#1919 | |
Drives: 2014 Scion FR-S
If you want lag free look elsewhere. This is a single core at 1 Ghz. The performance is less around what a flagship phone was in 2010. I compare it to MyTouch 4g from back when froyo was the flavor of Android. That being said it is a decent unit and leaps better than anything else I have seen in person. This unit supports a USB modem or you can use your phone's Wi-Fi hotspot. You can download offline maps in Google maps or use one of the apps that doesn't require network. Personally I just always tether and use Waze. |
#1920 | |
Drives: FRS RS 1.0
).Also does Waze allow you to download the entire USA maps? |
#1921 | |
I use Waze online for traffic based routing. Sygic seems to be the preferred option for offlinebut is not free. I tried but didn't like it. When my tethering was broken I would download offline maps of my area in Google maps. |
#1922 |
Because Racecar
Drives: 2013 Lightning Red Subaru BRZ
Has anyone had issues with extreme static or audio drop-outs? I was having audio drop-outs that seemed to coincide with bumps, so I assumed my connections came loose. (Probably unrelated, my rear camera also stopped working.
So I took out the unit to check all the connections. Nothing seemed loose, but i reconnected everything. When I turned on the car, I got good sound for about 15 seconds, then no audio (and still no rear-camera). If I turn up the volume I can hear intermittent static using USB and the radio app even when still, so its not a loose connection (well I doubt it is). I'm starting to think its something inside the unit. Anyone have ideas before I put the stock HU back in for testing? |
#1923 |
Drives: 2013 GBS BRZ Limited
Plug the stock HU back in and see what happens.
| The Following User Says Thank You to Pwolf For This Useful Post: | DC2R (05-17-2015) |
#1924 |
Drives: '13 Subaru BRZ, '06 Toyota 4Runner
I had issues like that for a while. Tapping the screen with a bit of force did the same thing. It eventually sorted itself out.
| The Following User Says Thank You to SilverlightPony For This Useful Post: | Kevinn (05-18-2015) |
#1925 |
Because Racecar
Awesome - I got out my old HU and for some reason the SD Card was gone. Hooked it up anyway (thinking it might just be for maps) and it won't even get past the Initial screen. Anyone have an image they would be willing to share?
#1926 |
Drives: 2014 BRZ Limited, Black, Manual
The stock BRZ Head unit may have an antitheft feature on it. But I could be mistaken. Maybe it's still covered under factory warranty? There's SD images on this forum elsewhere, you'll have to search for it.
#1927 |
Drives: Subaru BRZ '13 WRB
Image will not work. Files in the card are encrypted with card ID. Unfortunately, there is no way to use it without original SD card (SD will work from other models, including Toyota cars, using same type Fujitsu head-unit).
#1928 |
Drives: Mazda Miata
There's a 2015-03-18 rooted firmware on official forums http://ca-fi.com/forum/viewtopic.php?f=26&t=4751
But I haven't tested it! |
#1929 | |
I can't test the firmware, will be busy. Hopefully someone else can chime in? |
#1930 |
Hooner in training... eh?
Drives: 2013 Scion FRS
Anyone else notice the website pricing is down to $429? Is this normal or because they're out of stock??
**Dunno what to put here yet... Imagine something witty...** |
#1931 |
Drives: asdasdf
I will mainly be using the headunit to listen to Pandora while Waze runs in the foreground. Based on what i have read, that should work just fine. However, does this also work with FM radio and waze/ google maps audio? Or is the FM function an application that exists outside of the standard android system? I hope that makes sense.
#1932 | |
| REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo | SHIFTER | Electronics | Audio | NAV | Infotainment | 16 | 06-13-2017 07:23 PM |
| Android, bluetooth, Music, and the FR-S stock pioneer stereo | JayNutter | Electronics | Audio | NAV | Infotainment | 27 | 12-18-2014 04:54 AM |
| How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 | SHIFTER | Electronics | Audio | NAV | Infotainment | 29 | 04-07-2014 05:58 AM |
