Old 05-18-2015, 09:34 PM   #11747
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Originally Posted by immortal_suby View Post
Wow.
Blatant disregard for the truth.
Do you have the tS axles?
Originally Posted by DSOmegaX View Post
Didn't have enough time to get the draw stiffener on. Ended up installing: cf drive shaft, sti rear axles, sti steering rack bushings and the associated bolts.
The cf drive shaft/rear axle combo has done wonders to the acceleration of the car. It improves the responsiveness and immediacy of the throttle. While the majority of the improvement will be attributed to the drive shaft (half the weight), the larger diameter rear axles (same weight as stock), in my opinion, still contribute together with drive shaft as the larger diameter transfers more torque for the same amount of rotation. Overall, the car revs quicker, and what was most surprising to me, a lot smoother. A lot of the harshness and vibration as the car accelerates has been softened or eliminated.
The steering rack bushings have removed the dead center of the steering wheel. It has better weight, feels more solid, and improved the feedback from the road. And as mentioned, did not increase NVH.
Old 05-18-2015, 09:41 PM   #11748
immortal_suby
Drives: 2015 BRZ Limited 6MT
Hell no. I'd have to believe in the myth that 360 degrees of rotation was not 360 degrees of rotation to believe there would be any benefit from them. Maybe if my stock axles were twisted up like a candy cane I'd think that a larger axle could possibly transmit more torque.
I'm sure that if I was FI and worried about snapping an axle I'd be researching stronger ones, but at NA and still traction limited, I'm skeptical to say the least.
2015 BRZ , 1992 SVX LSL, 2019 ASCENT
immortal_suby is offline   Reply With Quote
The Following 2 Users Say Thank You to immortal_suby For This Useful Post:
DocWalt (05-19-2015), raven1231 (05-19-2015)
Old 05-18-2015, 10:06 PM   #11749
Porcupint
Drives: 13 GBS BRZ
MTEC shifter springs, stainless lines, street performance pads and fluid. Getting better and better every day.
Porcupint is offline   Reply With Quote
Old 05-18-2015, 10:20 PM   #11750
Pkush
Originally Posted by austinbrz View Post
Starship Enterprise deleted and High Mount Brake Light installed.
your house is gorgeous
Pkush is offline   Reply With Quote
The Following 2 Users Say Thank You to Pkush For This Useful Post:
austinbrz (05-18-2015), HotLeopardMama (05-19-2015)
Old 05-18-2015, 10:31 PM   #11751
austinbrz
austinbrz's Avatar
Drives: 2015 BRZ Limited (Crystal Black)
House
Thanks! Took a while to build it, but well worth the effort. Extra deep garage for modding and detailing!!!
austinbrz is offline   Reply With Quote
The Following User Says Thank You to austinbrz For This Useful Post:
Old 05-19-2015, 05:34 AM   #11752
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
I finally autocrossed it! I'm still on the stock Primacys, but I managed to just edge out a guy running an FR-S on [older] Rivals, so I suppose things went rather well :P
[ame]http://www.youtube.com/watch?v=SE-E3AmaLw0[/ame]
Stang70Fastback is offline   Reply With Quote
The Following User Says Thank You to Stang70Fastback For This Useful Post:
Choco (05-19-2015)
Old 05-19-2015, 06:15 AM   #11753
raven1231
It sure is! Damn man beautiful!
austinbrz (05-19-2015)
Old 05-19-2015, 10:35 AM   #11754
JDsThatGuy
Drives: Subaru BRZ Limited
For those that paid for their lips/side skirts/rear spats to be professionally painted, what did you pay to get them done? Looking to get some rough ideas on cost
JDsThatGuy is offline   Reply With Quote
Old 05-19-2015, 10:58 AM   #11755
echo419
echo419's Avatar
Drives: 2014 BRZ Limited
I'd imagine most place would be a couple hundred bucks. you're probably looking at a minimum charge for mixing/matching given the small amount of paint you're looking at.
Old 05-19-2015, 11:21 AM   #11756
scottxnizzle
scottxnizzle's Avatar
Drives: WRB BRZ
Originally Posted by miosaki View Post
Started to work on the front bumper lip and rear spats this weekend.
Applied primer, black paint coat, and matte clear coat. Sandpaper in-between for the bumps and uneven parts.
Leaving them to dry for a couple of days before install.
Attachment 109925
Lots of time to kill while waiting for the coats to dry. Playing around with the spray paint.
Attachment 109924
hey what lip kit is this? I'm in the market for one lol
scottxnizzle is offline   Reply With Quote
Old 05-19-2015, 12:44 PM   #11757
miosaki
miosaki's Avatar
Drives: 2015 CWP BRZ
Originally Posted by uEih View Post
Would love to see the finished product, painted my lip about a year ago with flat black and some sanding but no primer or clear coat so it seems like it's not withstanding and fading a bit. Planning to redo it this summer this time the proper way so it'll last more than just a year.
Definitely!
I'm trying out the matte clear coat on the front and rear to see how they look, and how long they last until fading starts. (Making myself wait to work on the sideskirts so I won't keep buying parts for the car. haha.)
Will post pictures soon!
I purchased the Bayson R STi style full lip kit.
They were really nice and called me when it was back in stock. Ordered/shipped in 3 days.
Check it out and see if you like!
miosaki is offline   Reply With Quote
The Following 2 Users Say Thank You to miosaki For This Useful Post:
iarefluffy (05-19-2015), uEih (05-19-2015)
Old 05-19-2015, 04:35 PM   #11758
uEih
Drives: CBS Subaru BRZ Limited
What rear fog/reverse light is that? Valenti? I was planning to either mod my light so it'll be a 4th brake light or just purchasing a light instead.
uEih is offline   Reply With Quote
Old 05-19-2015, 04:50 PM   #11759
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Got my JDL UEL Catless header and overpipe with black ceramic coat.
There some some small scratches on the back. I think JDL people might have put it on the ground and taken pictures.
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
The Following User Says Thank You to Figo For This Useful Post:
brz604 (05-23-2015)
Old 05-19-2015, 04:59 PM   #11760
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
SARD Goodies!
2URGSE
JPxM0Dz is offline   Reply With Quote
The Following User Says Thank You to JPxM0Dz For This Useful Post:
Choco (05-19-2015)
