Old 05-20-2015, 05:30 PM   #225
HunterGreene
Hail Magnet
HunterGreene's Avatar
Originally Posted by Kevinn View Post
Why are they even still wasting money on replacing fuel pumps?
Well, as the old saying goes, "Its not my money."
It has priests in it?
The Following User Says Thank You to HunterGreene For This Useful Post:
Kevinn (05-20-2015)
Old 05-20-2015, 06:39 PM   #226
CJB
Drives: 2013 BRZ Premium MT
Has anyone had power window issues NOT related to cold weather? Every time I open a door after the car has been sitting a while, the window sounds like it snaps out of the outer guide. Almost feels like I'm going to break it.
Other times, I'll shut the passenger door and the window will roll itself down halfway. I'm waiting for the day this happens in the rain.
I feel like replacing the door weatherstrip with the redesigned part (listed in the TSB for the cold weather issue) will probably fix the issue, but I'm worried the dealer will fight me on this.
CJB is offline   Reply With Quote
Old 05-21-2015, 03:03 AM   #227
I had the snap. It's terrible. Sounds like a hammer on glass. The hard stops or the regulator are not aligned properly. They must match up or the regulator will tweak itself and jam.
This window mechanism is really tricky and I've been told by a Subie service tech that there is no official alignment procedure.
I took the time to figure it out for myself last year but even if you held a gun to my head, I still wouldn't be able to describe a set procedure. One tweak affects everything else. Off the top of my head I remember 5 distinct adjustments.
CJB (05-21-2015)
Old 05-21-2015, 05:07 AM   #228
73TORANA!
Drives: Orange GTS
I had the same issue and it turned out that the upper stop on the window at the rear of the door. It had come loose and was allowing the window at the rear to go up higher, I noticed that the window travelled further at the rear than at the front. A quick adjustment and all fixed.
73TORANA! is offline   Reply With Quote
The Following 2 Users Say Thank You to 73TORANA! For This Useful Post:
Ultramaroon (05-21-2015), voyager2285 (09-11-2016)
Old 05-21-2015, 05:15 AM   #229
73TORANA!
Drives: Orange GTS
Originally Posted by Waffleicious View Post
I just got my BRZ back from the dealership after telling them about the chirping TSB and having them install a new fuel pump... I've only had it back for a day now, but the chirping is currently gone... Fingers crossed that it's gone for good, but we shall see!
I have only had this problem when I had to put E95 a 10% ethanole blend. I have been speaking to a Toyota AUS tech rep on an other matter and mentioned the chirp and he said that the USA has a dryer fuel blend that causes the issue and here In AUS our ron 98 is a better fuel ???
Old 05-21-2015, 06:17 AM   #230
steve99
Drives: FT86
That toyota guy must have done to much lsd (and i'm talking differentials) back in the 60's :-) our fuel is crap compared to usa fuels.
Yes I have found 10% ethanol fuels excite the crickets like the old united P100 RON where non-ethanol petrol shell caltex BP 98 shuts them up.
Weird thing is E85 shuts them up as well, maybe they get too drunk and pass out or I suspect its some additive they put in E85 occasionally when it rearly hot day and you have done a bit of spirited driving they fire up for a bit.
The Following 3 Users Say Thank You to steve99 For This Useful Post:
Tcoat (05-21-2015), Ultramaroon (05-21-2015), ZZT86 (05-21-2015)
Old 05-21-2015, 08:34 AM   #231
CoupedUpSubie
Drives: 2013 BRZ Limited
I'm curious as to if AUS has cracked down on sulphur like the USA has. Our gasoline has 30 ppm on average with a maximum of 80 ppm.
Sulphur in fuels act as a natural lubricant. Old diesels with high pressure injection pumps need an additive to prevent the pump from wearing out quickly.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
The Following User Says Thank You to CoupedUpSubie For This Useful Post:
73TORANA! (05-24-2015)
Old 05-21-2015, 10:02 AM   #232
HunterGreene
Hail Magnet
The probable cause as listed in the TSB is cavitation caused by the pump. How this relates to fuel composition and makeup (aka, ethanol in the mix) has not been fully explored.
A little google detective work gave me this link--A nice quick glance at the worldwide standards. You are correct, NA has a 30 ppm standard, with Aussie standards being 50 ppm. This is probably another contributing factor as to why we have more crickets in North America.
http://transportpolicy.net/index.php...parison:_Fuels
Just a side note, its interesting to see that we actually have the same diesel standard when it come to sulfur.
Old 05-21-2015, 01:46 PM   #233
That would definitely do it. Wish mine was that simple but I did learn quite a bit.
DustinS (05-21-2015)
Old 08-27-2015, 05:10 PM   #234
lupindub
Drives: Scion FR-S
Just curious where the heck you found these TSB at? I googled "Scion Techinical Service Bulletin" and I couldn't find any of the TSB the OP posted. So where the heck did you find this stuff from?
lupindub is offline   Reply With Quote
Old 08-27-2015, 05:12 PM   #235
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
Insider access at dealerships.
Sent from my HTC One using Tapatalk
aegisdrgn is offline   Reply With Quote
Old 08-27-2015, 05:14 PM   #236
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Most of them are from the forum members posting on this forum. If you google "site:www.ft86club.com tsb", you'll see the original threads posting the TSB for each issue. I just took the TSB from there and posted them here.
Old 08-27-2015, 05:29 PM   #237
lupindub
Drives: Scion FR-S
Ah makes sense. I was starting to get a bit insane trying to find the original TSB source. Every time I Googled"Scion FRS TSB", it would re-direct me to this site.
Old 08-27-2015, 06:01 PM   #238
Sideways
BRZZZZZ
Sideways's Avatar
Drives: 2013 BRZ Whiteout
I dropped my car off at Subaru dealership for rust repair on window pillar along with some cracking sound on the front driver side a-pillar, the service guy asked me if I need my fuel pump replaced as it was chirping, so getting it replaced also.
But he told me that there is yet another newer version of fuel pump on its way but won't be available for another few weeks, so if the problem returns after new fuel pump, I will have to take it in again after few weeks to get fuel pump replaced again.
Sideways is offline   Reply With Quote
chirping, high pressure fuel pump
Recall I think so!!!! RWD-boxer Issues | Warranty | Recalls / TSB 16 10-07-2012 11:39 AM
FRS recall? totally Issues | Warranty | Recalls / TSB 8 08-30-2012 01:01 AM
Recall! already earthsscum BRZ First-Gen (2012+) — General Topics 1 06-07-2012 08:00 PM
Owners Manual Recall Opie BRZ First-Gen (2012+) — General Topics 8 06-05-2012 11:09 PM
Did anyone get a call from toyota about a recall yet? AustinTCLN Scion FR-S / Toyota 86 GT86 General Forum 2 06-05-2012 12:45 AM
