#2731 |
#2732 | |
![]() I'm not a fan of external surges at all; the chance of it getting damaged and causing a fuel fire is too large. I won't coach cars with systems like that at all. If it's not disclosed up front (as requested), I'll just give a refund to the student and go home. |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | DocWalt (05-19-2015), Ultramaroon (05-18-2015) |
#2733 |
in orbe terrum non visi
Drives: violent
Street tires and RCE tarmac 2's. One NA one 450whp. The 3rd car is 225 whp built NA with JRZ'S still on street tires. We also had fuel starve at AMS on the roval. All e85. Atl brz is one of the cars.
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
#2734 |
Drives: 2012 Toyota 86
#2735 | |
http://datazap.me/u/darksunrise/data...og=0&data=1-14 You can see FLKC is much reduced. Oddly though, I started seeing progressively more FLKC in later sessions, even running the higher octane. Here's a log from my 4th (and fastest) session: http://datazap.me/u/darksunrise/data...og=0&data=1-14 Even though IAM's remained solidly at 1.0, I might start running the OFT 91 octane map at the track to be safe. The Perrin oil cooler was great at the track though. Peak oil temps were around 235 F, exactly what I was expecting.
2022 BRZ Build 2013 FR-S Build |
#2736 |
Drives: violent
Yes it holds the record na. 223 whp mustang dyno. Dbw motorsports has it on their Facebook page. Built high compression NA car.
| The Following User Says Thank You to Reaper For This Useful Post: | troek (05-19-2015) |
#2737 |
Just drive it
Drives: 13' FR-S
I went to Shenandoah circuit yesterday and I had so much fun.
Brake/tire setup OEM rotors Front - Project Mu HC800 Rear - stoptech street performance Stainless steel lines ATE type 200 fluid Sumitomo HTR Z III This was my second visit to this circuit, so I was more familiar with the track. I drove a bit more agrressively after each lap and I noticed at the end of each session, the brake would not work as it did in the beginning of the session. After 2nd session, I bled the brakes and there was a little bit of air in it. 3rd session, same feeling - great at beginning, fading at the end of the session. Is the issue brake fluid boiling, so leaving moisture in line? I've read from muptiple posts that ATE200 doesn't do that great on track. I know the boiling point is the lowest among the dot4 fluids, but just making sure I change to the right fluid on my next event. Also, any recommendation on budget rotor/pad upgrade would be appreciated! Thank you. |
#2738 |
Drives: 2013 Subaru BRZ Limited (WRB)
I removed one of my front DBA rotors to do some work to the ducting. On the back side, there was a perfect imprint of the carbotech pad. My previous reported issue was the pulsing, which we determined must be from the pad material that appeared to have melted on the visible front side.
Now that I've taken the rotor off, I can see a perfect impression of pad material in the shape of the pad on the back. The front doesn't have that. Seems to me that the rear pad stuck to the rotor when it was parked in the paddock. I checked the slider pins before the track day, and they appeared ok. Any thoughts on why this happened? |
#2739 | |
While you may have cooled the front brakes enough, the rear was probably still hot when you parked. I can't think of any other logical explanation. We know 100% that the brake was hot, but the reason why, is purely speculation. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Ultramaroon (05-18-2015) |
#2740 | |
You're getting the pads hot enough that they're fading (overheating) at the end of the sessions, and losing their bite. If you haven't already, you'll boil the ATE 200 (mushy pedal) as you get faster and step up the pads. We can help you with both. If you like the feel of the HC+800, try the Club Racer or 999 (approximately double and triple the cost of the HC+800). |
#2741 |
#2742 | |
This is the FRONT brakes. It's the backside pad that that had an imprint on the rotor (side opposite the wheel that you can't see). This is also with the pedal dance. The actual rear brakes, are 100% fine. |
#2743 | |
The inner edges of the rotors getting hotter is normal as well. The outside of the rotor has both more airflow (wheels/sides) as well as more contact area for sinking heat to the hub. It sounds like the inside pads are getting hotter than the outer pads. This is totally normal, particularly as you get more experienced. The imprint is from parking with the brakes still hot. The cheapest fix is to add brake ducts. The long term fix is to get a BBK (or bigger BBK). This is going to save you a ton of money on pads and rotors over the long term. For now, double your cooldown period, and do some slow laps in the pits to help keep air circulating until the brake system cools down more. |
#2744 | |
![]() ...still trying to fight that BBK |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 07:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 09:54 AM |
