Old 05-19-2015, 05:39 AM   #1
us3less24
chris86
Drives: Frs 2015
Send a message via Yahoo to us3less24
Help help :-)
Looking for best suited front pipe and over pipe for my frs.
I already have borla cat back exhuast, borla UEL headers and AEM intake.
Still dont know what would be my combination.
#noobhere
#pleasehelp
us3less24 is offline   Reply With Quote
Old 05-19-2015, 05:52 AM   #2
steve99
Drives: FT86
#noobhere
#pleasehelp
Consider keeping what you have and put money towards a tune
Changing front pipe/overpipe gives only small gain once you already have decent header. Changing front pipe to catless or hi-flow metalized cat can also make your car loud and raspy in combination with catless header.
best gains would be with canned tune for arround $500
see Basic Bolt on Mods guide link below
raven1231 (05-19-2015)
Old 05-19-2015, 05:55 AM   #3
us3less24
chris86
Drives: Frs 2015
Are you talking about "Open flash tablet"?looking for those also
Old 05-19-2015, 07:32 AM   #4
raven1231
Yes, the openflash tablet is one method of getting an OTS tune. ECUTEK is another method. I agree with what's stated above, the gains from the front pipe and over pipe are marginal, especially the over pipe. If you do decided to get either I would go with the manzo or topspeed versions as they are affordable and performance will be similar since it's negligible anyway. Also, as stated above though changing out your front pipe will likely increase rasp and noise, especially if going catless.
Old 05-19-2015, 07:36 AM   #5
us3less24
chris86
Drives: Frs 2015
Wahhhhh. But its too loud now like waking up the alarm of the cars :-(
Is resonated front pipe would be any help to silent down the noise a bit?
Old 05-19-2015, 07:41 AM   #6
Here dude read for hours- http://www.ft86club.com/forums/index.php
You will get more help there as well.
OH, and for future reference a title of "Help Help" doesn't do much good since we don't know if you are being held hostage, your cat is stuck in a tree or you are looking for info on exhausts.
Old 05-19-2015, 08:04 AM   #7
DarkSunrise
DarkSunrise's Avatar
If it's only loud during cold starts, your tuner should be able to reduce that for you (or you can do it yourself using OFT and romraider).
If it's too loud all the time, then adding an OP/FP will not help. Your CBE and/or header are simply too loud.
2022 BRZ Build
2013 FR-S Build
Old 05-19-2015, 10:29 AM   #8
us3less24
chris86
Drives: Frs 2015
Thanks guys :-)
Old 05-19-2015, 11:05 AM   #9
Teseo
Drives: frs
No problem
