#15 | |
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
#16 | |
Drives: 2013 brz limited
Thanks! A member already told me to coating it, just wait get money next month Sent from my iPhone using Tapatalk |
#17 | |
I also just posted my findings about tuning out the flat spot with RomRaider software and an OFT. See here; http://www.ft86club.com/forums/showp...&postcount=250 |
#18 | |
I just bought some high temperature paint, and I want to coating by myself, is that working? Sent from my iPhone using Tapatalk |
#19 |
nobody knows if it is working but you bud
#20 |
I've read nothing but bad things about using high-temp paint on headers. The exhaust coatings used professionally are actually ceramic-based. Anything lower temp will smell noxious every time you use your car. I recommend returning the high-temp paint, get your money back, and wait till you can afford to get either the volcanic rock based thermal wrap, or drop it off to be professionally coated. The fiberglass wrap is cheaper, but you end up smelling it every time you drive. They say it burns off, but it still smells forever. The rock wrap burns off and doesn't smell very much after that. I got my last 2 headers professionally coated and they only smelled the first day, after that the smell went away.
#21 | |
Drives: FT86
You need ceramic thermal coating for that or header heat wrap |
#22 |
Alexandrino_Auto
Drives: series.Blue
He deosn't have to worry about the stock resonator melting because he doesn't have the stock airbox. Injen Intake can be seen in the picture. I haven't heard of anyone having issues with the fan shrowd melting. If so, @ZHoward I have a ton of foil tape you can use if you're worried about it.
High temp paint will make it look pretty and protect it from rust, but that's it. Ceramic coating is teh way to go. This place did my header for $150 http://www.pacificcoastpowdercoating.com/
The Shadetree Project: I turn wrenches
#23 | |
Haha, thanks, I don't worry about that, the only thing I'm worry about is overheating on track, cause I'm already feel it is hotter than before after I drive on freeway Sent from my iPhone using Tapatalk |
#24 | |
And I know ur place and it is good price, but it is too far .... I have to go to class on weekday and I don't think they are working on weekends... Sent from my iPhone using Tapatalk |
#25 |
I wanna go fast
Drives: 2013 FR-S 6MT
easy to see the difference between this and nameless now after those closeup weld shots
#26 |
#27 |
#28 |
Drives: 2018 BMW M240i
| JDL UEL header/Nameless header-back exhaust (Atlanta area) | carbon_raven | Engine, Exhaust, Bolt-Ons | 16 | 05-09-2015 02:26 AM |
| Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 10:41 PM |
| RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 05:42 PM |
| Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 82 | 04-14-2014 08:16 PM |
| Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 04:12 PM |
