Old 05-19-2015, 10:08 PM   #29
MalcolmHimself
MalcolmHimself's Avatar
Drives: 2015 BRZ
Originally Posted by gdrider77 View Post
I've done this 4 times now on BRZ , and basically just remove from car. Once removed from car, ready to bake! No need to remove anything else.
One thing I recommend, when baking, put a couple 2x4 pieces of wood to set lights on. Then no chance of plastic touching metal oven pieces and melting.
I used a silicone baking mat for my prelude, plan to use the same thing for my BRZ. Don't need the grill marks
MalcolmHimself is offline   Reply With Quote
The Following User Says Thank You to MalcolmHimself For This Useful Post:
gdrider77 (05-20-2015)
Old 05-20-2015, 10:07 PM   #30
toast
Drives: 14 BSP Edelbrock BRZ
Originally Posted by Jive Turkey View Post
yeah, i'm sure you can make it brighter, the boomerang is a piece of glass/plastic with a few LED's behind it every little bit...i'm sure you can replace those LED's with brighter ones and it'll do the trick, i just dont know if you can take it apart without breaking it and ruining the boomerang, its very fragile.
You don't need brighter leds to get brighter boomerangs. The ones that are there are very underdriven. There is a thread on what to do to make them full power (some soldering and adding a heatsink). It is a good thing to do while you have the headlight apart to black it out.
toast is offline   Reply With Quote
Old 05-20-2015, 11:10 PM   #31
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Hey toast, what setting were you born on? Like crunchy 6 on the toaster or like blackened 9? Lol
Why in the frickle frackle would they under drive the LED's from factory? Because they didnt want to have to deal with that heatsink you have to add?
Old 05-20-2015, 11:13 PM   #32
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
yeah that comment was made almost 2 years ago...that kind of info wasn't around yet. LOL
Jive Turkey is offline   Reply With Quote
Old 05-21-2015, 10:50 AM   #33
toast
I wasn't criticizing, just point something out since this thread has been revived lately.
The stock leds are underdriven because the heat generated can be handled simply by the circuit board itself. Driving them at full strength requires changing the power pathways and added a pretty good sized heatsink.
Old 02-16-2016, 08:44 PM   #34
teehan
teehan's Avatar
Drives: 2015 WRB BRZ
I'm doing mine for my BRZ and I'm curious how far I should take it apart. What did you guys remove on your headlight prior to baking?
And at what temperature did you bake it at and for how long?
Any help would be awesome! Thanks everyone!
teehan is offline   Reply With Quote
Old 10-04-2016, 11:22 PM   #35
k.houan
k.houan's Avatar
Drives: BRZZZ
Anyone interested in trading your stock brz headlights for my professionally painted black ones? Im thinking of getting rid of my car soon.
k.houan is offline   Reply With Quote
Old 10-18-2018, 12:25 PM   #36
BOND007_LTK
Drives: 2013 brz
Looks yummy as f
Comments on light output tho...
Legal but more importantly safety concerns.
BOND007_LTK is offline   Reply With Quote
Old 12-03-2018, 09:28 PM   #37
Ivegotamain2
Drives: 2015 Limited BRZ
Here is my before/after.
I ended up going with 6-7 coats of the VHT engine enamel, sprayed in 10 minute coats and dried under a heating lamp. Let sit for 24 hrs.
Ivegotamain2 is offline   Reply With Quote
The Following 2 Users Say Thank You to Ivegotamain2 For This Useful Post:
bhmax (12-14-2018), ShadowReaper (09-12-2020)
Old 12-04-2018, 10:13 PM   #38
sharpsicle
Certs You Dont Care About
sharpsicle's Avatar
Drives: 2013 Galaxy Blue BRZ
Originally Posted by BOND007_LTK View Post
Looks yummy as f
BRZ uses HIDs with projector housings, FRS is halogens. Light output is not affected at all on BRZs.
sharpsicle is offline   Reply With Quote
Old 12-05-2018, 09:56 PM   #39
soundman98
ProCrastinationConsultant
soundman98's Avatar
in that last pic, the turn signal output is affected...
Old 12-14-2018, 01:57 PM   #40
Ivegotamain2
I've actually noticed no negligible light output degradation from the fogs, even using stock bulbs.
I used the directions on the second page with the black chrome paint and they still retain more than acceptable reflection.
I was actually thinking of switching to LED amber turn signals because I feared the output would be less, but it's been perfect as of now.
As said in this thread, the BRZ uses a projector, so the light doesn't reflect off of the chrome housing - that stuff is just there for looks (besides the turn signal housing of course).
Old 08-28-2020, 08:29 PM   #41
ShadowReaper
Indulgent Tormenter
ShadowReaper's Avatar
Drives: 15' LTD Subaru BRZ DGM
2 year revival.
How good of a seal is this afterwards. I'm not sure of the material in the headlight but if you need to bake something, what is the material that is being softened, and inevitably expanding. How does it go back to normal fitment, please don't say "it just stiffens back up to original fitment"
Instagram: Gabe.it.the.ole.college.try
ShadowReaper is offline   Reply With Quote
Old 08-28-2020, 10:36 PM   #42
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Originally Posted by ShadowReaper View Post
2 year revival.
It just stiffens back up to original fitment.
Something that inevitably expands when heated, inevitably contracts when cooled.
3 years on my headlights since baking them and no condensation or leaks. Same with a second set I did. I added no extra gasket material.
Anyone North Teas know how to Black out Headlight J-Money Southwest 2 02-05-2013 05:08 PM
Another headlight black out, with a twist. Hardrock4445 Cosmetic Modification (Interior/Exterior/Lighting) 32 01-16-2013 03:26 PM
FS [SYD] - Modelista front headlight eyeliners in black eleu2166 Australia Classifieds 9 11-05-2012 07:07 AM
And yet another Black headlight, different still FastLane1000 Cosmetic Modification (Interior/Exterior/Lighting) 23 10-29-2012 12:31 PM
Another black headlight, a little different Vonsamhain Cosmetic Modification (Interior/Exterior/Lighting) 26 10-18-2012 10:10 AM
