Old 05-21-2015, 08:31 PM   #1
Synack
Boosted
Synack's Avatar
Drives: Sideways
Joined the 400HP club. 445whp on Mustang Dyno
DBW Motorsports tune (Atlanta)
Flex Fuel kit from Moto East @moto-mike
Precision 5558 turbo
9:1 compression built motor
444whp/350wtq on high map E80/20psi
372whp/291wtq on low map E80/13psi
340whp/270wtq on low map 93/9psi
It'll go a bit higher when the gas tank fully becomes E85.
It's tuned to run any combination of 93/E85 and will compensate timing, tuning, PSI, power, etc depending on ethanol content level.
Full album, with a few old pics
http://imgur.com/a/rmSrY
Final Dyno
On the dyno
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
The Following 6 Users Say Thank You to Synack For This Useful Post:
Astroboy (05-22-2015), Bonburner (05-22-2015), Cal3000 (05-22-2015), Rulin (05-23-2015), STV3 (05-26-2015), texasbound972 (05-21-2015)
Old 05-21-2015, 09:05 PM   #2
Zozr
Drives: White
Damn...20psi.
That boxer must be crying
Zozr is offline   Reply With Quote
Old 05-21-2015, 09:12 PM   #3
Synack
Boosted
Synack's Avatar
Drives: Sideways
Originally Posted by Zozr View Post
Damn...20psi.
Hey it lasted fine for over 2 years on the previous turbo at 20psi on 93. The motor will enjoy 20psi much more on E85 this time
The Following 4 Users Say Thank You to Synack For This Useful Post:
Astroboy (05-22-2015), Bonburner (05-22-2015), hmong337 (06-07-2015), raven1231 (05-26-2015)
Old 05-21-2015, 10:06 PM   #4
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Final Dyno
On the dyno
Awesome numbers. Even with low compression looks like you're making good use of the e85 with the higher boost. That plot looks like the turbo still has another 2-3 psi in it, but really solid numbers with your compression ratio.
Xero-Limit is offline   Reply With Quote
Old 05-21-2015, 11:49 PM   #5
Synack
Boosted
Synack's Avatar
Drives: Sideways
Yeah it's not too bad. This Precision 5558 with journal bearing on 9:1 compression makes a similar power graph to a stock block 12.5:1 compression with a GT2867R. A GTX2867R spools about 400-500rpm quicker. Maybe if I went with the DBB version I could've made the graph shift left ~300rpm and be a little closer to GTX territory.
Still not bad for a $1000 JB turbo.
The car hasn't seen past E80 either, should look even better on E85 when the tune adjusts.
Old 05-22-2015, 04:22 AM   #6
fluffy-reindeer-slayer
Drives: fr-s and tc2
Sorry to venture off topic a bit but does d3 still make that kit?im from sa and i believe there out of houston correct?
fluffy-reindeer-slayer is offline   Reply With Quote
Old 05-22-2015, 08:10 AM   #7
kbogarto
Drives: 2013 BRZ limited WRB
So your tune lets the ecu adjust boost levels based on ethanol content in your gas? Is there a range it is set to operate in?
92 240sx (sold), 03 350z (sold), 13 BRZ (AVO turbo)
kbogarto is offline   Reply With Quote
Old 05-22-2015, 09:25 AM   #8
Synack
Boosted
Synack's Avatar
Drives: Sideways
The car was tuned for multiple ethanol levels as we added E85 into a tank that had 93 in it. But yes it adjusts things like timing and boost to compensate ethanol content levels. I'm running E77 at the moment and going to fill up later today to try to hit E85.
The range it operates in is anything from pure 93 octane pump gas to full blown E85. I believe it can handle up to E90 as well, but I'm not sure it'll ever see that. As you may already know, pump gas already contains 10% ethanol so that is what the computer is seeing and it thinks it's running E10. So I guess you could say the range is from E10-E90. I'm not sure what would happen if I ran pure gasoline with zero ethanol, but I'm sure it would be fine.
Old 05-22-2015, 09:28 AM   #9
Synack
Boosted
Synack's Avatar
Drives: Sideways
I honestly have no idea as I haven't talked to them in a while. I wouldn't buy their kit though honestly. Not because it's a bad kit, it's an excellent kit. They provided me awful customer support after my kit was installed. And their tuner could've provided me with a much better tune.
You might be better off getting a kit from Full Blown Motorsports or similar. They have amazing support and the kit is also top notch.
The Following User Says Thank You to Synack For This Useful Post:
fluffy-reindeer-slayer (05-22-2015)
Old 05-22-2015, 07:15 PM   #10
Cal3000
Drives: Panda FR-S
If you have a flex fuel kit, the ecu can integrate the AFR, timing and other adjustments based on the ethanol content automatically.
When I got my car tuned, the tuner tuned for 91 and then E66. Based on these 2 parameters, everything else above e66 or in between E0 and E66 was taken care of.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
The Following User Says Thank You to Cal3000 For This Useful Post:
Synack (05-23-2015)
Old 05-22-2015, 08:05 PM   #11
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
a built motor???
Damn...20psi.
It's a built motor at 9:1 compression, it can probably handle 30 psi...if it has forged internals and good bearings as long as it doesn't get oil or fuel starved.
people are running 13 psi at 12.5:1, that's a hell of a lot more dangerous than 20 psi at 9:1.
Jaden
Jaden is offline   Reply With Quote
The Following User Says Thank You to Jaden For This Useful Post:
Old 05-22-2015, 08:08 PM   #12
Jaden
Road-hole
you want to try E90?
Just whip out a couple of liters of moon shine and add it to the mix...
Jaden
Old 05-23-2015, 02:22 AM   #13
Synack
Boosted
Synack's Avatar
Drives: Sideways
Jaden
Doing that tonight on my throat, but not the car......
Old 05-23-2015, 03:53 AM   #14
#maverick#
#maverick#'s Avatar
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
Great numbers. E85 is the stuff of the racing gods haha
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
#maverick# is offline   Reply With Quote
Just joined the E85 Flex Fuel and probably 400HP Club! Synack Forced Induction 3 03-23-2015 03:51 PM
Finally Joined the Club Natedawg Scion FR-S / Toyota 86 GT86 General Forum 5 12-05-2014 11:36 AM
Just joined the FT86 club last weekend! Andrizzle Northern California 17 02-21-2014 05:22 PM
Finally joined the FT86 owners club Dvst8or Scion FR-S / Toyota 86 GT86 General Forum 15 09-01-2013 03:21 AM
Finally, offically joined the club~ Cyau Scion FR-S / Toyota 86 GT86 General Forum 18 05-19-2013 02:10 PM
