#99 |
Drives: 2014 GT86
AceHeader-MT: i meant - low gains shown not due dyno (that's very common problem with trying to compare results from different dynos and going just for numbers, not +%), but low gains shown relative on baseline oem stock. Of course, some dynos may show much higher relative to others, but if baseline is done on same dyno and at similar weather (air temp/pressure wise), then relative % gains should be same no matter what dyno is used for both baseline & with header+tune.
And i don't get - why. Maybe baseline is too high for some reason (mixed up with chart from different configuration? Or not stock, but with tune?), maybe something wrong with aftermarked parts installed runs (wrong or no tune? bad install with leaking gaskets?). I fail to see why there is just 172.4 whp stock 176.4 4-2-1(+FP) (+2.3%), 200.3 Nm stock 202.8 4-2-1(+FP) (+1.2%), when for example with custom tunes Nameless or PTuning headers can get from 175 whp baseline to 200 header+tune (+14%). It's not +5whp vs +25whp, that might be due different dynos, that seems wrong to me. It's +2.3 vs +14% that seems wrong. And i have no clue for reasons, as i see nothing wrong with how header is designed, it even seems more promising design wise to me then other headers with sharper bends, shorter runner lengths, with collectors of runners at wider angle. Magic ![]() IIRC, even just and only off-the-shelf tune on full-oem-stock can give at least +10whp/+5% on petrol, twice what your header+tune shown. I just don't get what might be wrong. Tune + catted header should give +15whp. Your uncutted one SHOULD be much better :/ LOL, usually some unbelieving customers distrust vendor supplied results being too high .. now it's other way around, with me trying to distrust too low ones
| The Following 3 Users Say Thank You to churchx For This Useful Post: |
#100 |
Drives: frs
The combo #4 looks promising, nice work and thanks for the effort.
Where is the sounds clips lol |
| The Following User Says Thank You to Teseo For This Useful Post: | AceHeader-MT (05-18-2015) |
#101 | |
That Guy
Drives: 2013 asphalt FRS MT
#102 | ||||
Drives: 2012 FR-S
haha, good catch
![]() Quote:
For the DD and HPDE drivers this may not happen. Quote:
![]() Quote:
You can check out on-board sounds from the GT car here. Only difference is we have a custom muffler, different from the OE one used for dyno testing: [ame="https://www.youtube.com/watch?v=o5f-fCfZExI"]2015 TSF rd.1 - YouTube[/ame] We can work on getting good sounds bites next ![]() Quote:
#103 |
Drives: 2014 GT86
AceHeader-MT: btw, couldn't it be, that dynos were performed right after reflashing, and maybe it's when ECU still relearns fuel trims or something along the lines, thus not showing full results, unlike stock, which, as done prior any reflash/ecu reset/exhaust parts upgrade, ran at full, not throttled back prior dyno runs power? In some tunes for dynoing purposes it might be taken care of, but in some - maybe not, and just maybe that was the reason for lower results? Well, however it be, i don't believe that your header isn't capable of much more, and imho first results by other users of these headers with independently performed tuning should show much better results.
#104 | |
Drives: 2012 FR-S
There are a few arriving in the US soon and maybe dyno numbers will be released by them? No promises though |
#105 |
Drives: 2012 FR-S
Here's some photos of the day
| The Following User Says Thank You to AceHeader-MT For This Useful Post: | Hyper4mance2k (05-19-2015) |
#106 |
This looks promising. Perhaps the flow is so good that an off the shelf tune wasn't able to keep up?
was the ECU reset between setups and how many pulls were performed for each combination? I understand this is a lot of combos and dyno time is not cheap! |
#107 | ||
Drives: 2012 FR-S
![]() Quote:
We did 2 pulls of each set-up and 3 pulls with the prototype cross system = 15 pulls (USA x2, 4-2-1 OEFP x2, 4-2-1 ACEFP x2, 4-1 OEFP x2, Cross OEFP x2, Cross ACEFP x3, Full OEM x2) Combined with the time to swap of each system...it was a long hot day. |
| The Following User Says Thank You to AceHeader-MT For This Useful Post: | Calum (05-19-2015) |
#108 |
Drives: 2012 FR-S
Here's some dyno numbers from Fricke in Sweden. He put these together for us before his opening event at Sweden Time Attack this weekend.
He's running 4-2-1 and a custom 2.5 exhaust with a 200cel catalytic converter and a stuffed muffler for 95dB Give 'em hell buddy! |
#109 |
Drives: 2014 GT86
AceHeader-MT: you don't happen to have his baseline header-less stock numbers/dyno results, do you?
#110 |
Drives: 2012 FR-S
#111 | |
Kuruma Otaku
Because titanium. |
#112 |
That's my guess, but haven't seen confirmation on that.
BTW if you look at CSG's Ace header thread, CSG lists results as tested against a "leading UEL header", but no name given. I think that might be Tomei. They also post a dyno (different car, same dyno) showing results from PTuning's 4-1 header.
2022 BRZ Build 2013 FR-S Build |
| Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 10:41 PM |
| RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 05:42 PM |
| Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 82 | 04-14-2014 08:16 PM |
| Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 04:12 PM |
| Wanted: UEL header with Perrin header back and tune. | skye67 | Engine, Exhaust, Transmission | 7 | 12-21-2013 10:34 PM |
