Old 05-11-2015, 07:41 PM   #1541
knipple
Drives: 2013 Ultramarine Scion FR-S
Originally Posted by swarb View Post
Im at 2.9 camber front and rear. Trying to get to 1.8-2.0 or so in the rear. 0 toe front .04 toe in rear.
Are aftermarket side skirts/steps, rear spats and lip spoiler legal? worried about aero rules.
Anyone have direct link to stx class rules? what is the other name for it? street XXXXX?
Here is a link to the rules: http://scca.cdn.racersites.com/prod/...ne_reduced.pdf
Street Touring is section 14 in the rulebook. As a general rule, if the rulebook does not say you can do something, you can't do it.
As far as Aero is concerned, the following bold italicized statement is what the rule book says. Depending on the region you run with, you may be able to get away with the Aero, but don't count on it.
Addition of spoilers, splitters, rear wings, bumper covers, valances, side
skirts, and non-functional sccops/vents is allowed provided that either:
1. It is a production part which is standard or optional equipment of a
US model of the vehicle. (“Model” is defined in Section 12.)
2. It is listed in the vehicle manufacturer’s US accessory catalog for that
vehicle for normal highway use. This does not allow for parts sold
through a manufacturer’s performance catalog (e.g., Ford Racing, HPD, Mazdaspeed, Mopar Performance, Mugen, NISMO, SPT, TRD,
etc).
Parts must be installed as directed by the manufacturer. Exact
replicas,including weight, from alternate sources are also permitted.
knipple is offline   Reply With Quote
The Following User Says Thank You to knipple For This Useful Post:
swarb (11-03-2015)
Old 05-11-2015, 07:53 PM   #1542
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Originally Posted by cjd View Post
You didn't mention the overwhelming proportion of gains to be found in the driver?
I will get better. I will get better. I will get better.
(Suspension done, excuses gone... I will get better!)
Ha... Good point.. . But I was taking the Driving part out of it and helping concentrate on setup...
-Adjustable bars are good.. the more adjustment you have, the better off you are to dial in the setup to your liking. whiteline 20-22 mm..
-Rear Bar can be had for cheap.... Used Stock 2008-2014 STi Rear bar.. since most of those guys change the stock bar ..anyways... there is a difference between a sedan and hatch bar and there is a year split and bar diameter change... *can't remember what it was tho... I am using a 2012 STi rear bar *19mm.. some of the earlier years were 18mm..
after market camber bolts will add appropriate camber to about -3 degrees for cheap to. but since you have the Feals.. you should be good. I will say that alignment is pretty critical on this platform... and there is definitely a sweet spot when conducting them. *mine has been on the alignment rack about 20 times since I owned it. Hope that helps
Bill
Scooby South is offline   Reply With Quote
The Following User Says Thank You to Scooby South For This Useful Post:
swarb (11-03-2015)
Old 05-11-2015, 10:25 PM   #1543
Skurj
Drives: SOLD...
Well as much as it would make sense to do suspension first it doesn't make a lot of sense right now unless I want to throw away $$..
With the current limitations of stock shock/Struts with lowering springs, replacing sway bars just means I will need to spend the money again to replace them once I install coilovers...
I need more front neg camber, and until i can get it.. the only thing that will help is abit more power..
Or bite the bullet for the first part of the season while saving for coilovers...
Is there a 'cookie cutter' sway bar setup being used these days?
What are the favoured spring rates for tarmac 2's these days?
So far my feeling is I need a car perhaps leaning towards oversteer but that could just be my frustration of having to deal with the boat i currently drive...
Tossing up RCE T2's or Ohlins... but .. fiscal responsibility may delay...
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018
and its gone... Sept '18 tho I am sure I will miss it
Replaced with 18 50th edition ND
Skurj is offline   Reply With Quote
Old 05-11-2015, 10:51 PM   #1544
cjd
cjd's Avatar
Drives: 2017 BRZ
If you're serious, T2 with good top-hats... by the time you get up to Ohlins, you're close to Tein SRC, which is ... well, spiral on up. Or keep your eyes peeled for a used set FS!
I was out (first time in this car, first time in 12 years) in a completely stock suspension setup on 225 PSS and didn't have issues lacking oversteer - I just wasn't pushing the car at all (or at least, that's the best I can figure.) I do have a tune, worth it for the soft revlimiter if nothing else.
I'm still on stock sways with new coilovers and a proper alignment (and 200TW tires now.) Going to run this way for a bit, watch tire temps and try to get a feel for things before making any other changes.
All that to say, I agree - suspension before power. Coils before sways, IMO. Alignment above all. And tires. And seat time.
You can get some crazy good deals here and there in the FS section.
Old 05-12-2015, 10:44 AM   #1545
autoXracer
Drives: 2013 WRB BRZ
What size RE71R are people running in STX? Is it same as RS3's 245/40-17 or 255's?
autoXracer is offline   Reply With Quote
Old 05-12-2015, 11:10 AM   #1546
justint5387
Drives: 4 wheels
We ran the 245/40/17. Have not tried the 255/40/17.
justint5387 is offline   Reply With Quote
The Following 3 Users Say Thank You to justint5387 For This Useful Post:
autoXracer (05-12-2015), MaxRED13 (05-27-2015), tigermack (05-13-2015)
Old 05-12-2015, 04:55 PM   #1547
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
The 255's have not really been readily available.
As for sway bars I prefer Whiteline
2superblus is offline   Reply With Quote
Old 05-12-2015, 05:37 PM   #1548
cjd
cjd's Avatar
Drives: 2017 BRZ
I'm trying 255 RE71R's. Might be willing to let a more seasoned driver have a go with them...
The Following User Says Thank You to cjd For This Useful Post:
Old 05-12-2015, 06:18 PM   #1549
autoXracer
Thanks for the input everyone! I remember for Dunlops 255 were preffered whereas 245 for RS3's. Might be too early to tell which works better on RE71R's
Old 05-14-2015, 06:04 PM   #1550
Skurj
Drives: SOLD...
Reconsidered my plans.. may as well leave the car as is for now. Until I can fit coilovers and the alignment to go with them, any bars I buy now will be wasted money.
The only other option is to spend money on power...
Ahh well, another season of gaining experience I guess!
Paid for Mar 2018
Old 05-15-2015, 07:05 PM   #1551
Forgetful
Drives: 2013 Ultramarine FR-S
Originally Posted by Mad_Mike View Post
Yes. There are a few local guys here running the 5 axis lip spoiler (in cs and stx), which are legal since they were put on at the port. Looks like this:
The OEM one in the catalog looks like this (legal):
Rs one looks like this (legal?):
I'm hoping to confirm this. Your post is the only reference to the 5ad spoiler and its legality. Anyone know if there's documentation to back that up. My local club wouldn't hesitate to let me stay in CS, but I might compete at the Canadian Nationals and I want to be certain I classify properly.
If it's not legal, what does that do to my classing? Best I can tell it wouldn't be legal in STX either.
Forgetful is offline   Reply With Quote
Old 05-15-2015, 07:56 PM   #1552
RedBRZ80
Drives: 2013 Red BRZ
The 245/40 RE71R is the hot tire and size at the moment. It's what I'm running and the last three local events I've finished no lower than 2nd overall pax.
RedBRZ80 is offline   Reply With Quote
The Following User Says Thank You to RedBRZ80 For This Useful Post:
autoXracer (05-16-2015)
Old 05-15-2015, 08:46 PM   #1553
cjd
cjd's Avatar
Drives: 2017 BRZ
Who has run 255? 245 was definitely the safe bet early in the game, but I haven't actually heard much on the 255. 245 may still be the best option, just not sure it's actually between compared yet. I may also be unaware, and it has.
Old 05-16-2015, 12:24 AM   #1554
EN2_Squirrel
EN2_Squirrel's Avatar
My budget is pretty limited. So at this point I am going to do a few more things and just get seat time.
I have feal 441's already yay, I went with 7k/7k rates. Shocks set currently at 18f/20r (1stiffest/30 softest).
1. pads that I can daily looking a winmax w3/w4, project mu hc+800 one of those and motul rbf 600 fluid.
2. 17x9 +35 wheels and 245/40-17 tires, rs3's probably.
3. Adjustable front sway bar. whiteline? strano?(not adjustable?) hotchiks? suggestions? can the endlinks be spherical type?
4. something to dial out some camber in the rear, options?
I think that is most of it. Suggestions?
It's going to be my first season so I guess I am shooting for local events and getting seat time.
The pad setup I have is winmax w4front/w4rear. but i was recommended to go to a w4front/w3rear for better cold use. as the rears dont get "too hot" for autox. If i am in the wrong for this thinking please feel free to correct me. On another front I doubt it but is that hotchkis x brace/half cage thing legal?
STREET MOD. My wallet now hates me....
EN2_Squirrel is offline   Reply With Quote
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
