Old 05-21-2015, 07:22 PM   #1569
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Originally Posted by Forgetful View Post
I've contacted FiveAxis via facebook and spoke to someone named Troy. He confirmed that the spoiler was port installed for the South East Toyota (SET) region, from mid 2012-2013.
I gather that port installed is port installed, whether it was just regionally or nationally available, so long as the part is readily available to the buying public.
Is a facebook message reasonable 'documentation' if it ever comes up in protest?
Thanks for the help.
Troy Sumitomo is the founder of Five:AD. If you ask him to send you an email from him with some kind of document showing that spoiler was part of port installed, it might be more legitimate than fb message.
Old 05-26-2015, 07:57 PM   #1570
RTR
Drives: monogram raven
2 part question
First, when coming across the finish line going from hard throttle to hard brake, has anyone else felt a big thud? Feels like something large, like the whole engine just shifts forward and slams into something else. Just trying to describe the thud I've felt 3 times now on 2 different days.
Second question
Let's leave type of coils out and just say adjustable 1-10. 1 being full stiff and 10 being full soft. Front and rear, where have you found your stiffness settings for your best times? Short 35-40 second tracks if it matters.
RTR is offline   Reply With Quote
Old 05-26-2015, 08:52 PM   #1571
knipple
Drives: 2013 Ultramarine Scion FR-S
Originally Posted by RTR View Post
2 part question
Second question
For the first question, no I haven't felt a thud like you have described.
As for the second, this will depend on what you have done to your car and how you want it to behave. You will only discover where you should be by driving the car on the courses you drive and adjusting the settings based on the feeling on the runs. As far as what setting to change, I use the chart I have attached to this reply to determine the change.
knipple is offline   Reply With Quote
The Following 3 Users Say Thank You to knipple For This Useful Post:
RTR (05-26-2015), swarb (05-27-2015), tahdizzle (05-27-2015)
Old 05-27-2015, 01:38 PM   #1572
MaxRED13
Novice Autocrosser
MaxRED13's Avatar
Drives: Scion FR-S Red//MT
Has anyone run higher springs rates like the ones on the Tein SRCs ro does that get too unmanageable.?
Sorry if this has been addressed previously my original search of this thread didn't come up with any results.
MaxRED13 is offline   Reply With Quote
Old 05-27-2015, 04:52 PM   #1573
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
well those coilovers by themselves are okay, but I don't think many people run those because of the Electronic dampening.
-Jack Burton
Old 05-27-2015, 07:59 PM   #1574
cjd
cjd's Avatar
Drives: 2017 BRZ
Huh? Electronic?
I have SRC with the 10k/12k rates. I'm embarrassingly slow still (2nd time in car, prior was 12 years ago , all new suspension, tires, and alignment for this race +rain) but working on video of Sunday, after it had stopped pissing on us. Stock sways. I can go a lot faster... No obvious issues. My wife and I drove up to Michigan (7 hrs) the previous weekend and she had no trouble knitting the whole trip.
The Following User Says Thank You to cjd For This Useful Post:
MaxRED13 (05-28-2015)
Old 05-28-2015, 11:53 AM   #1575
tahdizzle
So elite I'm 1338
Originally Posted by cjd View Post
Huh? Electronic?
the SRC are EDFC compatible. They don't come out of the box that way, but they are compatible. EDFC is not legal in STX.
-Jack Burton
Old 05-28-2015, 12:38 PM   #1576
BE4VER
( ͡° ͜ʖ ͡°)
BE4VER's Avatar
Drives: 14FR-S
Since the RS 1.0 is in STX, am I correct in assuming the release series 1.0 front lip is the standard by which the terms OEM and OEM replica are applied? Pretty sure a BRZ replica is out of the question for FR-S right? I don't think the TRD lip is a port option and I see that the assumed aero features dimensions, even though similar looking, look larger than the release series.
Does anyone have any links or any suggestions for other options for FR-S legal front lips? I can find plenty of replica side skirts but haven't turned up any front lip options yet.
“Has Anyone Really Been Far Even as Decided to Use Even Go Want to do Look More Like?”
BE4VER is offline   Reply With Quote
Old 05-28-2015, 01:09 PM   #1577
MaxRED13
Novice Autocrosser
MaxRED13's Avatar
Huh? Electronic?
I was specifically crious about how well the high spring rates do at the autocross level. I have heard of lots of people using them for time attack or track, but not so much for autocross.
Also what type of surface are your events held on? Tarmac? asphalt? concrete?
Old 05-28-2015, 02:50 PM   #1578
FastWhite
Drives: Subaru BRZ Limited M/T
I'm running the SRC's with 20/18 sway bars. To lazy to switch back to stock. I find the car extremely planted, very flat cornering. Which is what I like. The venue's I run on are asphalt, old stuff. I have never been on concrete.
I have moved up into back of the top runners. Improving. I definitely noticed a huge improvement after the Tein install. The comments from some of my co drivers were just as good. I find that you can set up the sweet spot very easily. Even a 1 click adjustment changes things up.
FastWhite is offline   Reply With Quote
The Following User Says Thank You to FastWhite For This Useful Post:
Old 05-28-2015, 08:02 PM   #1579
cjd
cjd's Avatar
Drives: 2017 BRZ
Yes, I'm slow still.
I'm not sure why EDFC compatibility would turn people away from a coilover... A lot cheaper without the electronics.
To lazy to figure out embedding on my phone, I may fix it later.
Old 05-29-2015, 11:36 PM   #1580
Im_SPEED
Drives: FRS hot lava
I would like to know about this as well
Im_SPEED is offline   Reply With Quote
Old 05-31-2015, 05:46 PM   #1581
RedBRZ80
Drives: 2013 Red BRZ
Tire pressures that we won with at Dixie was 30/27. Basically I've keep that all year so far. Running 245/40 RE71rs. About 75 runs. Flipping them to finish them off for local events, breaking out a new set for Match Tour next weekend.
RedBRZ80 is offline   Reply With Quote
The Following User Says Thank You to RedBRZ80 For This Useful Post:
Thorpedo (06-01-2015)
Old 05-31-2015, 06:37 PM   #1582
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Cold or hot? I'm finding on concrete (which is all I race on) I'm building pressure way faster than on RS3s before.
The Following User Says Thank You to BlaineWasHere For This Useful Post:
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 03:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 07:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 02:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 12:02 PM
