Old 05-19-2015, 11:26 PM   #1
BTXP.XD
Drives: 14' FRS
Cold Start, engine makes loud pop sound
Right now I have a 2013 FRS with TRD cat back, and sometimes when I do a cold start my car sounds like gas isn't going through fully and makes popping sounds from the exhaust.
But today when I did a cold start, my god it did that a couple times, then i heard a loud pop or cracking sound from the engine noise, so i quickly turned it off and openned the hood, nothing, so I started again and it ran perfectly normal.
Anyone experience this?
BTXP.XD is offline   Reply With Quote
Old 05-20-2015, 10:44 AM   #2
You might check (or have checked) to see if the car has any stored codes.
Have you changed gas stations / gas octane lately ... ??
Old 05-20-2015, 10:50 AM   #3
BTXP.XD
Drives: 14' FRS
I did not check for any stored codes, nor do I know what it is lol, mind explaining please?
But yea I do go through a few gas stations but all same company and 91 gas all the time.
NBeyond
https://www.instagram.com/nbeyond__/
Support us for daily cars + upcoming clothing line.
Old 05-20-2015, 11:55 AM   #4
When a modern engine "acts up", sometimes it will trigger (send) a code, indicating what may be the problem. These codes can be read by a code reader, hooked up to the OBD port on the car.
Code readers can be relatively inexpensive to purchase. Some auto parts stores will read any stored codes for free. A stored code is one that the car stored away and can be read at a later date.
My guess is that your car just "hiccupped" a couple of times and there is nothing to worry about.
I hope you get it sorted out.
Old 05-20-2015, 07:09 PM   #5
BTXP.XD
Drives: 14' FRS
Oh ICIC, kay i guess if it shows up again, ill bring it to a garage to have it checked for codes. But as of recently it has been running smoothly.
No problems now. I hope they are just hiccups, but the last one was a bad one haha!
Old 05-20-2015, 07:21 PM   #6
steve99
Drives: FT86
http://www.ft86club.com/forums/showthread.php?t=43408
it seems normal
car runs very rich at startup
can be "tuned" out
If you get pops during acceleration thats bad
Old 05-20-2015, 08:30 PM   #7
BTXP.XD
Drives: 14' FRS
it seems normal
can be "tuned" out
no its pops during cold start only, no acceleration, no gassing either LOL.
It acutally sounds similar to the first youtube video on the link.
Old 05-20-2015, 09:00 PM   #8
steve99
Drives: FT86
think your all ok then, it never gets cold enough for us to get that here :-)
Old 05-20-2015, 09:32 PM   #9
Mine with the TRD catback also can make some weird and wonderful noises on cold start. It always levels out and goes away as soon as it drops out of high idle so I figure it is just the nature of the beast and have never worried about it.
Old 05-20-2015, 09:56 PM   #10
BTXP.XD
Drives: 14' FRS
I think thats good to hear, but i'm not so happy cuz when winter comes, man... im already worried about the sound LOL. Manager said my cold start is too loud.
LMAO thats pretty good, but it also means u guys don't have the perk of snow drifting like in Canada!!
Old 05-20-2015, 10:32 PM   #11
steve99
Drives: FT86
If you have access to tuning device its pretty easy to tune out the high rev loud cold start, part of doing that is reducing the large fuel enrichment at startup to heat catylic converts which i suspect causes these pops
see tune tweaks link below
High Rev Cold Start noise reduction
Noisy high rev cold start is to warm up Cataylic converters for emissions purposes
http://www.ft86club.com/forums/showp...6&postcount=17
Three things happen Idle is increased to 1700rpm
Additional Fuel is added by offsetting MAF scale during warm-up
Ignition Timing is retarded by 15 degrees during warm-up
The retarded timing is what makes most of the additional noise.
You may get CEL code P050B if so just disable it its due to ecu monitoring post start ignition timing.
To fix alter the “Ignition Timing Post Start” table under “Ignition Timing- Advance” folder .
Change all cells from -15 to -4 degrees and most of the noisy “bark” should be gone.
.This image has been resized. Click this bar to view the full image. The original image is sized 1600x900.This image has been resized. Click this bar to view the full image. The original image is sized 1600x900.This image has been resized. Click this bar to view the full image. The original image is sized 1600x900.
You can also reduce the “Idle control” “Idle control Target A” and “Idle control Target B” tables reduce the values for idle that are over 1400 rpm to 1400 rpm.
The MAF adjustments can also be scaled back but those tables not in OFT definitions yet
Don’t get to aggressive with your adjustments else your car may not idle well in very cold weather startup and you may also trigger a CEL code related to cat warmup.
Whole thread on it here.
http://www.ft86club.com/forums/showt...rev+cold+start
Loud misfires upon cold start connorlug Issues | Warranty | Recalls / TSB 42 03-31-2016 04:43 PM
LOUD KNOCK during cold start Flat_4_Life Issues | Warranty | Recalls / TSB 23 03-18-2015 05:30 PM
Rattle sound on cold start Frs32907 Issues | Warranty | Recalls / TSB 0 07-12-2014 10:36 AM
rattle sound cold start marky Issues | Warranty | Recalls / TSB 1 03-24-2014 06:16 PM
Loud cold start and mpg drop since new be6sti Issues | Warranty | Recalls / TSB 7 11-28-2012 01:35 PM
