Old 05-21-2015, 05:39 PM   #1471
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Originally Posted by aquaman View Post
has anyone had an issue with the seal where the mechanical pump for the oil return line meets the block? when i get to redline and letoff, there is a drop of oil that comes out and lands on the overpipe and smokes. Is there an OE gasket or that could be used? maybe whatever they use on the automatics? when installed I used high temp RTV sylicone...
Do you mean the line that goes under the injector cover or the line that runs to the pump behind the head?
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 05-21-2015, 09:19 PM   #1472
Astroboy
Astroboy's Avatar
Drives: None
Mine constantly does that, But that's because I tore the bottom engine thread.
Astroboy is offline   Reply With Quote
Old 05-21-2015, 09:34 PM   #1473
aquaman
aquaman's Avatar
no, i mean the connection between the mechanical pump itself and the block...
aquaman is offline   Reply With Quote
Old 05-21-2015, 10:22 PM   #1474
protpibe
protpibe's Avatar
That's such a tricky part to install. Unfortunately, if it's leaking the only fix is to remove and redo the rtv gasket. I looked into getting a plate with a rubber seal made but it was way more money and effort than it was worth.
Old 05-22-2015, 08:56 AM   #1475
aquaman
aquaman's Avatar
that is what i figured,I thought the AT had somthing there that the MT doesn't. Am I wrong about that?
Old 05-22-2015, 10:45 AM   #1476
toast
Drives: 14 BSP Edelbrock BRZ
How is everyone's ceramic coating holding up? I can't tell what kind AVO uses, but based on what it looks like I've had similar things in the past and it would flake off just by looking at it wrong.
toast is offline   Reply With Quote
Old 05-22-2015, 11:01 AM   #1477
aquaman
aquaman's Avatar
http://www.alldatadiy.com/alldatadiy...9155/191560188
found this on AllDataDIY... there is a vaccume pump assembly for AT cars that just uses an O-ring. looks like i will be resealing it with RVT since there is no grove for an O-ring on the mechanical pump. maybe AVO can look at their pump and see if they can make future pumps have an O-ring like the vacuum pump assembly...
Old 05-22-2015, 11:08 AM   #1478
protpibe
protpibe's Avatar
As long as nothing like oil gets onto it, it seems to hold up fine. My first overpipe had oil drop on to it and it took all the ceramic coating off. My new 3" is fine, but the oil leak was fixed before putting it in.
Old 05-22-2015, 04:48 PM   #1479
Zenith/Nadir
Drives: 2013 GBS BRZ Limited
There was rust on my turbine housing after 1000 miles. I just took it back apart and had a local company I've used in the past recoat everything. It was cheaper than paying for it from AVO as well. In hindsight, that's how I would do it from the get go.
Zenith/Nadir is offline   Reply With Quote
Old 05-23-2015, 01:40 PM   #1480
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
So does anyone have that avo option for the wrx oem bov? Or is everyone on the avo dual vent?
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 05-25-2015, 08:45 PM   #1481
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
Can anyone speak to Ball Bearing Turbo Options aside from AVO's?
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
Old 05-30-2015, 07:42 AM   #1482
JD86
Drives: 2013 Toyota 86 GT
There's been avo kits in aus fitted with GTX2867 and GTX3076, don't have numbers on either sorry. The boys at high performance academy in nz switched out their turbo with a borg warner efr. In all cases there were custom dump pipes required, and I think mods to the headers for the 3076 to be a V band connection. I am pretty sure there was serious cutting and welding involved with the BW in the AVO position.
JD86 is offline   Reply With Quote
The Following 2 Users Say Thank You to JD86 For This Useful Post:
@Art_Mighty (06-04-2015), lamawithonel (03-20-2017)
Old 06-04-2015, 01:34 PM   #1483
Astroboy
Astroboy's Avatar
Drives: None
Anybody else having fitment issues while installing the avo oil cooler?
Old 06-04-2015, 01:58 PM   #1484
protpibe
protpibe's Avatar
Has anyone machined the flanges flat to compensate for header warping? If so, any fit issues with the overpipe afterwards?
avo, avoturboworld
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
