View Poll Results: Would you be interested in purchasing this product?
Yes 182 70.82%
No 24 9.34%
Maybe 51 19.84%
Voters: 257. You may not vote on this poll
Old 05-17-2015, 02:27 PM   #393
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
Originally Posted by protpibe View Post
Installing mine now, just about done. I'll post impressions soon
Can you comment on whether you can Dremel off that corner without removing the bracket from the car? Thanks!
1Cor10:23 is offline   Reply With Quote
Old 05-17-2015, 02:39 PM   #394
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Move Over Racing Bumper Q/R's. Interest?
Yeah you could but the top is awfully close to the fender. It's much easier to just remove it
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 05-17-2015, 04:14 PM   #395
protpibe
protpibe's Avatar
Okay so I just finished the install and my feelings are still a bit mixed. First of all, I wanted to confirm that the angled spacers do not just "float around", they're used to angle 2 of the 4 rods and they are bolted down on either end. On the topic of the angled spacers, I don't buy that they are more expensive to make than a bracket. You could just take a 3" long spacer and cut it in half at an angle. Voila, 2 spacers. Anyways, that's neither here nor there, but I did want to clear that up since I posted that it appeared they were used differently earlier.
Anyways...
The install is fairly straight forward and the instructions are adequate. At points it's fairly hard to understand, but once you have your car apart, it becomes pretty clear what has to be done. From beginning to end I would say that their 1.5 hour estimate is a little optimistic, but it's nowhere near an all day job. I do all my own work on my car and have had it apart countless times, and I would say it took me and a couple buddies 2 hours or so, but that includes time to discuss things like vaginas and beer.
My main complaint is the "generic" feel to everything. There are adjustments and measurements to be made when installing the rods which is what I didn't want to do when I bought a purpose built kit. A bracket would bolt in and have the rods in place. No measuring, no adjustment, it just bolts on and away you go. Two of the rods actually go through large 1/2" x 1/2" square holes and can be moved around significantly. I guess it's not the end of the world, but like I said, with a bracket it would essentially bolt on and be done with it.
Surprisingly, one of the easiest parts of the install is drilling giant holes in your bumper. It was a little nerve racking to gouge 3/4" holes with a stepped bit, but it went ok. My only suggestion at this point is to triple check as you go. I drilled the pilot hole, reinstalled the bumper and adjusted the angle in which I drilled to make sure it was centered. Once I went a step or two down, I installed and checked again. The end result was a perfectly centred rod.
After the actual clips are installed, be prepared to spend some time installing, removing, adjusting, and reinstalling. You need to find the "sweet spot" for the rod length to ensure you have a smooth bodyline between the fender and bumper cover.
I did have issues with the marker lights clearing the rods themselves and ended up having to cut a bunch of plastic and trim down the light connecter. Again, not the end of the world, but it's something that you would hope could of been avoided having bought a purpose built kit.
Overall I would rate the end result as an 8/10 and the kit itself about a 6/10 due to not being a true bolt on and go.
Would I buy it again if I had to go back and do it over? I'm 50/50.
Pros:
-It securely pulls the bumper into the car, as opposed to the OEM hook/clip system
-Fairly easy install, but somewhat time consuming.
-Latches look nice (if you are into that kind of look) - Mine are black on black
-Bumper gap is more or less gone
-The kit is adjustable, so even if you mess up a tiny bit, there's some "repair" area to play with
Cons:
Tough to justify the value for $185US
Not a simple bolt in install. Requires measurement and adjustment
Easy to mess up if you don't take your time
Clearance issues with marker light harness required trimming/dremel
Overall, I feel that this kit would be at home selling on ebay for $99, but $185 isn't the end of the world since it was designed and built in this hemisphere.
The Following 5 Users Say Thank You to protpibe For This Useful Post:
1Cor10:23 (05-17-2015), civicdrivr (05-19-2015), dj2020 (05-18-2015), Kiske (05-19-2015), SPCorBUST (05-17-2015)
Old 05-17-2015, 04:20 PM   #396
zeal86
zeal86's Avatar
Drives:
@protpibe Could you please post some process and final install pics?
projekt zeal86 build
zeal86 is offline   Reply With Quote
Old 05-17-2015, 04:33 PM   #397
protpibe
protpibe's Avatar
Sure. I started out taking pics but neglected it as the process went on.
They could of done a better job illustrating what needs to be cut. Essentially it's the upper corner closest to where the forward latch will be sitting.
If you want to save yourself some headache, take your wheels off or have the car in the air so you can turn them out of the way
Other than that, all the pics you need are in the instructions
The Following 4 Users Say Thank You to protpibe For This Useful Post:
civicdrivr (05-19-2015), juliog (05-17-2015), SPCorBUST (05-17-2015), zeal86 (05-17-2015)
Old 05-17-2015, 04:36 PM   #398
zeal86
zeal86's Avatar
Drives:
Attachment 109873
Attachment 109874
Attachment 109875
Attachment 109876
Looks good... in one of your pics the bumper is still out a bit... was that pic taken pre-adjustment?
Old 05-17-2015, 04:37 PM   #399
protpibe
protpibe's Avatar
It's the angle and lighting. I noticed that too and double checked to confirm that it's flush
The Following User Says Thank You to protpibe For This Useful Post:
zeal86 (05-17-2015)
Old 05-17-2015, 04:43 PM   #400
zeal86
zeal86's Avatar
Drives:
cool thanks... I'm on the fence still about returning the kit...I have not received a tracking number yet so hopefully if I decide to receive a refund it won't be a hassle. More than anything it is the cost versus what is received that has me on the fence.
Anyone received an anodized red set? Would love to see how they look installed... especially on a 37J or halo.
Old 05-17-2015, 06:25 PM   #401
1Cor10:23
1Cor10:23's Avatar
@protpibe thanks for the review, very insightful. Could I bother you to count the number of exposed threads for both rods? This could save a lot of adjustment time for everyone. Thanks!
The Following User Says Thank You to 1Cor10:23 For This Useful Post:
zeal86 (05-17-2015)
Old 05-17-2015, 08:03 PM   #402
protpibe
protpibe's Avatar
I'll see what I can do when I get home.
Also, I just want to point out that there is very little "quick release" to this kit. The only thing you are cutting out of the equation is the popit behind the marker light. Literally everything else still has to be done (fender liner screws, under hold stuff, under car stuff).
Old 05-17-2015, 08:18 PM   #403
1Cor10:23
1Cor10:23's Avatar
@protpibe that I agree with. Although I'm mostly getting it for gap control.
Old 05-18-2015, 07:44 AM   #404
JD86
Drives: 2013 Toyota 86 GT
So you only need two of the spacers, and looking at your kit they supplied you with four?
JD86 is offline   Reply With Quote
Old 05-18-2015, 08:13 AM   #405
1Cor10:23
1Cor10:23's Avatar
@JD86 you need two for each of the rear rods
SPCorBUST (05-18-2015)
Old 05-18-2015, 08:22 AM   #406
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
There is nothing structural behind the holes where the rod goes through correct? They look to simply bolt to the excess metal on the fender itself. Do you think this could be done with aftermarket fenders such as Todoroki/Virctory/Ings/Seibon that are fully fiberglass/carbon?
FRS front bumper garnish, interest? tunami Cosmetic Modification (Interior/Exterior/Lighting) 73 07-22-2015 11:53 PM
Just about ready to move on... SCharged Scion FR-S / Toyota 86 GT86 General Forum 75 10-07-2013 04:05 PM
Anybody else about to move on? TylerLieberman Scion FR-S / Toyota 86 GT86 General Forum 356 09-19-2013 08:51 AM
