Old 05-18-2015, 01:01 PM   #1
Vroomin86
Drives: 2015 Fire
265/35/18 in the front on a 18x9 wheel.....
Now before you say go search step out of this thread. Please I am not here to waste time, which is Infact why I did not search I have to order tires within the next 30 min.
I have a 265/35/18 on the rear, I am content on the square profile of the tire. Currently have a 245/40/18 on the front however the taller sidewall makes it look fuller and round at the top. 5 min ago I cancelled my order for 235/40, realized I will only be making it worse. My question. Will I be rubbing badly with a 265/35 up front? I am dropped to about 1 finger gap. Will it also make the front look more full? I am wondering if to simply get 245/40 again.
Again I apologize for making a thread on something that has prob been explained a thousand times, it is urgent. Otherwise I would have swapped my real wheels to the front and tried myself.
Edit: here is a pic. I am thinking of simply ordering 265/35/18 for the front as well but scared I will run a lot at this height. I have no fender mods
If you look at it closely watched you will notice what I am trying to fix. The front tire looks bigger than the rear.
Back tire squareness:
Front tire roundness/taller
Vroomin86 is offline   Reply With Quote
Old 05-18-2015, 01:08 PM   #2
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
check the last post of the meaty tire thread http://www.ft86club.com/forums/showt...=41083&page=61
Old 05-18-2015, 01:31 PM   #3
Vroomin86
Drives: 2015 Fire
Thank you, but I don't have a 9.5 inch wide rim. I have adjustable camber plates upfront and SPC camber bolts
Old 05-18-2015, 02:27 PM   #4
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Provided the offset isn't ridiculous, I imagine there would really be much of any issues, considering the fact the car is only lowered about an inch. However, some tires run tall and some run wide etc., so I'm not going to say 100% for sure you'll have no issues.
I doubt you'll be rubbing badly at that height though, especially since you have camber plates up front. You might see some rub under compression, but I don't think it's anything to worry about.
Old 05-18-2015, 03:37 PM   #5
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
i ran 18x9 +40 with 265/35. At -2.3 camber and about a finger gap, there is minimal rubbing. Can't go full lock while turning because will rub or hit spring, but its still easy to turn around for parking and such. I love the meaty tires.
Old 05-18-2015, 05:27 PM   #6
Vroomin86
Drives: 2015 Fire
Yea sorry guys can't believe I left out my offsets. +35 all around. This thread is worthless without pics. Let me fix that
Old 05-18-2015, 05:37 PM   #7
Model Citizen
Lacking brains
Drives: frz
Im running that size on a 9.5, et38 with -2.8 ish camber just fine
Spring rub at lock but never happens in the real world
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
The Following User Says Thank You to Model Citizen For This Useful Post:
Sportsguy83 (05-19-2015)
Old 05-18-2015, 05:48 PM   #8
Vroomin86
Drives: 2015 Fire
They look almost identical in height but I hate the fact that the rear is perfectly squared while the front is more round. Same tire brand and tire too.
Old 05-18-2015, 05:49 PM   #9
Vroomin86
Drives: 2015 Fire
So I am 5mm further out than you. Did you have to do any fender mods?
Old 05-18-2015, 06:13 PM   #10
Vroomin86
Drives: 2015 Fire
Bump for pic
Old 05-19-2015, 08:02 AM   #11
marlonthegreat
marlonthegreat's Avatar
I think this will answer your questions
http://www.ft86club.com/forums/showthread.php?t=87541
marlonthegreat is offline   Reply With Quote
Old 05-19-2015, 08:58 AM   #12
Sportsguy83
Drives: Limited BRZ
The rears are rolled, but the front fenders not. I did not do any other mod.
Old 05-19-2015, 04:21 PM   #13
Vroomin86
Drives: 2015 Fire
from all the pics ive seen.... it just looks like the front wheel well on these cars will always look more "filled" than the rear on a square set up. I chalk it up to the fact that these cars can take more offset in the rear than front.
Old 05-27-2018, 10:58 PM   #14
GT86_300plus
Drives: 2016 Scion FR-S
My 18x9.5 +40 with 265/35 square and its rubbing on my front
Right side on the frame rail.
GT86_300plus is offline   Reply With Quote
Wheel Directory: Volk Racing TE37 18x9.0 +45 Front / 18x9.5 +40 OmegaKnight Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 05-03-2016 08:09 AM
Pic Request: front wheel poke of 17x9 or 18x9 +35 on Prokit, TRD, RCE, or similar btoast Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 02-26-2015 02:38 AM
Wheel Directory: Work Meister S1 3-Pc 18x9.5 +29 / 18x9.5 +24 PradiG Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 12-12-2013 03:15 AM
Wheel + Suspension Question 18x9 +40 225/40/18 Front 235/40/18 Rear Asphalt~86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 06-10-2013 07:34 PM
Wheel Directory: Volk Racing TE37 18x9.0 +45 / 18x9.5 +45 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 09-04-2012 12:25 PM
