Old 05-20-2015, 06:01 PM   #15
churchx
churchx's Avatar
Drives: 2014 GT86
Nice to see that my hunch was right on the spot that real aceheader results should have been way better then preliminary dyno charts. I simply saw no possible reasons for it to not be among other top headers seeing it's design and not seeing possible limitations in it. Even more interesting to me seems it's good performance on petrol, as i don't have E85 here. No torque dip was known before, but nice to see these gains that accompany it. Also seeing that many other top headers reported gains of +35-40whp with other intake & exhaust bits fitted (sometimes even with direct exhaust pipe), but here Everything (including oem airfilter) except header and tune is stock, one can probably add extra 10hp with ease to these results. Maybe even more. Nice bit of hardware for those wishing maximum while staying NA.
Old 05-20-2015, 06:09 PM   #16
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Counterspace Baseline is stock BRZ on stock tune on 91 fuel (different car to tuned one with header). To get rated output from a stock BRZ/86 you need 93 fuel. The stock tune pulls a lot of timing on 91 fuel, probably worth 7 or so hp loss especially if it crap 91.
I would imagine the ACE header baseline was done on 98 ron fuel in their country which is probably closer to 93 aki usa fuel.
From everything I have read, our 93AKI is amazeballs good. It's better than your 100. Your 98 is better than our 91, but not by much.
91AKI>98ron>100ron>93AKI
For comparison's sake, 91AKi is currently $4.25USD per gallon. 93 is $7.95 & 100 AKI is $8.95
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 05-20-2015, 06:27 PM   #17
steve99
Drives: FT86
Our Aussie 98 ron is rubbish actually worse than your 91aki, European/Asian 98 seems much better
Aussie98/100RON>91AKI>European/Asian98RON>93AKI
Even on our 100ron (no longer available) we had to pull timing out of maps that would run ok on 91AKI.
Fuel is a big issue here we get great gains with E85 as our petrol is so crap.
Old 05-20-2015, 06:40 PM   #18
churchx
churchx's Avatar
Drives: 2014 GT86
I wonder where is european 95RON placed then (supposedly also listed in manual for my gt86, as allowed fuel). Below or on par with Australian 98 ..
As for E70 or E85 @OP .. i doubt there are much gains to be had above E70 .. there is limit how high detonation number can net noticeable improvements and when even higher detonation number will start showing diminishing returns. At least that is my impression on it from (IIRC) Shiv's thread about need for flex fuel kit ..
Old 05-20-2015, 06:43 PM   #19
s30series
Drives: 2015 BRZ Series.Blue
The ptuning headers dyno has me curious......that torque dip is horrible
s30series is offline   Reply With Quote
Old 05-20-2015, 06:57 PM   #20
churchx
churchx's Avatar
Drives: 2014 GT86
PTuning's was designed with racing in mind as main niche/priority. Unlike daily driving, it's more common that engine is kept in high rpm powerband during racing most of the time, so not much of a problem if used in it's intended niche. You simply don't spin engine that slow for it to hit torque dip. As for all the rest Aceheader seems much better allrounder. Except for legality bit due no cat in few states/countries. But then again with cat in Aceheader's header it will loose it's main distinguishing feature - it's long runners not just from overpipe portion but also from header itself runners part length, probably loosing in process these high gains (and who knows, maybe even torque dip won't be fixed as good as it is now, if you halve runners length).
Old 05-20-2015, 07:08 PM   #21
steve99
Drives: FT86
here is a log of South African 95 ron in stock tune IAM=0.2 and still pulling -3 degrees in places. Thats going to have a significant impact on performance.
Yes I doubt their would be any advantage on an NA car going from E70 to E85
http://datazap.me/u/steve99/south-af...ata=2-20-27-28
Old 05-20-2015, 07:43 PM   #22
Slowmotion
Drives: 04.5 GLI, 01 A4 Avant, RS 1.0
To be fair, ACE was testing a lot more combos, and if they had custom tuned for each combo, testing would have extended nearly two weeks, rather than just one day. This header had some pretty shitty results with stock and OTS tunes. The flow is so different that you don't see the true strengths until a custom tune is used.
Based on other dynos, and the other independent result, I expect to see solid AUC and some minor peak gains with more breathing mods.
Because there is no live tuning available for the FA20, tuning is very tedious and slow. In contrast, with my S2k, I can live tune, and literally tune 5x-8x faster. Even CSG's testing was nearly two full days.
Good point. I thought they had done some sort of tuning for each setup, but I guess I read wrong.
Slowmotion is offline   Reply With Quote
Old 05-20-2015, 09:20 PM   #23
akyp
Drives: 2012 86
I don't know the situation in Taiwan (that's where ACE is from correct?) but here our 98 RON is rather crappy too. With OFT OTS 91 tunes I need to pull quite a bit of timing to keep IAM at 1.0.
akyp is offline   Reply With Quote
Old 05-20-2015, 10:49 PM   #24
Kostamojen
This is pretty much what I expected. The ACE 4-2-1 is the best header you can buy for our cars.
Old 05-21-2015, 12:14 AM   #25
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
Here I was sold on the JDL UELs and then I read this thread.......I can't wait to see more test results though I'm excited!
Alltezza is offline   Reply With Quote
Old 05-21-2015, 02:37 AM   #26
Kodename47
Kodename47's Avatar
Drives: UK GT86
I wonder where is european 95RON placed then (supposedly also listed in manual for my gt86, as allowed fuel). .
On my trip to Europe all pumps has the MON rating, which IMO is more relevant for our cars. AKI is (RON+MON)/2. I found that the good quality 98 fuels were mainly 86/87 MON giving ~92AKI. Here in the UK Shell VPower is 99 RON and 86 MON, the rest are 97 RON when I can't find published data but I expect 90/91 AKI.
.: Stealth 86 :.
Kodename 47 DJ:
Old 05-21-2015, 03:38 AM   #27
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Originally Posted by projek_01 View Post
Subbed for JRSC results. I may have to bite the bullet if it looks good.
Definitely interested in this as well.
Old 05-21-2015, 08:12 AM   #28
rlpaul
Drives: point A to point C. Screw point B!
I was thinking of calling you guys to see what you thought of this header... whelp, guess my questions are answered.
rlpaul is offline   Reply With Quote
nsfwseriouslythisisporn
[REQ]BRZ Independent Fog Lights 1stGenBRZ86 DIY (Do-It-Yourself) Guides 3 04-17-2016 06:34 PM
What do I need for an independent tuner.. Shady195 Software Tuning 2 07-23-2014 09:04 PM
Subaru BRZ/Scion FR-S UEL Header by JDL -- Testing by Moto-East JPxM0Dz BRZ Photos, Videos, Wallpapers, Gallery Forum 13 05-08-2014 08:06 PM
Vortech Finale Review Video | Track Testing | Part 4 of 4 Dezoris Forced Induction 75 04-12-2014 12:45 PM
The Independent Review: Toyota GT86 Boxer-4 Scion FR-S / Toyota 86 GT86 General Forum 31 01-09-2012 06:22 PM
