What's the camber curve of the front suspension? It very well could be that just changing the springs may give you up to a half degree, putting you over 1.5 degrees on stock struts. As for the Koni's, as long as you pull the camber back into the range you would get with stock struts, you should be good. This is why I'm curious as to if 1.9 was TRD spring + crash bolts + stock strut.
Mark Last edited by markw; 05-24-2015 at 12:51 AM. |
#3090 | ||
The Stig's German cousin
The RX8 and M3 (IIRC) were on 245 stones. Everyone else was 225 or 235. Harvey/Fenter were on 225, they have the same size wheel as us. The tires were pretty mushy, but otherwise I like them a lot. I'll probably go with the 225 next time, because an already-not-super-communicative tire getting pinched and mushy makes reading the tire that much harder. That said they make good grip, and holy hell they are EASY to launch! I am not good at launching the car, mind you - go check my El Toro 60' times, or any of my times from last year (El Toro, Mineral Wells, Finale). These tires just made it way easier. Procedure was this: 1. Rev to 5k 2. Launch. Slip the clutch, keep throttle steady 3. At 10-20 feet, full throttle 4. At 30-40 feet, dump clutch I didn't play with revving higher because it was working really well, and I didn't want to snap axles or burn my clutch. I'm sure 2.0 is possible with someone who is better at launching. Hard to say how much is the compound and how much is the extra width of the tire.I'm not able to stay for the tour, so good luck to Dave and the other twins still there! |
#3091 |
Thanks Manfred. Safe drive home
Very wet today. Should be interesting.
#3092 | |
I had between 1.3 and 1.4 on all four corners prior to the springs. Now 1.9 front and 2.1 rear.
#3093 |
Drives: 1992 Isuzu PuP, 2014 FR-S
Has anyone checked the camber curve for our cars or know of a graph that is available online?
#3094 |
Drives: 2015 CWP BRZ
That is insane that people are getting 1.9 with Koni shocks and TRD springs!
I got a massive 1.0 on my BRZ with just camber bolts and pushing in as best as I could. I need more front negative camber. Can you get more negative camber with the Bilsteins too? |
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 06:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 01:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 09:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 02:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 11:03 AM |
